Question about the new Wild Thumper Bot
NWCCTV
If there are 6 motors for this Bot, how are they all being controlled using only 2 HB-25 motor controllers?
Let's say I have three motors, driven in parallel, all facing the same mechanical load, driven by a single DC supply. Current gets shared between the three, they all do their part and life is good.
But now, I stall one motor with an extreme load. It's stall current goes through the roof. The others have no drive anymore.
Does not sound good. Like thermal runaway in parallel transistor circuits.
I guess that implies that the stalled motor takes all the available current, which may or may not be the case. For example, say a DC motor has a stall current of 500mA at 12volts. In that case, with an HB25 (and an adequate supply), stalled motor would be getting 500mA at 12volts. The other (non-stalled) motors would have 12volts on their terminals, and draw whatever current they need.
The problem comes when a motor draws more current than the supply can give. In that case, the supply would turn to constant current (instead of constant voltage) and the voltage would drop until the system is in equilibrium. Even in that case, the other motors would have some voltage across their terminals.
