simpleIDE console Baud rate 230400? — Parallax Forums
prof_brainoprof_braino Posts: 4,313
edited 2013-04-13 12:07 in Propeller 1
I tried simpleIDE run console F8
It autocompiles and opens the window, but the max baud rate is 115200
My stuff uses 230400, I know other folks go higher.
Is there techincal limitation that prevents simpleIDE from using the higher baud rates?
If not I'd like to request 230400 for a future build.
    I'm sure propeller-load will work at 230400 but I'm not sure about the terminal emulator in SimpleIDE.
