Preserving a few variables across Power cycles
I need to save a few (less than 10) byte variables across power cycles. I am sure this has been discussed but I cannot find anything specific.
Up to now, I have had a clock chip with battery-backed RAM (DS-1302) and have kept them there and restored during initialization. But I will be getting time from a GPS from now on and don't need the clock chip any longer.
I am planning to use a little bit at the very top (last 16 bytes) of the EEPROM (24CL256). I will write and read it with code cribbed from "Basic I2C Routines V 1.3".
So here are my questions:
1. Does the boot loader always write the entire 32K bytes or just as much as it needs to? That is, will it over-write my variables (assuming my object leaves room)?
2. Would the boot loader work correctly if I used a 24CL512 (and keep the top 32K for myself)?
3. Is there something I am not thinking of that will keep this scheme from working? In other words, has anybody made this work in the past?
AdThanksVance for your time
2) The boot loader only affects the 1st 32K of EEPROM. You can use larger EEPROMs or multiple EEPROMs (at different addresses) and the boot loader will ignore any other than the 1st 32K
It's easiest to use a 64K EEPROM and store your values in the 2nd 32K. If you have only 32K and store the values in the upper few bytes of the EEPROM, they will get erased when you download a new program version. It may not be a problem during program debugging and, depending on what these variables contain, the program may be able to tolerate them being reset from time to time.
There's lesson on this in the PEK sticky in the Propeller forum (here's a direct link). You can save the new values of the variables to the EEPROM so they get loaded with the program on reboot.
Which Propeller board are you using? Most of the boards Parallax sells use 64K EEPROMs.
Whenever you load the EEPROM from the Prop Tool (F11) the entire lower 32K get overwritten. If you're just rebooting then whatever is in the EEPROM gets loaded to RAM including any changes you make. Rebooting wont mess up stuff you write EEPROM just loading the program from the Prop Tool will erase any changes you make to the lower 32K of EEPROM.
Yes, and the upper 32K doesn't get overwritten by the Prop Tool. It's very convenient to keep data you don't want overwritten in upper EEPROM.
This is a common practice among many Propeller users. It can be immensely useful.
BTW, Some EEPROMs have their size listed in a cryptic manner. If you don't know if you have a 32K EEPROM or a 64K EEPROM you can use the program attached to post #24 of this thread to check which size it is (it doesn't check for EEPROMs larger than 64K). The part of the program which checks for size works but the other features listed are really buggy.
Edit: I see Mike and Chris have already answered a lot of what you've asked. Sorry about the duplicate information.
Er, do you suppose Parallax will be selling a 64KB EEPROM soon?
All you need to use is this: write(@variable, @variable, 1 or 2 or 4) ' the last parameter is based on the variable's type
No need for a read method, the value is already in the variable when the Prop turns on.
Using the I2C object and this method (I believe it is just I2C's recommended write method):
The only caveat : try to do it relatively infrequently. If you write to the same block of the EEPROM frequently, you'll wear it out. There was a thread on here a while back where someone updated a variable once every couple seconds, as opposed to only when it was changed. He burned out his EEPROM in only a few days. (every 5 secs would be ~17000 writes in 24 hours).
What about a FRAM which doesn't need battery backup and has the ability (on average) to be written to the same location up to (10 to the power of 10) times?
