Command Line Adventures - Page 2 — Parallax Forums
2»
  • doggiedocdoggiedoc Posts: 2,248
    edited 2013-04-09 21:52
    Heater. wrote: »
    doggoidoc,
    Check out the nohup command. http://en.wikipedia.org/wiki/Nohup
    Allows you to logout and leave things running. Not the best solution but has worked very well for us.
    I came across an even better solution called screen. I can access the process from any connection with disrupting it. Perfect for minecraft (or long complies for that matter).
    edited 2013-04-09 21:57
    screen is an excellent solution. Especially for long compiles and such jobs as you say.
    Ultimately server processes like that should be started by the OS on boot up. Perhaps some monitoring should be in place to restart them when if they crash. Saves all that manual intervention.
    edited 2013-04-09 23:23
    Are you going to move on to Bash programing next? Or do you plan to have Perl do everything?
    edited 2013-04-10 03:50
    Heater. wrote: »
    Yes. I found some info on making minecraft a service that should do the trick. Screen is working pretty good for now though,
    edited 2013-04-10 08:12
    Minecraft... So I guess this is a dedicated game server.
    edited 2013-04-10 14:31
    Not completely. I've been playing with some of the propgcc stuff on it too. :D
