Directory listing question using FSRW 2.6
Here is the code that I'm using:
I have 31 files on the sd card. When doing a directory listing the listing starts out fairly fast but then gradually slows down as the listing progresses. Anyone else ever notice this? what might be the bottle neck in this?
In case you're wondering- yes I have tried many different cards. It's not the cards. Is there a buffer somewhere that gets bogged down?
pub SD_Directory | num_files, j, rslt
rslt := \sd_mount
if rslt < 0
return
num_files := 0
sd.opendir
slave.str(@sdfiledir1)
repeat while 0 == sd.nextfile(@tbuf)
num_files ++
repeat j from 1 to num_files
bytefill(@tbuf, 0, 20)
sd.opendir
repeat j
sd.nextfile(@tbuf)
sd[ 1 ].popen(@tbuf, "r")
slave.str(@tbuf)
repeat 15 - strsize(@tbuf)
slave.tx(" ")
slave.dec(sd[ 1 ].get_filesize)
sd[ 1 ].pclose
slave.tx(13)
slave.tx(10)
slave.str(string("Number of files: "))
slave.dec(num_files)
slave.tx(13)
slave.tx(10)
sd.pclose
sd_unmount
repeat j from 1 to num_files bytefill(@tbuf, 0, 20) sd.opendir repeat jpub nextfile(fbuf) | i, t, at, lns {{ ' Find the next file in the root directory and extract its ' (8.3) name into fbuf. Fbuf must be sized to hold at least ' 13 characters (8 + 1 + 3 + 1). If there is no next file, ' -1 will be returned. If there is, 0 will be returned. }}It appears, invoking fsrw.nextfile(buffer) copies the 8.3 file name to the buffer argument. If no file is found then fsrw.nextfile(buffer) returns -1. The directory listing in the original posting can be simplified with a single repeat until. Instead of first finding the number of files keep incrementing a counting until fsrw.nextfile(buffer) returns -1. On each iteration that returns 0, either send the file name to the terminal, process the file name, or buffer the files name(s) for later processing.
repeat while 0 == sd.nextfile(@tbuf) num_files ++ repeat j from 1 to num_files bytefill(@tbuf, 0, 20) sd.opendir repeat j sd.nextfile(@tbuf) 'sd[ 1 ].popen(@tbuf, "r") slave.str(@tbuf) repeat 15 - strsize(@tbuf) slave.tx(" ") 'slave.dec(sd[ 1 ].get_filesize) 'sd[ 1 ].pclose slave.tx(13) slave.tx(10) slave.str(string("Number of files: ")) slave.dec(num_files) slave.tx(13) slave.tx(10) sd.pclose sd_unmountAlthough it would be nice to have the filesize...
if \fsrw.mount(spiDO,spiClk,spiDI,spiCS) abort string("Can't mount SD card") fsrw.opendir b := 0 d := false repeat while fsrw.nextfile(@f0) == 0 d := true if b == 78 dsp.out(dsp#Cr) b := 0 dsp.str(@f0) ' put .popen / .get_filesize / .pclose here if you want repeat 13 - strsize(@f0) dsp.out(" ") b := b + 13 if d dsp.out(dsp#Cr) \fsrw.unmountWhat are you doing with "b"? I see it starts out as "0" and you increment it by 13 through the repeat loop and if it equals 78 you do what? Send a CR? Are you counting characters?
That is what the original code I posted above does. It uses 2 iterations of FSRW. One to read the filenames and the other to get the filesize of the filename. It really slows down if you have a number of files to list.
I think your code could be sped up a little bit by rewriting it as follows:
pub SD_Directory | num_files rslt := \sd_mount if rslt < 0 return num_files := 0 sd.opendir slave.str(@sdfiledir1) repeat while 0 == sd.nextfile(@tbuf) num_files ++ sd[ 1 ].popen(@tbuf, "r") slave.str(@tbuf) repeat 15 - strsize(@tbuf) slave.tx(" ") slave.dec(sd[ 1 ].get_filesize) slave.tx(13) slave.tx(10) slave.str(string("Number of files: ")) slave.dec(num_files) slave.tx(13) slave.tx(10) sd.pclose sd_unmountThis will still slow down as you proceed through the directory because popen will scan through the directory looking for the file each time. It takes longer to open a file that's located further in the directory. As I mentioned in my previous post, you could speed this up by modifying nextfile, or adding a new method to FSRW that returns both the filename and filesize.pub directory | fcount, check, idx, p_fname, fsize ' populate filenames list first bytefill(@filenames, 0, 13 * 100) ' clear list sd.opendir ' setup for .nextfile fcount := 0 ' reset files count repeat check := \sd.nextfile(@filenames[13 * fcount]) ' get next file in root if (check == 0) ' if found fcount += 1 ' increment file count else ' else quit ' done ' iterate through list, show name and size term.tx(CLS) if (fcount > 0) term.str(@Banner) repeat idx from 0 to fcount-1 ' loop through files p_fname := @filenames[13 * idx] ' point to name fsize := open_file(p_fname, "r") ' open, get size term.str(p_fname) ' print name term.tx(GOTOX) ' move cursor term.tx(16) if (fsize > 0) term.dec(fsize) ' print size else term.tx("?") term.tx(CR) term.tx(CR) term.dec(fcount) term.str(string(" file(s) found.")) else term.str(string("No files found.")) sd.pcloseI see now. You are listing them in a block sideways. When you get to 78 you start a new line.
Dave- That works 100% faster. Thanks for your help.
pub SD_Directory2 | num_files, rslt, b rslt := \sd_mount if rslt < 0 return num_files := 0 b := 0 sd.opendir slave.str(@sdfiledir1) repeat while 0 == sd.nextfile(@tbuf) num_files ++ sd[ 1 ].popen(@tbuf, "r") slave.str(@tbuf) repeat 12 - strsize(@tbuf) slave.tx(" ") slave.decn(sd[ 1 ].get_filesize, 8) slave.tx(" ") if b == 42 slave.tx(13) slave.tx(10) b := 0 b := b + 21 slave.str(@sdfiledir2) slave.dec(num_files) slave.tx(13) slave.tx(10) sd.pclose sd_unmountBut for some reason I can't get the first line to work right. I tried changing the b := b + 21 and the if b == 42 statements but can't figure out why. Also tried initializing b to 1. The filename, space, 8 digit filesize and space equals 21
Here's what I get:
What am I doing wrong?
