Another 5v latching relay source
I know Ero likes to buy these for 99 cents from Electronic Goldmine, but there are times when those are sold out.
http://www.futurlec.com/Relays/LATCHREL5Vpr.shtml
It took a bit of argument to convince people that these are in some ways better than regular relays (like they don't require constant power to hold an on or off), but they do make some low power projects easier to build.
On the other hand, these would work nicely with the BasicStamp BOE to offer extremely low power.
Why do some have two coils and other have one coil. Generally the two coil latching relays are required to switch higher load. These are rated for 5 amps.
http://forums.parallax.com/showthread.php/140126-Nice-Relays-for-1.10-ea-Prop-Potential
Hmmmm.... okay. Then these 2 coil latching relays might just be a good choice. It is easy enough to drive the 5V coil via a 2n2222 with flyback diodes.
For my own uses, reed relays are a bit delicate. 5 amps or more suits me.
Now where did I put them? I still have to make a BS1 control 27 relays.
http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/FAN3241TMX/?qs=sGAEpiMZZMtKB4wrjsn3lSqE3QXy0U%2fLgws7q%2fJvbYI%3d
The output is rated at 8 VDC minimum and the relay I mentioned is 5VDC --- they are not compatible.
Large 12v and 24v latching relays do exist. I find it a bit hard to spend $1.50 on a chip to drive a $2.50 relay. While it may be prudent, even necessary.. it seems as if I might be just adding too many chips because I don't properly understand the latching relay.
The 5v latching relay has 300mw coils, so it seems to need 60ma at 5 volts. That is definetly too high for direct connect to any microcontroller - a transistor or MOSfet is needed on each latch coil to boost available power.
