SD library in C
DavidZemon
I am trying to write an SD library using my generic SPI library and it isn't going well. Most of the time, I get 0x01 from CMD0, but I have yet to get anything other than 0xff or 0x7f as the first byte from CMD8. I've tried referencing fsrw and safe_spi but, as far as I can tell, I'm doing the same thing.
What could cause me to receive 0x01 from CMD0 followed by an invalid response from CMD8?
Code can be found here and the relevant files are SD_Driver.*, sd.*, and maybe spi* but I believe the SPI library is working.
https://github.com/SwimDude0614/PropWare
David
David
Anyway, CMD9 is responding with 0x01 as the first byte... it's idle. Why? The only issue I'm noticing is that there's a weird hickup in MISO a little before the half-way point of the argument.
After I receive 0x01 as the first byte, an error is thrown and the program quits. I commented out that debug line once and only ever received 0xff following the idle response , making me think that the 0x01 response is not a fluke - it truly is in the idle state.
A snapshot of only CMD9 can be found here, and the complete file (type VCD) can be found here.
(Sorry chip select isn't there. I only have two probes at the moment and had to use a jumper wire just to get the third signal. Two more probes have been ordered...)
Also, I guess I forgot to update this thread - I changed the git repository completely and reorganized. The new link is here and in the first post.
I would be interested in the opinions of some other developers on a specific question though. One of the things I like about C/C++ is header files, and how perfect they are for documentation. I like having pre-processor definitions, function prototypes (and function docs) and various other things in the header because it creates a separation that allows for each searching/finding. However, I was recently introduced to the idea of "private" functions in C by placing the prototypes in the source file (as opposed to header) which imply that those functions are therefore inaccessible from other files. Seemed brilliant and I have used this method for PropWare so far. The bad news though, is that it has destroyed some of the readability and searchability of my code. For instance, the first executable line of sd.c is line 250+; past definitions, global variable declarations and function documentation/prototypes.
What would you suggest I do? Forget about having "private" functions? Accept the decrease in readability and leave it as is? Create a second header file for private information? Another option?
You might also want to use some naming convention for you public interfaces like prefixing all function names. for exaample:
int SDSD_mount(....):
Then we all know this function belongs to SwimDudes SD library and is less likely to conflict with other libraries we might use.
You will only need prototypes for some very few special cases:
a) Recursive functions
b) Functions calling each other (this is pretty rare)
So, for your 'top down' coding, start by implementing the 'top' function, then keep placing the more detailed functions above that one in the source file.
And obviously this will lead to 'main()' being at the bottom of the file, which is why you see that so often.
My files generally look as follows:
Include statements for system header files
Include statements for other, non-system header files (e.g. my other libraries)
Include statements for local header files (these will typically have prototypes for my non-static functions)
static variables, if any
static functions (i.e. private to this file), nicely sorted so that they self-prototype.
public functions, and prototypes for these are in one of the local header file(s) included above
(The reason I call it 'self-prototyping' is that the compiler will check the parameters just as if you had actual prototypes. Just like a Pascal compiler would, as Pascal programs are generally laid out the same way, with the callee function above the caller function).
-Tor
-Tor
But wait a minute, if you have all your functions defined in your C file before they are used (a good idea) why have any static function declarations in you header either?
It's a contradiction, the header file says "look I have these functions" and the "static" says "but you are not allowed to use them.
Things get a bit more complex if you library is big enough to warrant living in multiple C files. Then you might want a second header file declaring all the private functions that are shared between files and cannot be static.
The only items I put in header files are prototypes for public functions (and I slap an 'extern' on them too), and #defines for constants and macros.
And if I used global variables (which I don't) they would be declared as'extern int glob_var;' in a header file. If I used global variables.. which I don't.
-Tor
"For external declarations the default storage class specifier will be extern and for internal declarations it will be auto. The only exception to this rule is the declaration of functions, whose default storage class specifier is always extern." http://publications.gbdirect.co.uk/c_book/chapter8/declarations_and_definitions.html
"Internal" library functions (shared between functions in the library, but not with the user of the library) I obviously declare in header files, the difference between these header files and the "public" header files is that my 'make install' target won't copy those header files into the public
'include/ ' directory. So they stay in the directory/directories where the library source is, they'll never migrate to /usr/include/ or the equivalent place on whatever target it is.
Of course C has this slightly weak spot that these non-public, but non-static functions are still visible in the global namespace.. and could be accessed by someone using the library even though they are meant for library-internal use. The user would be without the prototypes and would have to figure out how to use the functions (and maybe writing their own protoptypes). And, seen from the library writer point of view, you should think about namespace pollution and not give function names that may collide with something else to your internal, but non-static functions. Don't call them sort() or compare(), for example.. better use e.g. tf_lib_internal_sort() or something.
-Tor
(sorry about a couple of spurious line shifts in the above, the forum software sometimes won't let me delete empty lines when I'm in the Android browser)
-Tor
I like the idea of static functions. It was not something I was previously aware of. Also, as I mentioned earlier, I like the idea of documentation for functions staying in the header file(s) and, for that, it makes sense to have prototypes in the headers. Results: I've done as Heater first suggested and moved definitions and prototypes to the header file, at the bottom, with functions be preceded by the static keyword. (Thankfully, I was already aware of the static keyword for variables.)
I also began the implementation of SPIShiftIn_fast and *Out_fast. I like how fsrw and SD_MMC_FATEngine use the counter module, so that's my end goal. For now, I've simply created routines that do not call another asm function to clock out, but rather call "xor" twice in a row.
Also, any way a moderator could change the thread title to "PropWare - Generic C library files"?
Unfortunately... it's extremely slow. With all debugging turned off and using my SPIShiftIn_fast routine, it took many minutes (I didn't time it, but I think ~5) to read an 8 MB mp3 file. When I have time, SPI speed will be the first thing I optimize. Specifically, an entire GAS routine that reads a block and writes it to HUB memory one long at a time.
I've also recorded the code size of the SD demo with various options enabled/disabled. Here are the results:
I'm not entirely happy with this. It wasn't but a couple days ago that, without any options enabled, CMM mode was around 5k. This also does not include write functionality, and I know that's going to add a significant chunk of code.
Now I have two big things I'd like to fix when I'm done with the necessary functions: 1) read/write speed, 2) code size.
This most recent update has added a few new functions: SDfputc, SDfputs, SDftellw, SDftellr, SDfseekw, and SDfseekr. The tell* and seek* are for the independent read and write pointers. I know that isn't quite POSIX standard, but until I'm done with senior design (it's more useful to me this way), that's how it's going to stay.
I also found a stupid mistake in my option definitions and the code size has been updated below to reflect it (namely, the shell is a lot smaller) :
I wasn't planning on doing this for my project but an overall simplification required that I be able to append to and create new files.
I'll update with code sizes later... it's grown quite a bit. Good news is, if you don't need to write to files, you can disable that option and the code size should remain very similar to the numbers listed in my previous post.
As always, code available here: https://github.com/SwimDude0614/PropWare
1) I'm starting the implementation of Doxygen for PropWare. Current progress (based on the master branch of the git repo) can be found here: http://david.zemon.name/professional/PropWare/docs/html/
2) I realized the stupidity of my ways and am now compiling PropWare into a static library. Progress on this has been moved to the development branch (https://github.com/SwimDude0614/PropWare/tree/development)
When I attempt to build the SPI demo, I get undefined reference errors. Does anyone know why? I'll post full output from the library compilation in a reply to this post.
Now the linker can't find my assembly (spi_as.S).
To get "__load_start_spi_as_cog" it seems that you need this: .section .spi_as_cog, "ax"
Add -Xlinker -MAP=map_file to your gcc line so you can see all symbols in map_file.
SimpleIDE has a "Show Map File" command that does this for us.
Symbols like __load_start_* are always at the end of the map file.
I'm not 100% sure what your suggestion was with the map file, but I added the arguments to the linker flags and here's the output now when I attempt to build SPI_Demo.elf. The output when building the library hasn't changed (because it's not running the linker)
Building file: ../SPI_Demo.cInvoking: PropGCC Compiler /opt/parallax/bin/propeller-elf-gcc -I../../.. -I/opt/parallax/propeller-elf/include -Os -mlmm -Wall -o SPI_Demo.o -c ../SPI_Demo.c ../SPI_Demo.c:10:16: warning: return type of 'main' is not 'int' [-Wmain] ../../../spi.h:275:23: warning: 'SPIReadPar' declared 'static' but never defined [-Wunused-function] ../../../spi.h:284:16: warning: 'SPICountBits' declared 'static' but never defined [-Wunused-function] ../../../spi.h:297:16: warning: 'SPIGetPinNum' declared 'static' but never defined [-Wunused-function] Finished building: ../SPI_Demo.c Building target: SPI_Demo.elf Invoking: PropGCC Linker /opt/parallax/bin/propeller-elf-gcc -mlmm -fno-exceptions -fno-rtti -Xlinker -MAP=map_file -L/opt/parallax/propeller-elf/lib -L../../../Debug -o SPI_Demo.elf SPI_Demo.o -lPropWare Archive member included because of file (symbol) ../../../Debug/libPropWare.a(spi.o) SPI_Demo.o (_SPIWait) ../../../Debug/libPropWare.a(PropWare.o) ../../../Debug/libPropWare.a(spi.o) (_PropWareCountBits) /opt/parallax/propeller-elf/lib/libc.a(fputc.o) SPI_Demo.o (_fputc) /opt/parallax/propeller-elf/lib/libc.a(fopen_intern.o) SPI_Demo.o (___files) /opt/parallax/propeller-elf/lib/libc.a(default_io.o) /opt/parallax/propeller-elf/lib/libc.a(fopen_intern.o) (__driverlist) /opt/parallax/propeller-elf/lib/libc.a(init_io.o) /opt/parallax/propeller-elf/lib/libc.a(fopen_intern.o) (__InitIO) /opt/parallax/propeller-elf/lib/libc.a(thread.o) /opt/parallax/lib/gcc/propeller-elf/4.6.1/_crt0.o (__TLS) /opt/parallax/propeller-elf/lib/libc.a(memcpy.o) SPI_Demo.o (_memcpy) /opt/parallax/propeller-elf/lib/libc.a(memset.o) /opt/parallax/lib/gcc/propeller-elf/4.6.1/_crtbegin.o (_memset) /opt/parallax/propeller-elf/lib/libc.a(SimpleSerial.o) /opt/parallax/propeller-elf/lib/libc.a(default_io.o) (__SimpleSerialDriver) /opt/parallax/propeller-elf/lib/libc.a(serialparam.o) /opt/parallax/propeller-elf/lib/libc.a(SimpleSerial.o) (__baud) /opt/parallax/propeller-elf/lib/libc.a(terminal.o) /opt/parallax/propeller-elf/lib/libc.a(SimpleSerial.o) (__term_write) /opt/parallax/propeller-elf/lib/libc.a(fflush.o) /opt/parallax/propeller-elf/lib/libc.a(fopen_intern.o) (_fflush) /opt/parallax/propeller-elf/lib/libc.a(atoi.o) /opt/parallax/propeller-elf/lib/libc.a(SimpleSerial.o) (_atoi) /opt/parallax/propeller-elf/lib/libc.a(ctype.o) /opt/parallax/propeller-elf/lib/libc.a(atoi.o) (___ctype) Allocating common symbols Common symbol size file ___stdio_lock 0x4 /opt/parallax/propeller-elf/lib/libc.a(fopen_intern.o) _(float, int, long,...)(short) 0x1a0 /opt/parallax/propeller-elf/lib/libc.a(fopen_intern.o) Memory Configuration Name Origin Length Attributes hub 0x00000000 0x00008000 cog 0x00000000 0x000007c0 coguser 0x00000000 0x000007c0 ram 0x20000000 0x10000000 rom 0x30000000 0x10000000 drivers 0xc0000000 0x00100000 dummy 0xe0000000 0x00100000 *default* 0x00000000 0xffffffff Linker script and memory map LOAD /opt/parallax/lib/gcc/propeller-elf/4.6.1/spinboot.o LOAD /opt/parallax/lib/gcc/propeller-elf/4.6.1/_crt0.o LOAD /opt/parallax/lib/gcc/propeller-elf/4.6.1/_crtbegin.o LOAD SPI_Demo.o LOAD ../../../Debug/libPropWare.a LOAD /opt/parallax/lib/gcc/propeller-elf/4.6.1/libgcc.a START GROUP LOAD /opt/parallax/propeller-elf/lib/libc.a LOAD /opt/parallax/lib/gcc/propeller-elf/4.6.1/libgcc.a END GROUP LOAD /opt/parallax/lib/gcc/propeller-elf/4.6.1/libgcc.a LOAD /opt/parallax/lib/gcc/propeller-elf/4.6.1/_crtend.o .boot 0x00000000 0x20 *(.boot) .boot 0x00000000 0x20 /opt/parallax/lib/gcc/propeller-elf/4.6.1/spinboot.o 0x00000000 __clkfreq 0x00000004 __clkmode 0x00000008 __sys_mbox .lmmkernel 0x00000000 0x794 load address 0x00000020 *(.lmmkernel) .lmmkernel 0x00000000 0x790 /opt/parallax/lib/gcc/propeller-elf/4.6.1/_crt0.o 0x00000000 __LMM_entry 0x00000000 r0 0x00000004 r1 0x00000008 r2 0x0000000c r3 0x00000010 r4 0x00000014 r5 0x00000018 r6 0x0000001c r7 0x00000020 r8 0x00000024 r9 0x00000028 r10 0x0000002c r11 0x00000030 r12 0x00000034 r13 0x00000038 r14 0x0000003c lr 0x00000040 sp 0x00000044 pc 0x000000ac __LMM_MVI_r0 0x000000b8 __LMM_MVI_r1 0x000000c4 __LMM_MVI_r2 0x000000d0 __LMM_MVI_r3 0x000000dc __LMM_MVI_r4 0x000000e8 __LMM_MVI_r5 0x000000f4 __LMM_MVI_r6 0x00000100 __LMM_MVI_r7 0x0000010c __LMM_MVI_r8 0x00000118 __LMM_MVI_r9 0x00000124 __LMM_MVI_r10 0x00000130 __LMM_MVI_r11 0x0000013c __LMM_MVI_r12 0x00000148 __LMM_MVI_r13 0x00000154 __LMM_MVI_r14 0x00000160 __LMM_MVI_lr 0x0000016c __LMM_CALL 0x00000174 __LMM_CALL_INDIRECT 0x00000180 __LMM_JMP 0x00000188 __LMM_PUSHM 0x000001a8 __LMM_PUSHM_ret 0x000001b0 __LMM_POPRET 0x000001b8 __LMM_POPRET_ret 0x000001bc __LMM_POPM 0x000001dc __LMM_POPM_ret 0x000001e0 __MASK_0000FFFF 0x000001e4 __MASK_FFFFFFFF 0x000001e8 __TMP0 0x000001fc __CLZSI 0x00000200 __CTZSI 0x00000238 __CLZSI_ret 0x00000244 __UDIVSI 0x00000288 __UDIVSI_ret 0x00000290 __DIVSI 0x000002b8 __DIVSI_ret 0x000002c8 __MULSI 0x000002e8 __MULSI_ret 0x000002ec __C_LOCK_PTR 0x000002f0 __CMPSWAPSI 0x00000310 __CMPSWAPSI_ret 0x0000031c __LMM_RET 0x00000320 __LMM_FCACHE_LOAD 0x00000390 __LMM_FCACHE_START *(.kernel) .kernel 0x00000790 0x4 /opt/parallax/propeller-elf/lib/libc.a(thread.o) 0x00000790 __TLS .init 0x000007b4 0xb8 *(.init*) .init 0x000007b4 0xa0 /opt/parallax/lib/gcc/propeller-elf/4.6.1/_crtbegin.o 0x000007b4 entry 0x000007b4 start 0x000007fc ___init .init 0x00000854 0x18 /opt/parallax/lib/gcc/propeller-elf/4.6.1/_crtend.o .text 0x0000086c 0x1084 *(.text*) .text 0x0000086c 0x0 /opt/parallax/lib/gcc/propeller-elf/4.6.1/spinboot.o .text 0x0000086c 0x0 /opt/parallax/lib/gcc/propeller-elf/4.6.1/_crt0.o .text 0x0000086c 0x0 /opt/parallax/lib/gcc/propeller-elf/4.6.1/_crtbegin.o .text 0x0000086c 0x15c SPI_Demo.o 0x0000086c _main .text 0x000009c8 0x414 ../../../Debug/libPropWare.a(spi.o) 0x00000a26 _SPIStop 0x00000a48 _SPIIsRunning 0x00000a5c _SPIWait 0x00000a8c _SPIWaitSpecific 0x00000abf _SPISetMode 0x00000af5 _SPISetBitMode 0x00000b31 _SPISetClock 0x00000b76 _SPIStart 0x00000c79 _SPIGetClock 0x00000cba _SPIShiftOut 0x00000cf5 _SPIShiftIn 0x00000d48 _SPIShiftOut_fast 0x00000d68 _SPIShiftIn_fast 0x00000dbd _SPIShiftIn_sector .text 0x00000ddc 0x6c ../../../Debug/libPropWare.a(PropWare.o) 0x00000ddc _GPIOSwitchRead_Low 0x00000e1a _PropWareCountBits 0x00000e2e _PropWareGetPinNum .text 0x00000e48 0x100 /opt/parallax/propeller-elf/lib/libc.a(fputc.o) 0x00000e48 _fputc .text 0x00000f48 0x2f0 /opt/parallax/propeller-elf/lib/libc.a(fopen_intern.o) 0x00000f48 ___fopen_driver 0x00001118 _fclose .text 0x00001238 0x0 /opt/parallax/propeller-elf/lib/libc.a(default_io.o) .text 0x00001238 0xc8 /opt/parallax/propeller-elf/lib/libc.a(init_io.o) 0x00001238 __InitIO .text 0x00001300 0x4 /opt/parallax/propeller-elf/lib/libc.a(thread.o) .text 0x00001304 0x80 /opt/parallax/propeller-elf/lib/libc.a(memcpy.o) 0x00001304 _memcpy .text 0x00001384 0x9c /opt/parallax/propeller-elf/lib/libc.a(memset.o) 0x00001384 _memset .text 0x00001420 0x280 /opt/parallax/propeller-elf/lib/libc.a(SimpleSerial.o) .text 0x000016a0 0x0 /opt/parallax/propeller-elf/lib/libc.a(serialparam.o) .text 0x000016a0 0x0 /opt/parallax/propeller-elf/lib/libc.a(terminal.o) .text 0x000016a0 0x1ac /opt/parallax/propeller-elf/lib/libc.a(fflush.o) 0x000017f4 _fflush .text 0x0000184c 0xa4 /opt/parallax/propeller-elf/lib/libc.a(atoi.o) 0x0000184c _atoi 0x0000184c _atol .text 0x000018f0 0x0 /opt/parallax/propeller-elf/lib/libc.a(ctype.o) .text 0x000018f0 0x0 /opt/parallax/lib/gcc/propeller-elf/4.6.1/_crtend.o 0x000018f0 _etext = . .fini 0x000018f0 0x3c *(.fini*) .fini 0x000018f0 0x28 /opt/parallax/lib/gcc/propeller-elf/4.6.1/_crtbegin.o 0x000018f0 _exit .fini 0x00001918 0x14 /opt/parallax/lib/gcc/propeller-elf/4.6.1/_crtend.o 0x0000191c __exit 0x0000191c __Exit 0x00001928 __ExitHook .hub 0x0000192c 0x330 *(.hubstart) *(.hubtext*) .hubtext 0x0000192c 0x23c /opt/parallax/propeller-elf/lib/libc.a(terminal.o) 0x0000192c __term_write 0x000019b8 __term_read *(.hubdata*) *(.hub) *(.data) .data 0x00001b68 0x0 /opt/parallax/lib/gcc/propeller-elf/4.6.1/spinboot.o .data 0x00001b68 0x0 /opt/parallax/lib/gcc/propeller-elf/4.6.1/_crt0.o .data 0x00001b68 0x0 /opt/parallax/lib/gcc/propeller-elf/4.6.1/_crtbegin.o .data 0x00001b68 0x10 SPI_Demo.o .data 0x00001b78 0x8 ../../../Debug/libPropWare.a(spi.o) .data 0x00001b80 0x0 ../../../Debug/libPropWare.a(PropWare.o) .data 0x00001b80 0x0 /opt/parallax/propeller-elf/lib/libc.a(fputc.o) .data 0x00001b80 0x4 /opt/parallax/propeller-elf/lib/libc.a(fopen_intern.o) 0x00001b80 ___dummy .data 0x00001b84 0x8 /opt/parallax/propeller-elf/lib/libc.a(default_io.o) 0x00001b84 __driverlist .data 0x00001b8c 0xc /opt/parallax/propeller-elf/lib/libc.a(init_io.o) .data 0x00001b98 0x4 /opt/parallax/propeller-elf/lib/libc.a(thread.o) 0x00001b98 ___yield_ptr .data 0x00001b9c 0x0 /opt/parallax/propeller-elf/lib/libc.a(memcpy.o) .data 0x00001b9c 0x0 /opt/parallax/propeller-elf/lib/libc.a(memset.o) .data 0x00001b9c 0x2c /opt/parallax/propeller-elf/lib/libc.a(SimpleSerial.o) 0x00001b9c __SimpleSerialDriver 0x00001bc0 __SimpleSerialPrefix .data 0x00001bc8 0xc /opt/parallax/propeller-elf/lib/libc.a(serialparam.o) 0x00001bc8 __baud 0x00001bcc __txpin 0x00001bd0 __rxpin .data 0x00001bd4 0x0 /opt/parallax/propeller-elf/lib/libc.a(terminal.o) .data 0x00001bd4 0x0 /opt/parallax/propeller-elf/lib/libc.a(fflush.o) .data 0x00001bd4 0x0 /opt/parallax/propeller-elf/lib/libc.a(atoi.o) .data 0x00001bd4 0x84 /opt/parallax/propeller-elf/lib/libc.a(ctype.o) 0x00001bd4 ___ctype .data 0x00001c58 0x0 /opt/parallax/lib/gcc/propeller-elf/4.6.1/_crtend.o *(.data*) *(.rodata) *(.rodata*) *(.gnu.linkonce.d*) 0x00001c58 PROVIDE (__C_LOCK, .) 0x00001c58 0x4 LONG 0x0 .ctors 0x00001c5c 0x8 *(.ctors*) .ctors 0x00001c5c 0x4 /opt/parallax/propeller-elf/lib/libc.a(init_io.o) .ctors 0x00001c60 0x4 /opt/parallax/lib/gcc/propeller-elf/4.6.1/_crtend.o 0x00001c60 __environ 0x00001c60 __argv .dtors 0x00001c64 0xc *(.dtors*) .dtors 0x00001c64 0x4 /opt/parallax/propeller-elf/lib/libc.a(fopen_intern.o) .dtors 0x00001c68 0x4 /opt/parallax/propeller-elf/lib/libc.a(SimpleSerial.o) .dtors 0x00001c6c 0x4 /opt/parallax/lib/gcc/propeller-elf/4.6.1/_crtend.o .data 0x00001c70 0x0 0x00001c70 . = ALIGN (0x4) .bss 0x00001c70 0x29c 0x00001c70 PROVIDE (__bss_start, .) *(.bss) .bss 0x00001c70 0x0 /opt/parallax/lib/gcc/propeller-elf/4.6.1/spinboot.o .bss 0x00001c70 0x0 /opt/parallax/lib/gcc/propeller-elf/4.6.1/_crt0.o .bss 0x00001c70 0x0 /opt/parallax/lib/gcc/propeller-elf/4.6.1/_crtbegin.o .bss 0x00001c70 0x0 SPI_Demo.o .bss 0x00001c70 0x0 ../../../Debug/libPropWare.a(spi.o) .bss 0x00001c70 0x0 ../../../Debug/libPropWare.a(PropWare.o) .bss 0x00001c70 0x0 /opt/parallax/propeller-elf/lib/libc.a(fputc.o) .bss 0x00001c70 0x0 /opt/parallax/propeller-elf/lib/libc.a(fopen_intern.o) .bss 0x00001c70 0x0 /opt/parallax/propeller-elf/lib/libc.a(default_io.o) .bss 0x00001c70 0x50 /opt/parallax/propeller-elf/lib/libc.a(init_io.o) .bss 0x00001cc0 0xa8 /opt/parallax/propeller-elf/lib/libc.a(thread.o) 0x00001cc0 ___napuntil_ptr .bss 0x00001d68 0x0 /opt/parallax/propeller-elf/lib/libc.a(memcpy.o) .bss 0x00001d68 0x0 /opt/parallax/propeller-elf/lib/libc.a(memset.o) .bss 0x00001d68 0x0 /opt/parallax/propeller-elf/lib/libc.a(SimpleSerial.o) .bss 0x00001d68 0x0 /opt/parallax/propeller-elf/lib/libc.a(serialparam.o) .bss 0x00001d68 0x0 /opt/parallax/propeller-elf/lib/libc.a(terminal.o) .bss 0x00001d68 0x0 /opt/parallax/propeller-elf/lib/libc.a(fflush.o) .bss 0x00001d68 0x0 /opt/parallax/propeller-elf/lib/libc.a(atoi.o) .bss 0x00001d68 0x0 /opt/parallax/propeller-elf/lib/libc.a(ctype.o) .bss 0x00001d68 0x0 /opt/parallax/lib/gcc/propeller-elf/4.6.1/_crtend.o *(.bss*) *(COMMON) COMMON 0x00001d68 0x1a4 /opt/parallax/propeller-elf/lib/libc.a(fopen_intern.o) 0x00001d68 ___stdio_lock 0x00001d6c ___files 0x00001f0c PROVIDE (__bss_end, .) .hub_heap 0x00001f0c 0x4 0x00001f10 . = (. + 0x4) *fill* 0x00001f0c 0x4 00 0x00001f0c ___hub_heap_start = ADDR (.hub_heap) .drivers *(.drivers) 0x00000020 __load_start_kernel = LOADADDR (.lmmkernel) 0x00001c5c ___CTOR_LIST__ = ADDR (.ctors) 0x00001c64 ___DTOR_LIST__ = ADDR (.dtors) .hash *(.hash) .dynsym *(.dynsym) .dynstr *(.dynstr) .gnu.version *(.gnu.version) .gnu.version_d *(.gnu.version_d) .gnu.version_r *(.gnu.version_r) .rel.init *(.rel.init) .rela.init *(.rela.init) .rel.text *(.rel.text) *(.rel.text.*) *(.rel.gnu.linkonce.t*) .rela.text *(.rela.text) *(.rela.text.*) *(.rela.gnu.linkonce.t*) .rel.fini *(.rel.fini) .rela.fini *(.rela.fini) .rel.rodata *(.rel.rodata) *(.rel.rodata.*) *(.rel.gnu.linkonce.r*) .rela.rodata *(.rela.rodata) *(.rela.rodata.*) *(.rela.gnu.linkonce.r*) .rel.data *(.rel.data) *(.rel.data.*) *(.rel.gnu.linkonce.d*) .rela.data *(.rela.data) *(.rela.data.*) *(.rela.gnu.linkonce.d*) .rel.ctors *(.rel.ctors) .rela.ctors *(.rela.ctors) .rel.dtors *(.rel.dtors) .rela.dtors *(.rela.dtors) .rel.got *(.rel.got) .rela.got *(.rela.got) .rel.bss *(.rel.bss) .rela.bss *(.rela.bss) .rel.plt *(.rel.plt) .rela.plt *(.rela.plt) .stab *(.stab) .stabstr *(.stabstr) .stab.excl *(.stab.excl) .stab.exclstr *(.stab.exclstr) .stab.index *(.stab.index) .stab.indexstr *(.stab.indexstr) .comment *(.comment) .debug *(.debug) .line *(.line) .debug_srcinfo *(.debug_srcinfo .zdebug_srcinfo) .debug_sfnames *(.debug_sfnames .zdebug_sfnames) .debug_aranges *(.debug_aranges .zdebug_aranges) .debug_pubnames *(.debug_pubnames .zdebug_pubnames) .debug_info *(.debug_info .gnu.linkonce.wi.* .zdebug_info) .debug_abbrev *(.debug_abbrev .zdebug_abbrev) .debug_line *(.debug_line .zdebug_line) .debug_frame *(.debug_frame .zdebug_frame) .debug_str *(.debug_str .zdebug_str) .debug_loc *(.debug_loc .zdebug_loc) .debug_macinfo *(.debug_macinfo .zdebug_macinfo) 0x000007c0 PROVIDE (par, PAR) 0x000007c4 PROVIDE (cnt, CNT) 0x000007c8 PROVIDE (ina, INA) 0x000007cc PROVIDE (inb, INB) 0x000007d0 PROVIDE (outa, OUTA) 0x000007d4 PROVIDE (outb, OUTB) 0x000007d8 PROVIDE (dira, DIRA) 0x000007dc PROVIDE (dirb, DIRB) 0x000007e0 PROVIDE (ctra, CTRA) 0x000007e4 PROVIDE (ctrb, CTRB) 0x000007e8 PROVIDE (frqa, FRQA) 0x000007ec PROVIDE (frqb, FRQB) 0x000007f0 PROVIDE (phsa, PHSA) 0x000007f4 PROVIDE (phsb, PHSB) 0x000007f8 PROVIDE (vcfg, VCFG) 0x000007fc PROVIDE (vscl, VSCL) 0x00001f1c PROVIDE (__hub_end, (ADDR (.hub_heap) + 0x10)) 0x00008000 PROVIDE (__stack_end, 0x8000) OUTPUT(SPI_Demo.elf elf32-propeller) ../../../Debug/libPropWare.a(spi.o): In function `_SPIStart': (.text+0x21a): undefined reference to `__load_start_spi_as_cog' collect2: ld returned 1 exit status make: *** [SPI_Demo.elf] Error 1(I've pushed the changes to common.mk and spi_as.S)
Memory Configuration Name Origin Length Attributes hub 0x00000000 0x00008000 cog 0x00000000 0x000007c0 coguser 0x00000000 0x000007c0 ram 0x20000000 0x10000000 rom 0x30000000 0x10000000 drivers 0xc0000000 0x00100000 dummy 0xe0000000 0x00100000 *default* 0x00000000 0xffffffff Linker script and memory map LOAD libPropWare.a .boot *(.boot) .lmmkernel 0x00000000 0x0 *(.lmmkernel) *(.kernel) .init *(.init*) .text 0x00000000 0x0 *(.text*) 0x00000000 _etext = . .fini *(.fini*) .hub 0x00000000 0x4 *(.hubstart) *(.hubtext*) *(.hubdata*) *(.hub) *(.data) *(.data*) *(.rodata) *(.rodata*) *(.gnu.linkonce.d*) 0x00000000 PROVIDE (__C_LOCK, .) 0x00000000 0x4 LONG 0x0 .ctors 0x00000004 0x0 *(.ctors*) .dtors 0x00000004 0x0 *(.dtors*) .data 0x00000004 0x0 0x00000004 . = ALIGN (0x4) .bss 0x00000004 0x0 0x00000004 PROVIDE (__bss_start, .) *(.bss) *(.bss*) *(COMMON) 0x00000004 PROVIDE (__bss_end, .) .hub_heap 0x00000004 0x4 0x00000008 . = (. + 0x4) *fill* 0x00000004 0x4 00 0x00000004 ___hub_heap_start = ADDR (.hub_heap) .drivers *(.drivers) 0x00000000 __load_start_kernel = LOADADDR (.lmmkernel) 0x00000004 ___CTOR_LIST__ = ADDR (.ctors) 0x00000004 ___DTOR_LIST__ = ADDR (.dtors) .hash *(.hash) .dynsym *(.dynsym) .dynstr *(.dynstr) .gnu.version *(.gnu.version) .gnu.version_d *(.gnu.version_d) .gnu.version_r *(.gnu.version_r) .rel.init *(.rel.init) .rela.init *(.rela.init) .rel.text *(.rel.text) *(.rel.text.*) *(.rel.gnu.linkonce.t*) .rela.text *(.rela.text) *(.rela.text.*) *(.rela.gnu.linkonce.t*) .rel.fini *(.rel.fini) .rela.fini *(.rela.fini) .rel.rodata *(.rel.rodata) *(.rel.rodata.*) *(.rel.gnu.linkonce.r*) .rela.rodata *(.rela.rodata) *(.rela.rodata.*) *(.rela.gnu.linkonce.r*) .rel.data *(.rel.data) *(.rel.data.*) *(.rel.gnu.linkonce.d*) .rela.data *(.rela.data) *(.rela.data.*) *(.rela.gnu.linkonce.d*) .rel.ctors *(.rel.ctors) .rela.ctors *(.rela.ctors) .rel.dtors *(.rel.dtors) .rela.dtors *(.rela.dtors) .rel.got *(.rel.got) .rela.got *(.rela.got) .rel.bss *(.rel.bss) .rela.bss *(.rela.bss) .rel.plt *(.rel.plt) .rela.plt *(.rela.plt) .stab *(.stab) .stabstr *(.stabstr) .stab.excl *(.stab.excl) .stab.exclstr *(.stab.exclstr) .stab.index *(.stab.index) .stab.indexstr *(.stab.indexstr) .comment *(.comment) .debug *(.debug) .line *(.line) .debug_srcinfo *(.debug_srcinfo .zdebug_srcinfo) .debug_sfnames *(.debug_sfnames .zdebug_sfnames) .debug_aranges *(.debug_aranges .zdebug_aranges) .debug_pubnames *(.debug_pubnames .zdebug_pubnames) .debug_info *(.debug_info .gnu.linkonce.wi.* .zdebug_info) .debug_abbrev *(.debug_abbrev .zdebug_abbrev) .debug_line *(.debug_line .zdebug_line) .debug_frame *(.debug_frame .zdebug_frame) .debug_str *(.debug_str .zdebug_str) .debug_loc *(.debug_loc .zdebug_loc) .debug_macinfo *(.debug_macinfo .zdebug_macinfo) built in linker script:193: undefined symbol `PAR' referenced in expressionI'm guessing that's where I *should* see "__load_start_spi_as_cog"?
I've done some renaming and it didn't help any. Here's the new map: And yet, it still complains
To make it work, I had to do this:
Change all #include <PropWare.h> and other local includes to use non-default library syntax as #include "PropWare.h"
Add a main to your PropWare.c file.
Change your make file to look like this:
# ######################################################### # Build Commands # ######################################################### ifneq ($(NAME),) $(NAME).elf: $(OBJS) @echo 'Building target: $@' @echo 'Invoking: PropGCC Linker' $(CC) $(LDFLAGS) $(LIB_INC) $(LIBS) -o $@ $(OBJS) $(CC) -Xlinker -Map=$(NAME).map $(LDFLAGS) $(LIB_INC) $(LIBS) -o $@ $(OBJS) @echo 'Finished building target: $@' @echo ' ' endifsh-3.1$ cat PropWare.map Archive member included because of file (symbol) c:/propgcc/propeller-elf/lib/cmm\libc.a(fputc.o) sd.o (_fputc) c:/propgcc/propeller-elf/lib/cmm\libc.a(puts.o) sd.o (_puts) c:/propgcc/propeller-elf/lib/cmm\libc.a(gets.o) sd.o (_gets) c:/propgcc/propeller-elf/lib/cmm\libc.a(fopen_intern.o) sd.o (_(float, int, long,...)(short)) c:/propgcc/propeller-elf/lib/cmm\libc.a(printf.o) sd.o (_printf) c:/propgcc/propeller-elf/lib/cmm\libc.a(default_io.o) c:/propgcc/propeller-elf/lib/cmm\libc.a(fopen_intern.o) (__driverlist) c:/propgcc/propeller-elf/lib/cmm\libc.a(init_io.o) c:/propgcc/propeller-elf/lib/cmm\libc.a(fopen_intern.o) (__InitIO) c:/propgcc/propeller-elf/lib/cmm\libc.a(thread.o) c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/_crt0.o (__TLS) c:/propgcc/propeller-elf/lib/cmm\libc.a(memset.o) c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/_crtbegin.o (_memset) c:/propgcc/propeller-elf/lib/cmm\libc.a(strcmp.o) sd.o (_strcmp) c:/propgcc/propeller-elf/lib/cmm\libc.a(SimpleSerial.o) c:/propgcc/propeller-elf/lib/cmm\libc.a(default_io.o) (__SimpleSerialDriver) c:/propgcc/propeller-elf/lib/cmm\libc.a(serialparam.o) c:/propgcc/propeller-elf/lib/cmm\libc.a(SimpleSerial.o) (__baud) c:/propgcc/propeller-elf/lib/cmm\libc.a(terminal.o) c:/propgcc/propeller-elf/lib/cmm\libc.a(SimpleSerial.o) (__term_write) c:/propgcc/propeller-elf/lib/cmm\libc.a(fflush.o) c:/propgcc/propeller-elf/lib/cmm\libc.a(fopen_intern.o) (_fflush) c:/propgcc/propeller-elf/lib/cmm\libc.a(fgetc.o) c:/propgcc/propeller-elf/lib/cmm\libc.a(gets.o) (_fgetc) c:/propgcc/propeller-elf/lib/cmm\libc.a(fputs.o) c:/propgcc/propeller-elf/lib/cmm\libc.a(puts.o) (___do_fputs) c:/propgcc/propeller-elf/lib/cmm\libc.a(vfprintf.o) c:/propgcc/propeller-elf/lib/cmm\libc.a(printf.o) (_vfprintf) c:/propgcc/propeller-elf/lib/cmm\libc.a(atoi.o) c:/propgcc/propeller-elf/lib/cmm\libc.a(SimpleSerial.o) (_atoi) c:/propgcc/propeller-elf/lib/cmm\libc.a(ctype.o) c:/propgcc/propeller-elf/lib/cmm\libc.a(atoi.o) (___ctype) c:/propgcc/propeller-elf/lib/cmm\libc.a(wcrtomb_ascii.o) c:/propgcc/propeller-elf/lib/cmm\libc.a(vfprintf.o) (__wcrtomb_ptr) c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_udivdi3.o) c:/propgcc/propeller-elf/lib/cmm\libc.a(vfprintf.o) (___udivdi3) c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_umoddi3.o) c:/propgcc/propeller-elf/lib/cmm\libc.a(vfprintf.o) (___umoddi3) c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_clz.o) c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_udivdi3.o) (___clz_tab) Allocating common symbols Common symbol size file ___stdio_lock 0x4 c:/propgcc/propeller-elf/lib/cmm\libc.a(fopen_intern.o) _g_mcp300x_cs 0x1 mcp300x.o _g_l3g_cs 0x4 l3g.o _(float, int, long,...)(short) 0x1a0 c:/propgcc/propeller-elf/lib/cmm\libc.a(fopen_intern.o) _g_sd_buf 0x218 sd.o Memory Configuration Name Origin Length Attributes hub 0x00000000 0x00008000 cog 0x00000000 0x000007c0 coguser 0x00000000 0x000007c0 ram 0x20000000 0x10000000 rom 0x30000000 0x10000000 drivers 0xc0000000 0x00100000 dummy 0xe0000000 0x00100000 *default* 0x00000000 0xffffffff Linker script and memory map LOAD c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/spinboot.o LOAD c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/_crt0.o LOAD c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/_crtbegin.o LOAD PropWare.o LOAD spi.o LOAD spi_as.o LOAD sd.o LOAD l3g.o LOAD mcp300x.o LOAD hd44780.o LOAD c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a START GROUP LOAD c:/propgcc/propeller-elf/lib/cmm\libc.a LOAD c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a END GROUP LOAD c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a LOAD c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/_crtend.o .boot 0x00000000 0x20 *(.boot) .boot 0x00000000 0x20 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/spinboot.o 0x00000000 __clkfreq 0x00000004 __clkmode 0x00000008 __sys_mbox .lmmkernel 0x00000000 0x764 load address 0x00000020 *(.lmmkernel) .lmmkernel 0x00000000 0x760 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/_crt0.o 0x00000000 r0 0x00000000 __LMM_entry 0x00000004 r1 0x00000008 r2 0x0000000c r3 0x00000010 r4 0x00000014 r5 0x00000018 r6 0x0000001c r7 0x00000020 r8 0x00000024 r9 0x00000028 r10 0x0000002c r11 0x00000030 r12 0x00000034 r13 0x00000038 r14 0x0000003c lr 0x00000040 sp 0x00000044 pc 0x00000048 __MASK_FFFFFFFF 0x0000004c __TMP0 0x00000440 __LMM_CALL 0x00000448 __LMM_CALL_INDIRECT 0x00000454 __LMM_JMP 0x00000460 __LMM_PUSHM 0x00000480 __LMM_PUSHM_ret 0x00000488 __LMM_POPRET 0x00000490 __LMM_POPRET_ret 0x00000494 __LMM_POPM 0x000004b4 __LMM_POPM_ret 0x000004b8 __MASK_0000FFFF 0x000004cc __CLZSI 0x000004d0 __CTZSI 0x00000508 __CLZSI_ret 0x00000514 __UDIVSI 0x00000558 __UDIVSI_ret 0x00000560 __DIVSI 0x00000588 __DIVSI_ret 0x00000598 __MULSI 0x000005b8 __MULSI_ret 0x000005bc __C_LOCK_PTR 0x000005c0 __CMPSWAPSI 0x000005e0 __CMPSWAPSI_ret 0x000005ec __LMM_RET 0x00000660 __LMM_FCACHE_START *(.kernel) .kernel 0x00000760 0x4 c:/propgcc/propeller-elf/lib/cmm\libc.a(thread.o) 0x00000760 __TLS .init 0x00000784 0x74 *(.init*) .init 0x00000784 0x60 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/_crtbegin.o 0x00000784 start 0x00000784 entry 0x000007ab ___init .init 0x000007e4 0x14 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/_crtend.o .text 0x000007f8 0x3d78 *(.text*) .text 0x000007f8 0x0 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/spinboot.o .text 0x000007f8 0x0 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/_crt0.o .text 0x000007f8 0x0 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/_crtbegin.o .text 0x000007f8 0x6c PropWare.o 0x000007f8 _GPIOSwitchRead_Low 0x00000836 _PropWareCountBits 0x0000084a _PropWareGetPinNum 0x00000862 _main .text 0x00000864 0x414 spi.o 0x000008c2 _SPIStop 0x000008e4 _SPIIsRunning 0x000008f8 _SPIWait 0x00000928 _SPIWaitSpecific 0x0000095b _SPISetMode 0x00000991 _SPISetBitMode 0x000009cd _SPISetClock 0x00000a12 _SPIStart 0x00000b15 _SPIGetClock 0x00000b56 _SPIShiftOut 0x00000b91 _SPIShiftIn 0x00000be4 _SPIShiftOut_fast 0x00000c04 _SPIShiftIn_fast 0x00000c59 _SPIShiftIn_sector .text 0x00000c78 0x0 spi_as.o .text 0x00000c78 0x1850 sd.o 0x00000c78 _SDfeof 0x00000c8b _SDfseekr 0x00000cbd _SDfseekw 0x00000cef _SDftellr 0x00000cf4 _SDftellw 0x00000cf9 _SDSendCommand 0x00000d33 _SDGetResponse 0x00000dab _SDStart 0x00000f68 _SDReadBlock 0x0000105b _SDWriteBlock 0x0000111a _SDReadDataBlock 0x00001175 _SDWriteDataBlock 0x000011d0 _SDUnmount 0x00001228 _SDReadDat16 0x0000123a _SDReadDat32 0x0000125d _SDWriteDat16 0x00001269 _SDWriteDat32 0x00001285 _SDfclose 0x00001335 _SDGetSectorFromPath 0x0000133b _SDGetSectorFromAlloc 0x0000135d _SDGetFATValue 0x0000141e _SDMount 0x000015e9 _SDLoadSectorFromOffset 0x000016f7 _SDIncCluster 0x0000176c _SDLoadNextSector 0x00001808 _SDGetFilename 0x0000186b _SDFind 0x00001959 _SDchdir 0x00001a3d _SDReloadBuf 0x00001abf _SDfgetc 0x00001b05 _SDfgets 0x00001b3a _SDFindEmptySpace 0x00001ccd _SDExtendFAT 0x00001da0 _SDfputc 0x00001e3f _SDfputs 0x00001e5d _SDCreateFile 0x00001f7f _SD_Shell_touch 0x00001fab _SDfopen 0x00002158 _SD_Shell_cat 0x00002191 _SDPrintFileAttributes 0x0000220d _SDPrintFileEntry 0x00002250 _SD_Shell_ls 0x000022f1 _SD_Shell .text 0x000024c8 0x300 l3g.o 0x00002604 _L3GStart 0x00002677 _L3GAlwaysSetMode 0x0000267d _L3GReadX 0x00002688 _L3GReadY 0x00002693 _L3GReadZ 0x0000269e _L3GRead 0x000026ad _L3GReadAll 0x00002755 _L3G_ioctl .text 0x000027c8 0x164 mcp300x.o 0x000027c8 _MCP300xStart 0x00002827 _MCP300xAlwaysSetMode 0x0000282d _MCP300xRead 0x000028ac _MCP300xReadDif .text 0x0000292c 0x658 hd44780.o 0x000029d7 _HD44780Clear 0x00002a04 _HD44780Start 0x00002cdc _HD44780Move 0x00002d4a _HD44780_putchar 0x00002dd8 _HD44780_puts 0x00002deb _HD44780_int 0x00002e5e _HD44780_uint 0x00002eb0 _HD44780_hex 0x00002ef6 _HD44780_printf .text 0x00002f84 0x80 c:/propgcc/propeller-elf/lib/cmm\libc.a(fputc.o) 0x00002f84 _fputc .text 0x00003004 0xc c:/propgcc/propeller-elf/lib/cmm\libc.a(puts.o) 0x00003004 _puts .text 0x00003010 0x34 c:/propgcc/propeller-elf/lib/cmm\libc.a(gets.o) 0x00003010 _gets .text 0x00003044 0x17c c:/propgcc/propeller-elf/lib/cmm\libc.a(fopen_intern.o) 0x00003044 ___fopen_driver 0x00003131 _fclose .text 0x000031c0 0x10 c:/propgcc/propeller-elf/lib/cmm\libc.a(printf.o) 0x000031c0 _printf .text 0x000031d0 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(default_io.o) .text 0x000031d0 0x50 c:/propgcc/propeller-elf/lib/cmm\libc.a(init_io.o) 0x000031d0 __InitIO .text 0x00003220 0x4 c:/propgcc/propeller-elf/lib/cmm\libc.a(thread.o) .text 0x00003224 0x9c c:/propgcc/propeller-elf/lib/cmm\libc.a(memset.o) 0x00003224 _memset .text 0x000032c0 0x68 c:/propgcc/propeller-elf/lib/cmm\libc.a(strcmp.o) 0x000032c0 _strcmp .text 0x00003328 0x1dc c:/propgcc/propeller-elf/lib/cmm\libc.a(SimpleSerial.o) .text 0x00003504 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(serialparam.o) .text 0x00003504 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(terminal.o) .text 0x00003504 0xe0 c:/propgcc/propeller-elf/lib/cmm\libc.a(fflush.o) 0x000035bf _fflush .text 0x000035e4 0xbc c:/propgcc/propeller-elf/lib/cmm\libc.a(fgetc.o) 0x000035e4 __filbuf 0x00003680 _fgetc .text 0x000036a0 0x60 c:/propgcc/propeller-elf/lib/cmm\libc.a(fputs.o) 0x000036a0 ___do_fputs 0x000036f7 _fputs .text 0x00003700 0x7d0 c:/propgcc/propeller-elf/lib/cmm\libc.a(vfprintf.o) 0x00003a70 _vfprintf .text 0x00003ed0 0x50 c:/propgcc/propeller-elf/lib/cmm\libc.a(atoi.o) 0x00003ed0 _atol 0x00003ed0 _atoi .text 0x00003f20 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(ctype.o) .text 0x00003f20 0x18 c:/propgcc/propeller-elf/lib/cmm\libc.a(wcrtomb_ascii.o) 0x00003f20 __wcrtomb_ascii .text 0x00003f38 0x338 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_udivdi3.o) 0x00003f38 ___udivdi3 .text 0x00004270 0x300 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_umoddi3.o) 0x00004270 ___umoddi3 .text 0x00004570 0x0 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_clz.o) .text 0x00004570 0x0 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/_crtend.o 0x00004570 _etext = . spi_as.cog 0x00000000 0x508 load address 0x00004570 spi_as.cog 0x00000000 0x508 spi_as.o .fini 0x00004a78 0x30 *(.fini*) .fini 0x00004a78 0x1c c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/_crtbegin.o 0x00004a78 _exit .fini 0x00004a94 0x14 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/_crtend.o 0x00004a96 __Exit 0x00004a96 __exit 0x00004aa2 __ExitHook .hub 0x00004aa8 0x488 *(.hubstart) *(.hubtext*) .hubtext 0x00004aa8 0x134 c:/propgcc/propeller-elf/lib/cmm\libc.a(terminal.o) 0x00004aa8 __term_write 0x00004af4 __term_read *(.hubdata*) *(.hub) *(.data) .data 0x00004bdc 0x0 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/spinboot.o .data 0x00004bdc 0x0 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/_crt0.o .data 0x00004bdc 0x0 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/_crtbegin.o .data 0x00004bdc 0x0 PropWare.o .data 0x00004bdc 0x8 spi.o .data 0x00004be4 0x0 spi_as.o .data 0x00004be4 0x118 sd.o .data 0x00004cfc 0x0 l3g.o .data 0x00004cfc 0x0 mcp300x.o .data 0x00004cfc 0x0 hd44780.o .data 0x00004cfc 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(fputc.o) .data 0x00004cfc 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(puts.o) .data 0x00004cfc 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(gets.o) .data 0x00004cfc 0x4 c:/propgcc/propeller-elf/lib/cmm\libc.a(fopen_intern.o) 0x00004cfc ___dummy .data 0x00004d00 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(printf.o) .data 0x00004d00 0x8 c:/propgcc/propeller-elf/lib/cmm\libc.a(default_io.o) 0x00004d00 __driverlist .data 0x00004d08 0xc c:/propgcc/propeller-elf/lib/cmm\libc.a(init_io.o) .data 0x00004d14 0x4 c:/propgcc/propeller-elf/lib/cmm\libc.a(thread.o) 0x00004d14 ___yield_ptr .data 0x00004d18 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(memset.o) .data 0x00004d18 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(strcmp.o) .data 0x00004d18 0x2c c:/propgcc/propeller-elf/lib/cmm\libc.a(SimpleSerial.o) 0x00004d18 __SimpleSerialDriver 0x00004d3c __SimpleSerialPrefix .data 0x00004d44 0xc c:/propgcc/propeller-elf/lib/cmm\libc.a(serialparam.o) 0x00004d44 __baud 0x00004d48 __txpin 0x00004d4c __rxpin .data 0x00004d50 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(terminal.o) .data 0x00004d50 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(fflush.o) .data 0x00004d50 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(fgetc.o) .data 0x00004d50 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(fputs.o) .data 0x00004d50 0x54 c:/propgcc/propeller-elf/lib/cmm\libc.a(vfprintf.o) .data 0x00004da4 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(atoi.o) .data 0x00004da4 0x84 c:/propgcc/propeller-elf/lib/cmm\libc.a(ctype.o) 0x00004da4 ___ctype .data 0x00004e28 0x4 c:/propgcc/propeller-elf/lib/cmm\libc.a(wcrtomb_ascii.o) 0x00004e28 __wcrtomb_ptr .data 0x00004e2c 0x0 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_udivdi3.o) .data 0x00004e2c 0x0 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_umoddi3.o) .data 0x00004e2c 0x100 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_clz.o) 0x00004e2c ___clz_tab .data 0x00004f2c 0x0 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/_crtend.o *(.data*) *(.rodata) *(.rodata*) *(.gnu.linkonce.d*) 0x00004f2c PROVIDE (__C_LOCK, .) 0x00004f2c 0x4 LONG 0x0 .ctors 0x00004f30 0x8 *(.ctors*) .ctors 0x00004f30 0x4 c:/propgcc/propeller-elf/lib/cmm\libc.a(init_io.o) .ctors 0x00004f34 0x4 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/_crtend.o 0x00004f34 __argv 0x00004f34 __environ .dtors 0x00004f38 0xc *(.dtors*) .dtors 0x00004f38 0x4 c:/propgcc/propeller-elf/lib/cmm\libc.a(fopen_intern.o) .dtors 0x00004f3c 0x4 c:/propgcc/propeller-elf/lib/cmm\libc.a(SimpleSerial.o) .dtors 0x00004f40 0x4 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/_crtend.o .data 0x00004f44 0x0 0x00004f44 . = ALIGN (0x4) .bss 0x00004f44 0x718 0x00004f44 PROVIDE (__bss_start, .) *(.bss) .bss 0x00004f44 0x0 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/spinboot.o .bss 0x00004f44 0x0 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/_crt0.o .bss 0x00004f44 0x0 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/_crtbegin.o .bss 0x00004f44 0x0 PropWare.o .bss 0x00004f44 0x0 spi.o .bss 0x00004f44 0x0 spi_as.o .bss 0x00004f44 0x230 sd.o .bss 0x00005174 0x4 l3g.o 0x00005174 _g_l3g_alwaysSetMode .bss 0x00005178 0x4 mcp300x.o 0x00005178 _g_mcp300x_alwaysSetMode .bss 0x0000517c 0x24 hd44780.o .bss 0x000051a0 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(fputc.o) .bss 0x000051a0 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(puts.o) .bss 0x000051a0 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(gets.o) .bss 0x000051a0 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(fopen_intern.o) .bss 0x000051a0 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(printf.o) .bss 0x000051a0 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(default_io.o) .bss 0x000051a0 0x50 c:/propgcc/propeller-elf/lib/cmm\libc.a(init_io.o) .bss 0x000051f0 0xa8 c:/propgcc/propeller-elf/lib/cmm\libc.a(thread.o) 0x000051f0 ___napuntil_ptr .bss 0x00005298 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(memset.o) .bss 0x00005298 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(strcmp.o) .bss 0x00005298 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(SimpleSerial.o) .bss 0x00005298 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(serialparam.o) .bss 0x00005298 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(terminal.o) .bss 0x00005298 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(fflush.o) .bss 0x00005298 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(fgetc.o) .bss 0x00005298 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(fputs.o) .bss 0x00005298 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(vfprintf.o) .bss 0x00005298 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(atoi.o) .bss 0x00005298 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(ctype.o) .bss 0x00005298 0x0 c:/propgcc/propeller-elf/lib/cmm\libc.a(wcrtomb_ascii.o) .bss 0x00005298 0x0 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_udivdi3.o) .bss 0x00005298 0x0 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_umoddi3.o) .bss 0x00005298 0x0 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_clz.o) .bss 0x00005298 0x0 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm/_crtend.o *(.bss*) *(COMMON) COMMON 0x00005298 0x218 sd.o 0x00005298 _g_sd_buf COMMON 0x000054b0 0x4 l3g.o 0x000054b0 _g_l3g_cs COMMON 0x000054b4 0x1 mcp300x.o 0x000054b4 _g_mcp300x_cs *fill* 0x000054b5 0x3 00 COMMON 0x000054b8 0x1a4 c:/propgcc/propeller-elf/lib/cmm\libc.a(fopen_intern.o) 0x000054b8 ___stdio_lock 0x000054bc _(float, int, long,...)(short) 0x0000565c PROVIDE (__bss_end, .) .hub_heap 0x0000565c 0x4 0x00005660 . = (. + 0x4) *fill* 0x0000565c 0x4 00 0x0000565c ___hub_heap_start = ADDR (.hub_heap) .drivers *(.drivers) 0x00000020 __load_start_kernel = LOADADDR (.lmmkernel) 0x00004f30 ___CTOR_LIST__ = ADDR (.ctors) 0x00004f38 ___DTOR_LIST__ = ADDR (.dtors) .hash *(.hash) .dynsym *(.dynsym) .dynstr *(.dynstr) .gnu.version *(.gnu.version) .gnu.version_d *(.gnu.version_d) .gnu.version_r *(.gnu.version_r) .rel.init *(.rel.init) .rela.init *(.rela.init) .rel.text *(.rel.text) *(.rel.text.*) *(.rel.gnu.linkonce.t*) .rela.text *(.rela.text) *(.rela.text.*) *(.rela.gnu.linkonce.t*) .rel.fini *(.rel.fini) .rela.fini *(.rela.fini) .rel.rodata *(.rel.rodata) *(.rel.rodata.*) *(.rel.gnu.linkonce.r*) .rela.rodata *(.rela.rodata) *(.rela.rodata.*) *(.rela.gnu.linkonce.r*) .rel.data *(.rel.data) *(.rel.data.*) *(.rel.gnu.linkonce.d*) .rela.data *(.rela.data) *(.rela.data.*) *(.rela.gnu.linkonce.d*) .rel.ctors *(.rel.ctors) .rela.ctors *(.rela.ctors) .rel.dtors *(.rel.dtors) .rela.dtors *(.rela.dtors) .rel.got *(.rel.got) .rela.got *(.rela.got) .rel.bss *(.rel.bss) .rela.bss *(.rela.bss) .rel.plt *(.rel.plt) .rela.plt *(.rela.plt) .stab *(.stab) .stabstr *(.stabstr) .stab.excl *(.stab.excl) .stab.exclstr *(.stab.exclstr) .stab.index *(.stab.index) .stab.indexstr *(.stab.indexstr) .comment *(.comment) .debug *(.debug) .line *(.line) .debug_srcinfo *(.debug_srcinfo .zdebug_srcinfo) .debug_sfnames *(.debug_sfnames .zdebug_sfnames) .debug_aranges 0x00000000 0x40 *(.debug_aranges .zdebug_aranges) .debug_aranges 0x00000000 0x20 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_udivdi3.o) .debug_aranges 0x00000020 0x20 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_umoddi3.o) .debug_pubnames *(.debug_pubnames .zdebug_pubnames) .debug_info 0x00000000 0x127b *(.debug_info .gnu.linkonce.wi.* .zdebug_info) .debug_info 0x00000000 0x850 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_udivdi3.o) .debug_info 0x00000850 0x8ad c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_umoddi3.o) .debug_info 0x000010fd 0x17e c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_clz.o) .debug_abbrev 0x00000000 0x332 *(.debug_abbrev .zdebug_abbrev) .debug_abbrev 0x00000000 0x162 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_udivdi3.o) .debug_abbrev 0x00000162 0x17a c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_umoddi3.o) .debug_abbrev 0x000002dc 0x56 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_clz.o) .debug_line 0x00000000 0x232 *(.debug_line .zdebug_line) .debug_line 0x00000000 0xeb c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_udivdi3.o) .debug_line 0x000000eb 0xe7 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_umoddi3.o) .debug_line 0x000001d2 0x60 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_clz.o) .debug_frame 0x00000000 0x64 *(.debug_frame .zdebug_frame) .debug_frame 0x00000000 0x30 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_udivdi3.o) .debug_frame 0x00000030 0x34 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_umoddi3.o) .debug_str 0x00000000 0x14 *(.debug_str .zdebug_str) .debug_str 0x00000000 0xa c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_udivdi3.o) .debug_str 0x0000000a 0xa c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_umoddi3.o) .debug_loc 0x00000000 0x15b0 *(.debug_loc .zdebug_loc) .debug_loc 0x00000000 0xb40 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_udivdi3.o) .debug_loc 0x00000b40 0xa70 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_umoddi3.o) .debug_macinfo *(.debug_macinfo .zdebug_macinfo) 0x000007c0 PROVIDE (par, PAR) 0x000007c4 PROVIDE (cnt, CNT) 0x000007c8 PROVIDE (ina, INA) 0x000007cc PROVIDE (inb, INB) 0x000007d0 PROVIDE (outa, OUTA) 0x000007d4 PROVIDE (outb, OUTB) 0x000007d8 PROVIDE (dira, DIRA) 0x000007dc PROVIDE (dirb, DIRB) 0x000007e0 PROVIDE (ctra, CTRA) 0x000007e4 PROVIDE (ctrb, CTRB) 0x000007e8 PROVIDE (frqa, FRQA) 0x000007ec PROVIDE (frqb, FRQB) 0x000007f0 PROVIDE (phsa, PHSA) 0x000007f4 PROVIDE (phsb, PHSB) 0x000007f8 PROVIDE (vcfg, VCFG) 0x000007fc PROVIDE (vscl, VSCL) 0x0000566c PROVIDE (__hub_end, (ADDR (.hub_heap) + 0x10)) 0x00008000 PROVIDE (__stack_end, 0x8000) OUTPUT(PropWare.elf elf32-propeller) 0x00004570 PROVIDE (__load_start_spi_as_cog, LOADADDR (spi_as.cog)) 0x00004a78 PROVIDE (__load_stop_spi_as_cog, (LOADADDR (spi_as.cog) + SIZEOF (spi_as.cog)) ) .debug_ranges 0x00000000 0x178 .debug_ranges 0x00000000 0xc8 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_udivdi3.o) .debug_ranges 0x000000c8 0xb0 c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/cmm\libgcc.a(_umoddi3.o) sh-3.1$$ git diff diff --git a/Makefile b/Makefile index 9984c1a..7c68199 100644 --- a/Makefile +++ b/Makefile @@ -1,15 +1,17 @@ # Build all source code files within PropWare for easy testing of compilation e -PRJ = PropWare -all: PropWare.o spi.o spi_as.o sd.o l3g.o mcp300x.o hd44780.o BOARD = QUICKSTART MODEL = cmm CFLAGS = -Os -# Insert your own path here - it should be the same directory that contains "co -PROPWARE_PATH = /home/david/PropWare +NAME= PropWare +OBJS= PropWare.o spi.o spi_as.o sd.o l3g.o mcp300x.o hd44780.o # Optionally, specify where your compiler is installed -PREFIX = /opt/parallax +PREFIX = /c/propgcc + +all: $(NAME).elf + +include ./common.mk + -include $(PROPWARE_PATH)/common.mk diff --git a/PropWare.c b/PropWare.c index 4eb3c90..fd6370b 100644 --- a/PropWare.c +++ b/PropWare.c @@ -4,7 +4,7 @@ * @author David Zemon */ -#include <PropWare.h> +#include "PropWare.h" uint8_t GPIOSwitchRead_Low (uint32_t pin) { DIRA &= ~pin; // Set the pin as input @@ -35,3 +35,8 @@ uint8_t PropWareGetPinNum (const uint32_t pinMask) { ; return --temp; } + +int main(int argc, char *argv[]) +{ + return 0; +} diff --git a/common.mk b/common.mk index 5a9ebac..6bc1a0e 100644 --- a/common.mk +++ b/common.mk @@ -55,8 +55,8 @@ endif CFLAGS_NO_MODEL := -Wextra $(CFLAGS) CFLAGS += -m$(MODEL) -Wall -CXXFLAGS += $(CFLAGS) -Wall -LDFLAGS += -m$(MODEL) -fno-exceptions -fno-rtti +CXXFLAGS += $(CFLAGS) -Wall -fno-rtti +LDFLAGS += -m$(MODEL) -fno-exceptions INC += -I$(PROPWARE_PATH) -I $(PREFIX)/propeller-elf/include ifeq ($(MODEL), cmm) @@ -91,6 +91,7 @@ $(NAME).elf: $(OBJS) @echo 'Building target: $@' @echo 'Invoking: PropGCC Linker' $(CC) $(LDFLAGS) $(LIB_INC) $(LIBS) -o $@ $(OBJS) + $(CC) -Xlinker -Map=$(NAME).map $(LDFLAGS) $(LIB_INC) $(LIBS) -o $@ $(OB @echo 'Finished building target: $@' @echo ' ' endif diff --git a/hd44780.c b/hd44780.c index fc06cac..807fec7 100644 --- a/hd44780.c +++ b/hd44780.c @@ -4,7 +4,7 @@ * @author David Zemon, Collin Winans */ -#include <hd44780.h> +#include "hd44780.h" #ifdef HD44780_DEBUG #include <stdio.h> #endif diff --git a/hd44780.h b/hd44780.h index 94a39ee..f84c9af 100644 --- a/hd44780.h +++ b/hd44780.h @@ -14,7 +14,7 @@ #include <stdarg.h> #include <stdlib.h> #include <propeller.h> -#include <PropWare.h> +#include "PropWare.h" #define HD44780_DEBUG diff --git a/l3g.c b/l3g.c index 06afa18..64c71a3 100644 --- a/l3g.c +++ b/l3g.c @@ -4,7 +4,7 @@ * @author David Zemon, Collin Winans */ -#include <l3g.h> +#include "l3g.h" uint32_t g_l3g_cs; uint8_t g_l3g_alwaysSetMode = 0; diff --git a/l3g.h b/l3g.h index 27dcef6..2800ccf 100644 --- a/l3g.h +++ b/l3g.h @@ -11,8 +11,8 @@ #define L3G_H_ #include <propeller.h> -#include <PropWare.h> -#include <spi.h> +#include "PropWare.h" +#include "spi.h" #define L3G_SPI_MODE SPI_MODE_3 #define L3G_SPI_BITMODE SPI_MSB_FIRST diff --git a/max6675.c b/max6675.c index 234e3db..4ffab08 100644 --- a/max6675.c +++ b/max6675.c @@ -4,7 +4,7 @@ * @author David Zemon */ -#include <max6675.h> +#include "max6675.h" uint32_t g_max6675_cs = -1; uint8_t g_max6675_alwaysSetMode = 0; diff --git a/mcp300x.c b/mcp300x.c index 7de4037..ed7c3d3 100644 --- a/mcp300x.c +++ b/mcp300x.c @@ -5,7 +5,7 @@ */ // Includes -#include <mcp300x.h> +#include "mcp300x.h" #define MCP300X_START BIT_4 #define MCP300X_SINGLE_ENDED BIT_3 diff --git a/mcp300x.h b/mcp300x.h index 61646fb..d0f12ba 100644 --- a/mcp300x.h +++ b/mcp300x.h @@ -14,8 +14,8 @@ #define MCP300X_H_ #include <propeller.h> -#include <PropWare.h> -#include <spi.h> +#include "PropWare.h" +#include "spi.h" #define MCP300X_SPI_DEFAULT_FREQ 100000 #define MCP300X_SPI_MODE SPI_MODE_2 diff --git a/sd.c b/sd.c index baf4d65..c6a558f 100644 --- a/sd.c +++ b/sd.c @@ -5,7 +5,7 @@ */ // Includes -#include <sd.h> +#include "sd.h" #ifdef SD_DEBUG /* @brief Print an error through UART string followed by entering an infinite diff --git a/sd.h b/sd.h index 286f8db..c49f002 100644 --- a/sd.h +++ b/sd.h @@ -23,8 +23,8 @@ #include <propeller.h> #include <stdlib.h> #include <string.h> -#include <PropWare.h> -#include <spi.h> +#include "PropWare.h" +#include "spi.h" /** * @defgroup sd FAT16/32 SD card diff --git a/spi.c b/spi.c index 7201305..335a5ec 100644 --- a/spi.c +++ b/spi.c @@ -5,7 +5,7 @@ */ // Includes -#include <spi.h> +#include "spi.h" #ifdef SPI_DEBUG #include <stdio.h> diff --git a/spi.h b/spi.h index 41b1b20..3b03b1f 100644 --- a/spi.h +++ b/spi.h @@ -11,7 +11,7 @@ #include <propeller.h> #include <stdlib.h> -#include <PropWare.h> +#include "PropWare.h" /** * @brief Extra code options - Uncomment definitions to enable features diff --git a/spi_as.S b/spi_as.S index cb9beb8..f9ee362 100644 --- a/spi_as.S +++ b/spi_as.S @@ -8,7 +8,7 @@ */ #define ASM_OBJ_FILE -#include <PropWare.h> +#include "PropWare.h" /* NOTE: These definitions *MUST* match up with the SPI source file "spi.c" */ // Different fuctions supported by this GAS module Steve@DADS-PC /c/gccdev/propside/MyProjects/PropWare (master) $Also - the directory structure might look a little weird as I have it in the git repo. I'm a fan of Eclipse and Eclipse likes to do its builds in a "Debug" folder beneath the root directory. Henceforth why I defined PROPWARE_PATH as ".." in PropWare/Makefile
I've shown you how to successfully build using the tools provided. It's up to you to apply it however you like.
Am I missing something?
My end goal here is not to build SPI_Demo.elf. I want to create a large library full of functions that makes the Propeller as easy to use as Arduino. If I can get this working (and I know, I have a LOT of work left in a lot more areas than just expanding the number of modules), then this ought to make the Propeller more powerful than Arduino, with just as much versatility (module files like spi.c and hd44780.c), just as easy to use, with an IDE (Eclipse) that isn't complete garbage (Arduino)
