New OBEX thoughts
Hi all,
I just had a look at the new OBEX, looks good
I do however have a couple of things
Is it going to be just one OBEX? or one per device? Prop1, Prop2, etc as it may be a bit of a nightmare.
Will there be a search function?
Also, the headers All/Data Storage/Display/Fun/Human Input/Math/Motor Control/Protocol/Sensor/Signals/Speech/Sound/Tool are too long for the display and is drawn over the line beneath, ( even though the window is wider 2560 on my mac )
Cheers,
Jim.
Cheers,
Jim.
Ray
As risk of encouraging four different concurrent threads of discussion on obex, you'll be pleased to know a very nice search system will be implemented soon.
I don't think it's active right now, but all of the object entries had to be checkmarked with "Propeller 1" as they were moved, so we've got the bases covered for Propeller 2.
The window size is actually under discussion, so I suspect you'll see some adjustments there, but that's not my department.
Jeff
If someone could shift my first name into the last name position (leaving the first name blank) that would probably take care of the issue.
It's probably a manifestation of the root cause discussed in post #14 of this thread: http://forums.parallax.com/showthread.php/147593-New-Propeller-Object-Exchange
Is there another place for c drivers/code for the propeller?
