Does anyone know how I may be able to drive this display with a propeller?
I pulled this thing out of an radar detector a while back, and am interested in getting it running. The problem is I do not know if displays like this need an interface chip like a parallel LCD, or if you just drive the LEDs like you would a seven segment, i don't even know what these displays are called. The display is 8 digits and has a grid of leds in each digit display.
Whether led or VF it is a 6 character display using a 5 x 7 matrix for each character.
100-200 volts and the VF displays run off around 50V. If you check out the power supply that powered it you could probably figure out which.
https://www1.elfa.se/data1/wwwroot/assets/datasheets/hdsp-253x_eng_tds.pdf
They have the look of "smart-displays".
Serial, SPI most likely.
https://cobra.com/downloads/manuals/XRS9630_MANL.pdf
Keep on "googling"!
I think feng may be right. Wouldn't hurt to try hooking it up using that data sheet, although if power was applied in reverse it may be fried.
http://www.digikey.com/scripts/DkSearch/dksus.dll?lang=en&keywords=hcms-2973&WT.srch=1&cur=USD
I was super excited I could buy more of these, till I saw they were $35 bucks in singles!
