DS1307 Initialization and Demo - Page 2 — Parallax Forums
2»
  • ShaliniShalini Posts: 59
    edited 2013-04-04 14:53
    I downloaded all 3 codes into the propeller and I'm getting some lines in the display.
    edited 2013-04-04 15:05
    I'm getting blank screen after the programs are downloaded....is there anything else to be done...Am I missing something???
  • ChrisGaddChrisGadd Posts: 311
    edited 2013-04-04 15:51
    Shalini wrote: »
    In your LCD driver.spin code you have given:
    PUB start(E_pin, RW_pin, RS_pin, D4_pin) : okay
    stop
    pins[0] := E_pin
    pins[1] := RW_pin
    pins[2] := RS_pin
    pins[3] := D4_pin
    the 0,1,2,3... is the propeller pins numbers which your using to connect E, RW, RS, and DB4??
    No, that's simply to make it easier to load those assignments into a PASM routine. All of the pin assignments are made in the top-level object "LCD clock". As currently written, RS is on 16, R/W 17, E 18, D4 through D7 on 19 through 22 ( in that order). The DS1307 uses 28 and 29, and a couple pushbutton switches (only required if you want to set the time) are on 26 and 27, with pull-ups to 3.3V.
    I tested it on a 16x2 LCD, though it displays all characters in the eight left-most columns so it should appear fine on a 8x2 display; your JHD162A uses the same format.
    edited 2013-04-04 15:57
    ChrisGadd wrote: »
    oh those three codes are for PASM (Assembly language), but are they still supposed to work on Propeller Tool 1.3.2?? because I'm getting blank display on the LCD...
    edited 2013-04-04 17:32
    Should work fine on 1.3.2
    Okay, let's try it from a different direction. You say that the display works properly with the LCD_8x2_4bit object?
    I simplified my object and modified it to use LCD_8x2_4bit instead, try it now. Also included the serial terminal just to see if the DS1307 is being read okay.
    LCD clock - basic - Archive [Date 2013.04.04 Time 20.20].zip
    And just to be sure, when you say you're downloading all of the codes into the Propeller, you do mean that you're loading the top-level object, "LCD Clock - basic" in this case, which is automatically loading the other objects, right? And not that you're not loading all of the object files individually one-at-a-time, right?
    Sorry, gotta ask.
    edited 2013-04-04 18:00
    i download them individually...
    edited 2013-04-04 18:24
    ChrisGadd wrote: »
    Sorry, gotta ask.
    IT WORKS!!!!! THANK YOU SO MUCH!!! Now the LCD is showing:
    31/12/00
    00:14:4801/01/01
    edited 2013-04-04 19:21
    Shalini wrote: »
    31/12/00
    00:14:4801/01/01
    its running like a timer instead of a clock.....what do i need to change to make it display clock time??
    edited 2013-04-04 20:07
    Shalini wrote: »
    now the clock is working in 24 hr mode,but I don't why the date is printing twice (one on first line and another on second line of the LCD)...
    edited 2013-04-05 06:15
    Shalini wrote: »
    Now, its showing:
    Date: 05/04/13
    Time: 09:16:40AM
    THANKS TO ALL U GUYS FOR HELPING ME OUT, U SAVED MY PROJECT!!! BUT I'M STILL NOT DONE!!!
