Electret Microphone Question — Parallax Forums
sunblocksunblock Posts: 55
edited 2013-04-30 16:14 in General Discussion
I've attached a picture of a schematic of a voice IC module that has an electret microphone attached to it. The schematic shows both the positive and negative leads of the electret mic connected to the voice IC module (ISD3900)--directly. My question(s): why would the negative lead be attached to the IC? Is it not true that the variation on the positive side reflects the sound pressure on the electret mic? And if one wanted to use this as simply a sound sensing device, would it not be better to run the(+) side through a ADC to get get fluctuation readings, and simply ignore the (-)? Similar in concept to the sound impact sensor from Parallax... Thoughts....
VR/JW--Sunblock
