I've broken my code - running out of hair - please spot the obvious mistake
I managed to break my code (it's a skill I have).
Basically I'm reading a string of serial data and doing stuff with it...
Towards the end of MAIN I call a debugging routine called PrintBuffer, then I call the CheckMessage routine. The very first step of CheckMessage is to call PrintBuffer again as somewhere beteen the printBuffer calls it gets screwey.
so in Psudeo code
Main
PrintBuffer(@InBuffer)
CheckMessage (@InBuffer)
CheckMessage (message)
PrintBuffer (@message)
How can the two strings from PrintBuffer be different?
Modbus_PAC.spin
Huge thanks in advance
so in Psudeo code
Main
Seems just when I _think_ i've got a handle on string data - I make a mistake like this...
