Reset circuit on Prop1 Protoboard USB
Will someone explain the principle behind the NPN BJT with base connected through a series capacitor to the DTR pin of the FTDI (USB interface) chip on the Propeller Protoboard USB? I presume that it operates with a short pulse on the DTR pin causing a transient which propagates through the capacitor, causing Q1 forward bias and conducting to pull RESET low. After the transient forward bias is gone, allowing RESET to float. This also isolates the DTR pin from VSS when the reset button is pushed. Right?
