MSR1 Power problems
Hi,
I'm attempting to build a hexapod robot using the MSR1 (retired) board to run the servo motors. There are 3 servo motors in each leg so 18 total. I have used the jumpers to set all the pins to "V IN" setting, and am supplying 6V from a DC power supply. However, every time I turn on the propeller, it resets itself with in seconds and continues to do so. Is this the current limiter? If so what can I do to prevent the current to the chip spiking? I would like to run the chip on a separate 3.3V supply but I can't stop it from running of the 6V.
Any suggestions of what might be causing this/ how to solve it?
Many thanks,
Jon
Many thanks,
Jon
Also 6V is the lowest that the board appears to run with. There's even mention of 6.5V in the first couple of paragraphs of the documentation.
Does the board stay stable when you don't try turning on any servos?
I guess what I'm asking is, is it resetting because the motors are trying to move, or would it still be resetting without the motors plugged in?
Well, it looks like you have two problems...
If the servo voltage limit is 6 volts (and 5 preferred?) and the Prop regulator want to see 6.5?
That put's you 1/2 volt below a guaranteed limit.
The other is current, not voltage.
When the current load increases, the voltage is being pulled down below the above limit.
Figure 1 amp for each servo.
They don't pull that all the time, as you noted.
But if they EVER all run at the same time, they will all pull their own 1 amp - each.
The best solution?
Raise the Vin to 7.5 volts and add a 5 volt regulator (LM7805?) for each servo.
But you HAVE to supply enough current to run all the do-dads.
And that could be as high as 18 AMPS.....
You will not get that from any wall wart I've ever met.
I don't see any big electrolytic capacitors on the board, so if your power supply isn't giving you 15A at 6v, you're probably sagging it down too much. Servos run all the time, they are closed loop analog devices and have an idle current of 15ma, and a no-load operating current of 140ma +/- 50ma.
So, at least 270ma at 6V idle, 2520ma no-load moving, and probably around 9A peak load current.
I'm guessing your power supply is too small and 18 servos is creating a lot of sag/noise on the power bus and causing the Propeller to brown out. The other option is that you are encountering the un-powered USB bug where the Propeller powers the USB chip via parasitics because the P30/P31 are being driven by software and the USB isn't plugged in.
The board already has 2 switchmode power supplies, your main power supply you are feeding it with is underpowered. Adding regulators won't fix that problem.
You need a battery (what it was designed for) or a beefy 6v power supply.
Like I said above, you need around a 10A surge capacity at 6V for the board and servos to work correctly. You should be using AT MINIMUM a 6v/3A power supply, and that won't be enough if you move a lot of servos at once.
Granted. That may be a bit of over-kill.
Another possible way to go would be run the servos directly from a 6 volt source (but make it a much bigger source)
and run the Propeller from a DIFFERENT source.
If this is to be battery operated, use separate batteries?
