TI DIP Adapter EVM — Parallax Forums
TI DIP Adapter EVM
RDL2004RDL2004 Posts: 2,554
edited 2013-04-12 16:35 in General Discussion
I ran across this Texas Instruments DIP Adapter EVM in a post on another forum. I added one to my last order from Mouser just to see what it looked like. It could be useful to someone that uses a lot of surface mount op amps (or similar devices) and needs to build prototype circuits on breadboards.
The full module is about 2.5" x 2.75" and snaps apart into six boards for each of six different package types and it includes two strips of high quality pin headers. It's not enough pins for all 36 boards, but it's enough to get started.
At $10 it's not a bad deal if you would use most of the different types or to have around "just in case". If all you really needed was one type, such as SOIC-8, you'd probably be better off just buying adapter boards for that package only.
