propstick serial transmit indicator led on?
I have my propstick plugged into a breadboard running a program but the program does not seem to be working and the red serial transmit indicator led is on? anyone know why this is?
I am trying to use it as an 8bit register or 9 if the twos compliment needs 9
heres my code but i dont think that has anything to do with it.. I have +5 volts going to pin12 and have it grounded on pin9
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 var byte a,b,c,d,e,f,g,h,i word subtraction,clock pub register2v2 dira[0..7] := 0000 dira[8..16] := 11111 dira[30..31] := 00 repeat clock := ina[31] subtraction := ina[30] outa[8] := a outa[9] := b outa[10] := c outa[11] := d outa[12] := e outa[13] := f outa[14] := g outa[15] := h outa[16] := i if clock <> 1 a := ina[0] b := ina[1] c := ina[2] d := ina[3] e := ina[4] f := ina[5] g := ina[6] h := ina[7] if subtraction == 1 a := !a + 1 if a == 2 b := b + 1 a := 1 c := !c if b == 2 c := c + 1 b := 1 d := !d if c == 2 d := d + 1 c := 1 e := !e if d == 2 e := e + 1 d := 1 f := !f if e == 2 f := f + 1 e := 1 g := !g if f == 2 g := g + 1 f := 1 h := !h if g == 2 h := h + 1 g := 1 if h == 2 i := 1 h := 1 if clock == 1
