Any analog video summator schematics available?
Hello.
I have bought for quite cheap 4 pcs of 1/4 sharp CCD boards with lens. They perform quite nice, but I have an idea - align them all into one direction, and sum the video signal, to get better low light visibility. I've checked maxim, analog, etc. websites, was not unable to find an IC that can join together several analog video signals, only switches and muxes are available. There are no such solution?
although if you did want to use DSP practices to try and stitch together the overlapping multiple images it would be a fascinating project.
sort of like fly eye vision... scratch that, sort of like spider eye vision, to start with.
DSP stacking is good, but it needs much more specific knowledge.
For better low light sensitivity it may be simpler to use a lens that collects more light.
Ditto that.
You can't just sum video signals and get a valid video signal as a result. Firs of all, they won't be synchronized with each other unless you spend a lot of money on cameras that accept an external sync. Second, even if the signals were in sync, only the video portion should be summed, not the syncs. And, finally, you would ultimately be defeated by parallax due to the optical axes of four lenses not being colinear. Once you adjusted things to get image convergence at one distance, subjects at other distances would be non-convergent.
http://www.engadget.com/2013/05/02/pelican-imaging-array-camera-coming-2014/
Depending on the actual ccd chip used, if they are externally clocked, you may be able to parallel them so that the charge in each bucket is clocked out of the same pixels at the same time syncronously. You could sum these outputs into an op amp circuit but I think you would have to be able to sum either the current or convert the charge current to a voltage to sum in the op amp. That all assumes that none of the clock drivers is built into the CCD chip itself. It was one thing to sync multiple chips to get a higher resolution scan of an image (with very specialized lens assemblies and software stitching trickery) quite another to try to overlap the same image. CCDs are discrete packages of charge laid out row/column. If you are just a bit off in timing, the rows of columns will overlap and I would guess the net effect would be the same as if you defocussed an analog pickup tube and overscanned the same areas as you went. As to lenses, Nightmare one would be lining up 4 separate lenses, Phil ran that one down. if you used one lens with a splitter to go 4 ways,odds are the losses would offset any gain of using four CCDs Since the amount of light will not increase as it moves through the lens assembly, each CCD would then see one fourth of the amount of light as was coming into the lens assembly. The result, a blurry lower contrast image than one ccd w/ one lens.........
</speculation>
The common clocking and lens assy was one OEMs way to get higher resolution AND frame rates out of a medical system camera based on two ccd chips ...........
You would probably get a better S/N improvement by cooling the sensor in one camera and amplifying the image portion of the video output.
Here's datasheet for CCD sensor used in normal quality ccd camera boards:
http://www.datasheetarchive.com/sony+icx639-datasheet.html
