Question about Propeller Tool Library
So, I've been at this for a couple years, and I just had something 'happen' that kind of alarmed me.
I have been faithfully backing up my "C:\Program Files(x86)\Parallax Inc\Propeller Tool v1.3.2\Library" directory (into which I have some of my own spin files) (this is the default installation directory).
I assumed that I was backing up current versions until I restored the backup to the netbook for some field work, got to the site, and found that all the versions were old. My files existed on the netbook, but after the first time when I put them there they weren't updated there anymore (as best as I can tell).
It seems that my CURRENT versions are located in "C:\Users\bte2_000\AppData\Local\VirtualStore\Program Files (x86)\Parallax Inc\Propeller Tool v1.3.2\Library", and I have not been including them in my routine backups.
I tried to search the forum, and I did RTFM.
Anybody have any insight as to how this works, or maybe if I can get a little flexibility as to where I can locate my Library? I would LIKE to locate my Library files in another location, but can't seem to figure out exactly how.
Just a heads up to make sure you are actually backing up your important stuff. I was, but not nearly as often as I thought I was. I discovered what was actually happening by searching the entire drive for SPIN files. Everything worked fine on my desktop, it wasn't until I tried to use the files on another computer that I discovered there was a problem.
Thanks in advance.
ETA- Oh yeah- I have Viewport installed (don't use it much yet) - I don't know if that matters.
Thanks in advance.
you stumbled over a windows security 'feature'.
since Vista writing into 'System-Directories' is considered a security-thread.
Program Files(x86) is one of those Directories.
thus those writes get 'redirected' to the virtual store. And read from there for the same user.
this has nothing to do with viewport...
as far as I know you can NOT disable this 'feature' of windows.
According to Mircrosoft Programs should save their settings and user-files in %APPDATA% not the Install-directory of the program.
Parallax is not doing that and installs the library in the Program folder. So it does not work (since Vista) to change the content of that folder or even files within.
Except you run proptool as Administrator (run as) then you can write there.
I keep all my files for a project together in my project-directory, risking to have multiple copies of my own libraries with sync-problems between them...
There are some discussions here about multiple libraries and path in the OBJ section. But as far as I know not supported yet.
Enjoy!
People spend a lot of time writing code (I just had to take two trips instead of one)(cost me about $100)(thank God I wasn't flying- I'd have been ticked), and I just think that it should be in bold type on the first page. All user file quirks should. Users should remain fully apprised when their hard work is at risk (like when your backups aren't really backups).
ETA- So I uninstalled it and reinstalled it to another directory but now the editor pane will not show anything. The Explorer pane displays correctly but when I open a file it is not visible.
That should work too.
Never thought about that. Nice solution. Obvious, once spoken out.
Enjoy!
Besides, this is less about where I save the files and more about the fact that they weren't getting backed up properly, despite me thinking they were.
I'm really glad my drive didn't smoke. I think Parallax should at least recommend NOT installing to this directory (assuming there are technical hurdles to overcome in fixing it).
I'm not dishing on them- it is a great product and a great company, but I find this to be a very serious issue.
Reinstall Propeller Tool using the 'custom' button, and what I did was just edit "C:\Program Files(x86)\Parallax Inc\Propeller Tool v1.3.2\" to read "C:\My Program Files\Parallax Inc\Propeller Tool v1.3.2\". Do the same with Viewport if you have it.
At this point, Propeller Tool ran but the editor pane was garbled until I restarted my computer.
After I restarted my computer, I opened Regedit and searched for "\Program Files(x86)\Parallax Inc\Propeller" and edited all of the library entries (should be 1, might be 2 or 3) as above. I kept my one edit and deleted the other one.
After I did that Propeller Tool worked properly so I then pasted my files into the library.
All appears well except now my Viewport don't work- it will not see my Parallax library. I'll try to figure it out later.
Whatever you do, check the dates on your files before you conclude that you have the right ones.
For whatever reason, I have learned to always do a full uninstall of the Propeller Tool before updating or re-installing. There are apparently some registry entries that should be touched during a re-install that are not and quirks show up. I experienced this on XP, Win7 Ultimate, Win7 Enterprise 64Bit.
I also keep my Spin files separate from those in the Prop Tool library.
I just did the netbook, and cleaned the Registry before reinstalling. Uninstalling didn't remove the entries. Worked first time.
lardom, you ain't kidding. I would love to keep my objects seperate but a) I shouldn't have to have them in their repository in the first place, and b) writing code is hard enough without wrestling with the compiler.
If a person could merely specify a full path to the desired object, none of this would be an issue.
