I2C for beginners (Using BMP085 Barometer)
Hey guys,
My Spin skills and PASM skills are not real great, I am learning more and more everyday but I am still a beginner. I want to play with a BMP085 barometer and I am trying to locate an I2C driver to use. I have been looking at the Basic I2C Driver but in the description it states that the code assumes there are no pull-up resistors on SDA and SCL. I have the BMP085 breakout board from sparkfun and the schematic shows there being pull-up resistors on the board.
My question is, can I still use this code with the BMP085, or any I2C device that already has pull up resistors built in?
Shawn
Shawn
Most slave devices don't do it, but Micro-controller based modules may very well do it.
Since the answer is yes, thank you SRLM. Do I need to modify the Basic I2C Driver code? My guess is no!
This is the simple program I wrote to read out the calibration E2PROM on the BMP085, The BMP085 manual says communication can be checked by reading these registers. 0 and FFFF are invalid numbers from these registers and I got 0 for all of them. I would say this means I did not communicate at all with the chip. I am sure I missed something simple, this should not be complicated. Here is my code if anyone would like to take a look.
Shawn
If I change the address to $77 then I get a -1 back. What does the -1 signify? The code says that if a error occurs it will return true. -1 surely is not true is it? This is one thing I need to learn in order to read and write code better. So I am assuming that I have the right address since I do not get a -1 when I use the address %1110 1110. Or could the address still be wrong?
The example that I was basing my code off of read the BMP085 registers as a word. I saw the addresses in the data sheet as byte size but I think I can read a whole word out, I don't think that is the problem. I tried modifying the code to read just one byte out and it still read out 0's.
I might have found the problem, in order to read the device I think I have to use %1110 1111 and to write I have to use %1110 1110. I am going to try that now.
Shawn
It did not show up properly in my post above.
Also I am using V1.3 Basic I2C Driver.
Shawn
I tried %1110 1110 and %1110 1111.
Shawn
Thanks Again
Shawn
On to the next section of code for the BMP085. I need to send a request for a temperature reading. The register address is $F4 and the control register value should be $2E if I read the manual right. After sending the request for a temperature reading I have to wait for 4.5mS before I can try to read it. Now that I have waited 4.5mS I should be able to read the temperature out of register $F6 MSB and register $F7 LSB. When I add the code below to my main program I get a value of 128 all the time for my Temperature1 variable, it never changes. I do not think my request for a temperature reading is making it to the BMP085. The reason I don't think it is making it, is because the BMP085 has a END OF CONVERSION line that should change from a logic 0 to a logic 1 when the temperature reading is ready to be read. The EOC is never changing state to a logic 1, I hooked my scope to it.
I tried a bunch of different things with no success.
Shawn
I tried placing the I2C#OneAddr in the writebyte command initially but I put it in the wrong spot. When I do this I2C.WriteByte(8, $EE, $f4| I2C#OneAddr, $2e) my END OF CONVERSION pin changes to a logic 1 and I am able to read a value out of the device for temperature. I haven't figured out what the variable means yet, it seems strange that a bunch of math is required just to get the temperature.
Shawn
Now it is time to read out the Pressure! I am having a hard time understanding the data sheet. The Uncompensated Pressure can be read out in either a 16 bit or 19 bit value. This is what I have tried, does this look reasonable, or does it look messed up. I am about ready to write the Compensated Pressure routine. When I run this program I do get a reading. The reason I question this is, if I read out MSB, LSB, and XLSB and display them individually I get strange values. MSB should be 8 bits, LSB should be 8 bits, and XLSB should be 3 bits. However my XLSB value can be as high as 128, and I don't understand how you can get 128 from a 3 bit value.
Also I do not understand this equation either but it came straight out of the data sheet.
UP := (MSB<<16 + LSB<<8 + XLSB)>> (8 - Mode)
Shawn
Shawn
Thanks again Kuroneko and also to Tim Moore who's program I modeled mine off of. I think I have a better understanding of the Basic I2C Drivers now also. I will post my code once I have it cleaned up.
Shawn
