MMA7455 and BS2sx
Hi guys,
I am trying to use a MMA7455 3 axis accelerometer module with a BS2sx. I tried the demo code for the BS2 and modified this code and both work for the BS2 (demo MMA7455L 3-Axis Accelerometer Demo (PBasic) v1.0 DEMO#2.bs2 and my code testlessvar.bs2 ). Unfortunately when I switch the chip to a BS2sx the accelerometer values always indicate -1 on all axes. I need to use the BS2sx for memory space. After looking into it, I tought it might be caused by the different transmission rates of the SHIFTIN and SHIFTOUT commands on the BS2sx (42 kbits/s instead of 16kbits/s for the BS2). Is this the problem and is there anyway I can fix it?
Thank you for your help!
