Option request for PNut
Baggers
I'm now getting way over the PNut download max, even with having data already in hub-ram.
Is there any chance you could add a compile only option? so that it doesn't download a chopped file and run it?
Cheers,
Jim.
Cheers,
Jim.
So I have 2 windows open...
a pnut window for editing & compiling
a Dos window (run cmd) which uses a batch file to run p2load to download (and -T or -t for a terminal in the dos window)
For that You can use Ctrl-L one time for compile then Ctrl-L - Back to source
