Dual TV Output
I'm trying to output Chip's Graphic demo to two separate outputs on the same Prop Prototype Board.
Resistors in place output verified by running the demo with the correct pin group individually.
OUTPUT TV1 = PINS 0..3
OUTPUT TV2 =PINS 16..19
Can it be done?
Can it be done?
They are two separate graphics programs, two displays showing some gauges and numbers. It doesn't do much except animate the panel a little.
I'll just slap another Prop on the board and split up the displays.
