Invert Servo32v7 Driver output (Assembly Language) — Parallax Forums
courtenscourtens Posts: 101
edited 2013-05-09 20:19 in Propeller 1
I am stuck trying to invert the output of the driver Servo32v7.
All works well without going through the 7404N inverter chip; but would like to us the chip --- I am having some very high power discharge in a somewhat close proximity of the servos wire which is messing up my signal to the servo. I am hoping this would help.
Looking at the driver code, could it be that I would needs to change this line from 1 to 0? This is the line
ZoneShift1              res     1
I decided to past the driver code here as the Object Exchange Site is undergoing some maintenance.
* Servo32v7 Driver                   v7 *
* Author: Beau Schwabe                  *
* Copyright (c) 2009 Parallax           *
* See end of file for terms of use.     *
 Control up to 32-Servos      Version 7               08-18-2009
 Coded by Beau Schwabe (Parallax).
 History:
                            Version 1 -               initial concept
                            Version 2 - (03-08-2006)  Beta release
                            Version 3 - (11-04-2007)  Improved servo resolution to 1uS
                            Version 4 - (05-03-2009)  Ability to disable a servo channel
                                                      and remove channel preset requirement
                            Version 5 - (05-08-2009)  Added ramping ability
                            Version 6 - (07-18-2009)  Fixed slight timing skew in ZoneLoop and
                                                      fixed overhead timing latency in ZoneCore
                            Version 7 - (08-18-2009)  Fixed servo jitter in ramping function when
                                                      servo reached it's target position.
Theory of Operation:
Each servo requires a pulse that varies from 1mS to 2mS with a period of 20mS.
To prevent a current surge nightmare, I have broken the 20mS period into four
groups or Zones of 8 servos each with a period of 5mS. What this does, is to
ensure that at any given moment in time, a maximum of only 8 servos are receiving
a pulse.
   Zone1 Zone2 Zone3    Zone4          In Zone1, servo pins  0- 7 are active
           In Zone2, servo pins  8-15 are active
  │─5mS│─5mS│─5mS│─5mS│        In Zone3, servo pins 16-23 are active
  │──────────20mS───────────│        In Zone4, servo pins 24-31 are active
    1-2mS servo pulse 
The preferred circuit of choice is to place a 4.7K resistor on each signal input
to the servo.    If long leads are used, place a 1000uF cap at the servo power
connector.    Servo's seem to be happy with a 5V supply receiving a 3.3V signal.
CON
    _1uS = 1_000_000 /        1                                                 'Divisor for 1 uS
    ZonePeriod = 5_000                                                          '5mS (1/4th of typical servo period of 20mS)
    NoGlitchWindow = 3_000                                                      '3mS Glitch prevention window (set value larger than maximum servo width of 2.5mS)
        'Use at least 500uS for overhead (actual overhead about 300uS)
     LowRange = 500             '<- during Debug I changed this value to 1 to test 1us resolution
    HighRange = 2500
VAR
        long          RampFlag
        long          ZoneClocks
        long          NoGlitch
        long          ServoPinDirection
        long          ServoData[32]                                             '0-31 Current Servo Value
        long          ServoTarget[32]                                           '0-31 Desired Servo Value
        long          ServoDelay[32]                                            '0-31 Servo Ramp Delay
OBJ
SERVO           : "Servo32_Ramp_v2"
PUB Start
    RampFlag := 0
    ZoneClocks := (clkfreq / _1uS * ZonePeriod)                                 'calculate # of clocks per ZonePeriod
    NoGlitch   := $FFFF_FFFF-(clkfreq / _1uS * NoGlitchWindow)                  'calculate # of clocks for GlitchFree servos. Problem occurs when 'cnt' value rollover is less than the servo's pulse width.
    cognew(@ServoStart,@ZoneClocks)
PUB Ramp
    SERVO.StartRamp(@ServoData)
    RampFlag := 1
PUB SetRamp(Pin, Width,Delay)|S_Width
      ServoDelay[Pin] := Delay 'Note: The resolution of Delay is about 38.75us
                               '      or 3100 clocks
      S_Width := LowRange #> Width <# HighRange                                 'limit Width value
      Pin :=    0 #> Pin <# 31                                                  'limit Pin value between 0 and 31
      ServoTarget[Pin] := ((clkfreq / _1uS * S_Width)/SERVO#CoreSpeed)*SERVO#CoreSpeed
        'calculate # of clocks for a specific Pulse Width
        'and adjust the snap value to match the value of
        'CoreSpeed. (Note: this prevents jitter when Servo
        '                  has reached it's target position)
      if S_Width==Width
         dira[Pin] := 1                                                         'set selected servo pin as an OUTPUT
      else
         dira[Pin] := 0                                                         'set selected servo pin as an INPUT only if Width out of range
      ServoPinDirection := dira                                                 'Read I/O state of ALL pins
PUB Set(Pin, Width)|S_Width                                                     'Set Servo value
      if RampFlag == 0
         ServoData[Pin] := (clkfreq / _1uS * S_Width)                           'calculate # of clocks for a specific Pulse Width
      else
         ServoData[Pin] := ((clkfreq / _1uS * S_Width)/SERVO#CoreSpeed)*SERVO#CoreSpeed
      ServoTarget[Pin] := ServoData[Pin]
      if S_Width==Width
      else
DAT
'* Assembly language *
                        org
ServoStart              mov     Index,                  par                     'Set Index Pointer
                        rdlong  _ZoneClocks,            Index                   'Get ZoneClock value
                        add     Index,                  #4                      'Increment Index to next Pointer
                        rdlong  _NoGlitch,              Index                   'Get NoGlitch value
                        mov     PinDirectionAddress,    Index                   'Set pointer for I/O direction Address
                        add     Index,                  #32                     'Increment Index to END of Zone1 Pointer
                        mov     Zone1Index,             Index                   'Set Index Pointer for Zone1
                        add     Index,                  #32                     'Increment Index to END of Zone2 Pointer
                        mov     Zone2Index,             Index                   'Set Index Pointer for Zone2
                        add     Index,                  #32                     'Increment Index to END of Zone3 Pointer
                        mov     Zone3Index,             Index                   'Set Index Pointer for Zone3
                        add     Index,                  #32                     'Increment Index to END of Zone4 Pointer
                        mov     Zone4Index,             Index                   'Set Index Pointer for Zone4
IOupdate                rdlong  dira,                   PinDirectionAddress     'Get and set I/O pin directions
Zone1                   mov     ZoneIndex,              Zone1Index              'Set Index Pointer for Zone1
                        call    #ResetZone
                        call    #ZoneCore
Zone2                   mov     ZoneIndex,              Zone2Index              'Set Index Pointer for Zone2
                        call    #IncrementZone
                        call    #ZoneCore
Zone3                   mov     ZoneIndex,              Zone3Index              'Set Index Pointer for Zone3
                        call    #IncrementZone
                        call    #ZoneCore
Zone4                   mov     ZoneIndex,              Zone4Index              'Set Index Pointer for Zone4
                        call    #IncrementZone
                        call    #ZoneCore
                        jmp     #IOupdate
ResetZone               mov     ZoneShift1,             #1
                        mov     ZoneShift2,             #2
                        mov     ZoneShift3,             #4
                        mov     ZoneShift4,             #8
                        mov     ZoneShift5,             #16
                        mov     ZoneShift6,             #32
                        mov     ZoneShift7,             #64
                        mov     ZoneShift8,             #128
ResetZone_RET           ret
IncrementZone           shl     ZoneShift1,             #8
                        shl     ZoneShift2,             #8
                        shl     ZoneShift3,             #8
                        shl     ZoneShift4,             #8
                        shl     ZoneShift5,             #8
                        shl     ZoneShift6,             #8
                        shl     ZoneShift7,             #8
                        shl     ZoneShift8,             #8
IncrementZone_RET       ret
ZoneCore                mov     ServoByte,              #0                      'Clear ServoByte
                        mov     Index,                  ZoneIndex               'Set Index Pointer for proper Zone
ZoneSync                mov     SyncPoint,              cnt                     'Create a Sync Point with the system counter
'                       mov     temp,                   _NoGlitch
'                       sub     temp,                   SyncPoint            wc
                        sub     _NoGlitch,              SyncPoint         nr,wc 'Test to make sure 'cnt' value won't rollover within Servo's pulse width
              if_C      jmp     #ZoneSync                                       'If C flag is set get a new Sync Point, otherwise we are ok.
'                       add     SyncPoint,              #220                    '<- Debug - 2us becomes 1us
'                       add     SyncPoint,              #300                    '<- Debug - 2us becomes 3us
                        add     SyncPoint,              #260                    'Add overhead offset to counter Sync point
        'midpoint from above Debug test.
                        mov     LoopCounter,            #8                      'Set Loop Counter to 8 Servos for this Zone
                        movd    LoadServos,             #ServoWidth8            'Restore/Set self-modifying code on "LoadServos" line
                        movd    ServoSync,              #ServoWidth8            'Restore/Set self-modifying code on "ServoSync" line
        LoadServos      rdlong  ServoWidth8,            Index                   'Get Servo Data
                        sub     Index,                  #4                      'Decrement Index pointer to next address
                        nop
        ServoSync       add     ServoWidth8,            SyncPoint               'Determine system counter location where pulse should end
                        sub     LoadServos,             d_field                 'self-modify destination pointer for "LoadServos" line
                        sub     ServoSync,              d_field                 'self-modify destination pointer for "ServoSync" line
                        djnz    LoopCounter,            #LoadServos             'Do ALL 8 servo positions for this Zone
                        mov     temp,                   _ZoneClocks             'Move _ZoneClocks into temp
                        add     temp,                   SyncPoint               'Add SyncPoint to _ZoneClocks
'----------------------------------------------Start Tight Servo code-------------------------------------------------------------
         ZoneLoop       mov     tempcnt,                cnt                     '(4 - clocks) take a snapshot of current counter value
                        cmpsub  ServoWidth1,            tempcnt       nr,wc     '(4 - clocks) compare system counter to ServoWidth ; write result in C flag
                        muxc    ServoByte,              ZoneShift1              '(4 - clocks) Set ServoByte.Bit0 to "0" or "1" depending on the value of "C"
                        cmpsub  ServoWidth2,            tempcnt       nr,wc     '(4 - clocks) compare system counter to ServoWidth ; write result in C flag
                        muxc    ServoByte,              ZoneShift2              '(4 - clocks) Set ServoByte.Bit1 to "0" or "1" depending on the value of "C"
                        cmpsub  ServoWidth3,            tempcnt       nr,wc     '(4 - clocks) compare system counter to ServoWidth ; write result in C flag
                        muxc    ServoByte,              ZoneShift3              '(4 - clocks) Set ServoByte.Bit2 to "0" or "1" depending on the value of "C"
                        cmpsub  ServoWidth4,            tempcnt       nr,wc     '(4 - clocks) compare system counter to ServoWidth ; write result in C flag
                        muxc    ServoByte,              ZoneShift4              '(4 - clocks) Set ServoByte.Bit3 to "0" or "1" depending on the value of "C"
                        cmpsub  ServoWidth5,            tempcnt       nr,wc     '(4 - clocks) compare system counter to ServoWidth ; write result in C flag
                        muxc    ServoByte,              ZoneShift5              '(4 - clocks) Set ServoByte.Bit4 to "0" or "1" depending on the value of "C"
                        cmpsub  ServoWidth6,            tempcnt       nr,wc     '(4 - clocks) compare system counter to ServoWidth ; write result in C flag
                        muxc    ServoByte,              ZoneShift6              '(4 - clocks) Set ServoByte.Bit5 to "0" or "1" depending on the value of "C"
                        cmpsub  ServoWidth7,            tempcnt       nr,wc     '(4 - clocks) compare system counter to ServoWidth ; write result in C flag
                        muxc    ServoByte,              ZoneShift7              '(4 - clocks) Set ServoByte.Bit6 to "0" or "1" depending on the value of "C"
                        cmpsub  ServoWidth8,            tempcnt       nr,wc     '(4 - clocks) compare system counter to ServoWidth ; write result in C flag
                        muxc    ServoByte,              ZoneShift8              '(4 - clocks) Set ServoByte.Bit7 to "0" or "1" depending on the value of "C"
                        mov     outa,                   ServoByte               '(4 - clocks) Send ServoByte to Zone Port
                        cmp     temp,                   tempcnt       nr,wc     '(4 - clocks) Determine if cnt has exceeded width of _ZoneClocks ; write result in C flag
              if_NC     jmp     #ZoneLoop                                       '(4 - clocks) if the "C Flag" is not set stay in the current Zone
'-----------------------------------------------End Tight Servo code--------------------------------------------------------------
'        Total = 80 - clocks  @ 80MHz that's 1uS resolution
 ZoneCore_RET            ret
d_field                 long    $0000_0200
PinDirectionAddress     long    0
counter                 long    0
Address1                long    0
Address2                long    0
Address3                long    0
temp1                   long    0
temp2                   long    0
tempcnt                 long    0
dly                     long    0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
ServoWidth1             res     1
ServoWidth2             res     1
ServoWidth3             res     1
ServoWidth4             res     1
ServoWidth5             res     1
ServoWidth6             res     1
ServoWidth7             res     1
ServoWidth8             res     1
ZoneShift1              res     1
ZoneShift2              res     1
ZoneShift3              res     1
ZoneShift4              res     1
ZoneShift5              res     1
ZoneShift6              res     1
ZoneShift7              res     1
ZoneShift8              res     1
temp                    res     1
Index                   res     1
ZoneIndex               res     1
Zone1Index              res     1
Zone2Index              res     1
Zone3Index              res     1
Zone4Index              res     1
SyncPoint               res     1
ServoByte               res     1
LoopCounter             res     1
_ZoneClocks             res     1
_NoGlitch               res     1
_ServoPinDirection      res     1
DAT
&#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;
&#9474;                                                   TERMS OF USE: MIT License                                                  &#9474;
&#9500;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9508;
&#9474;Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation    &#9474;
&#9474;files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy,    &#9474;
&#9474;modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software&#9474;
&#9474;is furnished to do so, subject to the following conditions:        &#9474;
&#9474;        &#9474;
&#9474;The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.&#9474;
&#9474;        &#9474;
&#9474;THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE          &#9474;
&#9474;WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR         &#9474;
&#9474;COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,   &#9474;
&#9474;ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.                         &#9474;
&#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;
    edited 2013-04-21 13:24
    Without testing it, I think all you need to do to invert the output is to change the lines that read ...
    muxc ServoByte
    ... so that they read ...
    muxnc ServoByte
    These lines are located directly after the "ZoneLoop" towards the end of the assembly program.
    Also, please update your driver to Servo32v9...
    http://forums.parallax.com/showthread.php/147219-CODE-UPDATE-Servo32v9?highlight=servo32v9
  • courtenscourtens Posts: 101
    edited 2013-04-21 14:30
    muxnc ServoByte
    Thank you Beau -- changing this in the code inverted the duration length, but not the I/O output.
    So in other words what used to be long is now short and what used to be short is now long. The high is still high, and the low is still low.
    Maybe I wasn't clear. What I am looking for is to invert the IO output so that high gets to be low and low turns into high.
    I was hoping the Bitwise NOT flag would work. As far as I understand the code this would invert the saved values ... (but this is not working.)
    mov     outa,                   !ServoByte
    edited 2013-04-21 22:53
    Using muxnc is only have the work. As the idle state for the other 3 zones (unaffected by ZoneLoop) is now inverted the initialisation for ServoByte has to change to:
    ZoneCore                neg     ServoByte,              #1                      'Set ServoByte to idle
    edited 2013-04-22 09:25
    kuroneko wrote: »
    Thank you kuroneko. I tried that, but it is not changing anything.
    I am new to Assembly Language and can't find what keeps the ON - ON and the OFF - OFF
    I assume this is saved in 0 and 1 values within registers -- values that are being called upon.
    I tried adding this line; but that just creates chaos:
    ZoneLoop ...
                            andn    ServoByteInvert,        ServoByte             '<< new
                            mov     outa,                   ServoByteInvert         '(4 - clocks) Send ServoByte to Zone Port
    edited 2013-04-22 11:40
    Using a 7407 instead of a 7404 might be simpler. It is a non inverting buffer with the same pinout as the 7404.
    edited 2013-04-22 11:46
    kwinn wrote: »
    Very nice!
    I like the way you're thinking -- out of the box!
    This is what I'll do.
    :smile:
    edited 2013-04-22 12:26
    Either way...
    The lines that I had originally said to change from muxc to muxnc still need to be changed in addition to one more line.
    The line that reads ...
    ...should be changed to....
    ZoneCore mov ServoByte, #%11111111 <-- EDIT: Don't use this
    edited 2013-04-22 13:27
    Either way...
    ZoneCore mov ServoByte, #111111
    Beau -- Thank you for taking the time to upload this new inverted version. I tried it, but somehow it is still not working. Did it work for you?
    edited 2013-04-22 13:35
    I checked it on a digital scope, the output should be correct.
    EDIT: I just tested it with the attached circuit using the inverted servo driver and the servo worked just fine.
    571 x 421 - 62K
    edited 2013-04-22 16:00
    very strange ...
    I tested your suggested code only using one servo (at first) -- then with 2 servos. They are "parallax standard servos." Your suggested code is somehow not working, for me.
    Here are two images from my scope. Both readings are straight from the propeller pin -- none are going through an inverter.
    This is the image of the non-inverting code (v7), which works -- but it is not inverted.
    And this is the new driver that isn't working (servo is not moving) and it is also not inverted.
    775 x 587 - 199K
    776 x 591 - 202K
    edited 2013-04-22 16:53
    How does that work with zones 1..3? I mean while you run through ZoneLoop you'd have to keep the other outputs idle (i.e. high). IOW the above code only works for zone 0. Therefore my earlier [post=1178980]suggestion[/post] of using a neg ServoByte, #1.
    edited 2013-04-23 10:25
    courtens wrote: »
    Very nice!
    :smile:
    Thanks for the compliment. Not really "out of the box" thinking, just a preference for simplicity. After all if you need a buffer it may as well be one that provides the output polarity you need, and most of the 74xx series logic had inverting and non inverting versions of each chip.
    edited 2013-04-23 12:29
    kuroneko's suggestion in post #4 is correct...
    Change "Zonecore" so that it reads "ZoneCore neg ServoByte, #1" and all four zones will work correctly.
    Updated code in post #8
    edited 2013-04-23 14:07
    Very nice -- thank you ALL sooo much! It is working. :smile:
    edited 2013-05-09 17:40
    Today I used the inverted driver on a different QuickStart board. I have a lot of code going on there ... but had to discover that the inverted driver is not working properly. It flips "ON" other I/O's that I do not even address ... most strange. Going back to the old none-inverted code worked.
    edited 2013-05-09 18:03
    courtens wrote: »
    FWIW, the PASM part only drives pins you tell it to (rdlong dira, PinDirectionAddress). And that's the only source for the directions. Could it be that something is overwriting memory, specifically this location (you wouldn't notice this effect with the non-inverted driver)? To test this add something like this to the driver:
    IOupdate        rdlong  dira, PinDirectionAddress       ' Get and set I/O pin directions
                    [COLOR="#FFA500"]test    invalid, dira wz[/COLOR]                ' check for invalid bits
           [COLOR="#FFA500"] if_nz   hubop   $, #128[/COLOR]                         ' reset
    [COLOR="#FFA500"]invalid         long    $00000003[/COLOR]                       ' contains a 1 at invalid bit locations (here 0 and 1)
    If a reset is too extreme simply stop there (waitpeq $, #0) and/or light an LED.
    Another way to populate dira with invalid bits is due to the way the SPIN interface is written. It uses dira of the caller and adds/removes the servo pins. Which means bits set by the caller (non-servo) are also communicated to the PASM driver. Quick fix:
                                   '      or 3100 clocks
         [COLOR="#FFA500"] if S_Width==Width
             ServoPinDirection |=  |< Pin                                           'set selected servo pin as an OUTPUT
          else
             ServoPinDirection &= !|< Pin                                           'set selected servo pin as an INPUT only if Width out of range
    [/COLOR]
          if RampFlag == 0
          else
          else
             ServoPinDirection &= !|< Pin                                           'set selected servo pin as an INPUT only if Width out of range [/COLOR]
    This never came up with the non-inverted driver because unused outputs (enabled or not) are kept on idle (low). That said, the caller could subsequently clear its dira assignment (as it owns it) which would affect previously set servo pins during the next Set* call. So this needs to be fixed in either version.
