ESC Servo Code PASM Problem — Parallax Forums
ShawnaShawna Posts: 508
edited 2013-04-15 17:52 in Propeller 1
Hey Guys,
This is one of the first PASM programs I wrote, and it has been quite awhile since I wrote it. Also I have not written a PASM program since. It is for my quad project! The program is designed to run 8 ESC's at a 400hz rate. I thought the program was running fine, I set it up using my O Scope. But I noticed a problem while flying my quad, every once in awhile all 4 motors will glitch out for just a fraction of a second. Sometimes it won't happen at all during a 10 minute flight and sometimes it will happen 4 or 5 times. I think since it happens to all 4 motors that it is in my servo code.
Here is the code, its not real long but it is in PASM I am hoping that someone that is good with PASM can take a look at it with out wasting a bunch of their time. The program is basically my interpretation of the Servo 32 code. I tore it apart and tried to slim it down for just 8 ESC's. The sync portion is probably where the problem is, I figured out how many clock cycles it takes to run at 400hz. Then I add it to CNT and if it throws up an overflow flag I run the sync loop again. It looks like it should work to me but I am not sure. I suppose it is possible that my ESC's cannot run at 400hz but even if that is the problem I don't see that causing all four ESC's glitching out at the same time. I will try changing the wavelength tomorrow.
CON
  _clkmode      = xtal1 + pll16x
  _xinfreq      = 5_000_000
       MHZ      = 80
       UpDate   = 2_500
       NoGlitch = 3_000
       _1uS     = 1_000_000
VAR
Long ServoOutput[8]
OBJ
PUB Start
  'ServoOutPut[0] :=  80_000     '1.0mS
  'ServoOutPut[1] :=  80_000     '1.0mS
  'ServoOutPut[2] :=  80_000     '1.0ms
  'ServoOutPut[3] :=  80_000     '1.0ms
  'ServoOutPut[4] :=  80_000     '2.0ms
  'ServoOutPut[5] :=  80_000     '1.75mS
  'ServoOutPut[6] :=  80_000     '1.5mS
  'ServoOutPut[7] :=  80_000     '1.25ms
  cognew(@ServoOut, @ServoOutput)'Launch new cog
Pub Set(ServoIndex,Width)
    ServoOutput[ServoIndex] := constant(80000000 /1_000_000) * Width                'calculate # of clocks for a specific Pulse Width
DAT
        ORG 0
ServoOut
        mov           Address, PAR
        mov              DIRA, Servo_Pin_Mask
Sync
        mov              Temp, cnt
        mov          WaveTemp, Wave_Length
        add          WaveTemp, cnt        wc
if_c    jmp #Sync
LoadServoWidth
        rdlong ServoWidth1, Address
        add    ServoWidth1, Temp
        add        Address, #4
        rdlong ServoWidth2, Address
        add    ServoWidth2, Temp
        add        Address, #4
        rdlong ServoWidth3, Address
        add    ServoWidth3, Temp
        add        Address, #4
        rdlong ServoWidth4, Address
        add    ServoWidth4, Temp
        add        Address, #4
        rdlong ServoWidth5, Address
        add    ServoWidth5, Temp
        add        Address, #4
        rdlong ServoWidth6, Address
        add    ServoWidth6, Temp
        add        Address, #4
        rdlong ServoWidth7, Address
        add    ServoWidth7, Temp
        add        Address, #4
        rdlong ServoWidth8, Address
        add    ServoWidth8, Temp
        sub        Address, #28
OutPutLoop
        cmpsub  ServoWidth1, cnt        nr,wc
        muxc      ServoByte, ServoOut1
        cmpsub  ServoWidth2, cnt        nr,wc
        muxc      ServoByte, ServoOut2
        cmpsub  ServoWidth3, cnt        nr,wc
        muxc      ServoByte, ServoOut3
        cmpsub  ServoWidth4, cnt        nr,wc
        muxc      ServoByte, ServoOut4
        cmpsub  ServoWidth5, cnt        nr,wc
        muxc      ServoByte, ServoOut5
        cmpsub  ServoWidth6, cnt        nr,wc
        muxc      ServoByte, ServoOut6
        cmpsub  ServoWidth7, cnt        nr,wc
        muxc      ServoByte, ServoOut7
        cmpsub  ServoWidth8, cnt        nr,wc
        muxc      ServoByte, ServoOut8
        mov            OUTA, ServoByte
        cmp        WaveTemp, cnt        nr,wc
if_NC   jmp #OutPutLoop
        jmp #Sync
Address        Long 00_0000_0000_0000_0000_0000_0000_0000
Servo_Pin_Mask Long 00_0000_0000_0000_1111_1111_0000_0000
Wave_Length    Long 200_000' = 400hz  320_000 = 250hz
ServoOut1      Long 00_0000_0000_0000_1000_0000_0000_0000
ServoOut2      Long 00_0000_0000_0000_0100_0000_0000_0000
ServoOut3      Long 00_0000_0000_0000_0010_0000_0000_0000
ServoOut4      Long 00_0000_0000_0000_0001_0000_0000_0000
ServoOut5      Long 00_0000_0000_0000_0000_1000_0000_0000
ServoOut6      Long 00_0000_0000_0000_0000_0100_0000_0000
ServoOut7      Long 00_0000_0000_0000_0000_0010_0000_0000
ServoOut8      Long 00_0000_0000_0000_0000_0001_0000_0000
ServoByte      Long 00_0000_0000_0000_0000_0000_0000_0000
ServoWidth1    Long 00_0000_0000_0000_0000_0000_0000_0000
ServoWidth2    Long 00_0000_0000_0000_0000_0000_0000_0000
ServoWidth3    Long 00_0000_0000_0000_0000_0000_0000_0000
ServoWidth4    Long 00_0000_0000_0000_0000_0000_0000_0000
ServoWidth5    Long 00_0000_0000_0000_0000_0000_0000_0000
ServoWidth6    Long 00_0000_0000_0000_0000_0000_0000_0000
ServoWidth7    Long 00_0000_0000_0000_0000_0000_0000_0000
ServoWidth8    Long 00_0000_0000_0000_0000_0000_0000_0000
Temp           Long 00_0000_0000_0000_0000_0000_0000_0000
WaveTemp       Long 00_0000_0000_0000_0000_0000_0000_0000
Fit  80
'.000_000_012_5nS per clock cycle
'1_600_000 clock cycles = 20mS or 50hz
'200_000 clock cycles = 2.5mS or 400hz
Shawn
    edited 2013-04-02 19:47
    Can't help you with those small glitches (needs more digging) but I have a big one for you. Think about what happens when WaveTemp gets close to $FFFFFFFF. Especially at the end:
    cmp WaveTemp, cnt wc
            jmp #Sync
  • ShawnaShawna Posts: 508
    edited 2013-04-02 20:07
    kuroneko,
    If the wavetemp + CNT roll over $FFFFFFFF the wc flag should be set and it will loop back to sync. The most I would lose is 1 maybe 2 wavelengths. Which at 250hz that would only be 8mS. I don't think that would be noticeable. Or am I missing something else?
    Shawn
    edited 2013-04-02 20:12
    Shawna wrote: »
    What I meant was that WaveTemp is effectively Wave_Length + cnt (sync loop at the top). IOW WaveTemp being -1 is a perfectly valid result (no overflow). However, with that value you will never get a carry set condition in your output loop.
    To see the effect just add these 3 lines before your sync loop (don't connect anything expensive to the outputs in case it can't cope).
    neg     cnt, #14
                    sub     cnt, Wave_Length
                    waitcnt cnt, #0
    This will prime WaveTemp to be -1 when leaving the sync loop.
    edited 2013-04-02 20:30
    OK my lack of knowledge in PASM is getting the best of me. I thought I understood the syntax when I wrote the code but maybe not enough. I will have to get the propeller manual out and do some reading. I kind of get what you are saying but not completely, its to the manual for me. When $FFFFFFFF rolls over does it go to 1 or -1?
    Shawn
    edited 2013-04-02 20:34
    Shawna wrote: »
    $FFFFFFFF is -1 (just a point of view really). Next value is 0 etc. Forget rollover for now. If WaveTemp leaves the sync loop with that value it's game over simply because there is nothing an unsigned compare (cmp WaveTemp, cnt wc) can do to generate a carry set condition. You're comparing the biggest unsigned 32bit integer against something which can only ever be equal.
    edited 2013-04-02 20:54
    I get the gyst of what your saying, I got some home work to do on this.
    Shawn
    edited 2013-04-03 17:57
    Ok I have decided to just use an object that has been posted before. I want to dig into this but not right now, my new problem is, I cannot get the Servo8Fast object to work. I wrote a simple program to use this object on pins 15, 14, 13 and 12. The program should just initiate the Servo8Fast object and send a 1ms signal to the four pins. I do not have access to my scope right now but if the program works my ESC's should stop beeping. Here is my code and the attached file is the Servo8Fast. I got the object from the QuadX project. I have been bombing out here lately. If someone would like to look at this it I would be appreciative.
    Servo8Fast.spin
    CON
            _clkmode = xtal1 + pll16x                                               'Standard clock mode * crystal frequency = 80 MHz
    VAR
    OBJ
      ESC      : "Servo8Fast"
    PUB Main
      ESC.Init                                              'Initiate ESC Program.
      ESC.AddFastPin(15)                                    'Actual Pin number on Prop.
      ESC.AddFastPin(14)                                    'Actual Pin number on Prop.
      ESC.AddFastPin(13)                                    'Actual Pin number on Prop.
      ESC.AddFastPin(12)                                    'Actual Pin number on Prop.
      ESC.Set(15, 1000)                          'Set ESC value before start up.
      ESC.Set(14, 1000)                          'Set ESC value before start up.
      ESC.Set(13, 1000)                          'Set ESC value before start up.
      ESC.Set(12, 1000)                          'Set ESC value before start up.
      ESC.Start                                             'Start ESC COG.
    Shawn
    edited 2013-04-03 18:23
    Shawna wrote: »
    ''Note that the INDEX passed here is [COLOR="#FF0000"]in the range 0 to 7[/COLOR], and does NOT
    ''specify a pin number like the normal Servo32 object
    PUB Set(ServoIndex, Width)                                            'Set Servo value
          ServoData[ServoIndex] := constant(80000000 / _1uS) * Width      'calculate # of clocks for a specific Pulse Width
    Also, the Servo8Fast object is currently hardwired for pins 0..3 and 28..31 (see ZoneShift# table). Adjusting Set() parameters and the table should get you there. The AddFastPin() parameters should stay the same.
    edited 2013-04-03 18:33
    I just shorted 5 volts to one of the inputs on my proto-board trying to scope it, and now I can't load a program into it I think I just fried my propeller, time to start over.
    Thanks for the reply
    Shawn
    edited 2013-04-04 18:35
    Thanks Kuroneko,
    I got the code to work with the pins stated above, I thought I had got a hold of the code Jason Dorie modified so any pin can be defined, I guess not.
    Shawn
    edited 2013-04-05 08:46
    Here is an update to the 'Servo32' program.
    https://drive.google.com/folderview?id=0B0DJmXrvrE-IemxSdktUTmZHd2s&usp=sharing
    History:
    Version 1 - initial concept
    Version 2 - (03-08-2006) Beta release
    Version 3 - (11-04-2007) Improved servo resolution to 1uS
    Version 4 - (05-03-2009) Ability to disable a servo channel
    and remove channel preset requirement
    Version 5 - (05-08-2009) Added ramping ability
    Version 6 - (07-18-2009) Fixed slight timing skew in ZoneLoop and
    fixed overhead timing latency in ZoneCore
    Version 7 - (08-18-2009) Fixed servo jitter in ramping function when
    servo reached it's target position
    Version 8 - (12-20-2010) Added PUB method to retrieve servo position
    Version 9 - (04-05-2013) cnt rollover issue corrected with ZonePeriod
    by setting up Counter A and using the Phase
    accumulator instead of the cnt
    Note: This also eliminates the need to setup
    a 'NoGlitch' variable
    edited 2013-04-13 15:22
    Thanks for the Link Beau,
    I got my board rebuilt and the Servo 8 Fast code running. I am still having glitching or twitching problems with all 4 motors every once in awhile. It can happen once a minute or 2 or three times in the matter of a couple of seconds. I do not think it is the servo 8 fast code, has anyone else had problems using the servo 8 Fast object, I have it running at 250 Hz. It is version 1.3 I believe. I have beating my head over this for awhile, I am going to change out my receiver and see if that is the problem.
    Shawn
    edited 2013-04-13 16:39
    I am powering my board off the ESC's BEC's. I read that if you have more than one ESC you should not run their BEC's in parallel to power anything. I also read that as long as they are linear BEC's and not switching it does not matter. So I disconnected 3 out of the 4 BEC's from my ESC's and I swapped out my receiver with another one. I did not fly the quad but I ran it at quarter throttle for 7 minutes and held it against the floor, no glitching or twitching. I am going to try and fly it soon. If the glitching and twitching persists then I will dig further into the code.
    Shawn
    edited 2013-04-13 17:06
    Problem still remains, this is my main flight loop. Can you guys look at how the repeat loop is timed and tell me if there is a problem with my loop timing? I want to run this loop at 250Hz. I am using the DbgCountLow and DbgCountHigh to determine how long all of my routines take. They take about 2.1mS. 250Hz is 4mS in-between loops so I use this at the end to wait until 4 mS is up.
        waitcnt( constant(80_000_000 / 250) + LastTime)
        LastTime += constant(80_000_000 / 250)
    This is my main flight loop.
    PUB Flight
      LastTime := cnt
      Repeat
        DbgCountLow  := cnt                                 'Used to time Flight loop.
        Check_Armed_Status
        Get_RC
        Get_GYRO
        Convert_GYRO_2_Angle
        Convert_ACC_2_Angle
        LowPass_Filter_ACC
        Complimentary_Filter
        Change_RC_2_Angle
        If ARMED == TRUE
          DoInt := True
          Roll_PID
          Pitch_PID
          Yaw_PID
          Motor_Output_Calc
          Write_to_ESC
        Else
          IErrorRoll  := 0
          IErrorPitch := 0
          DoInt := False
          Check_Gestures
        DbgCountHigh  := cnt
        Debug[34] := DbgCountLow
        Debug[35] := DbgCountHigh
        Debug[36] := DbgCountHigh - DbgCountLow
    Shawn
  • JonnyMacJonnyMac Posts: 9,558
    edited 2013-04-13 21:46
    If you want to run at 250Hz setting up the loop timing is easier than what you're doing:
    t := cnt
      repeat
        ' loop code
        waitcnt(t += constant(80_000_000 / 250))
    Have you started analyzing time required by your calls? One of many great things about the Propeller is that it can time itself:
    tix := -cnt
      ' code to test
      tix += cnt - 544
    Finally... move your debug elements to another cog. You don't want to be putting code is tight loop that does not belong there in production.
    edited 2013-04-14 06:45
    Thanks Jonny
    After the waitcnt(t += constant(80_000_000 / 250))wouldn't I still have to have a t:= cnt? Also and I appreciate the help, but other than a waste of code can you see a problem with running my loop like that. I haven't fully worked my head around your example yet.
    I tried a few more things last night and I am still having problems. I am assuming all 4 motors(esc's) are glitching or twitching at the same time. When it happens the whole quad jerks up about a inch or two. If it was just one motor I do not think it would behave this way I think it would veer off in a random direction depending on which motor glitched. Unless it is only one motor(esc) and the PID loops are compensating for it and trying to maintain attitude.
    Another thought that has occurred to me and I hope this is not the case because I don't understand it and I don't see it done that often in the code I look at. In my flight loop I have a routine that writes the motor outputs. My flight loop runs in 1 cog and my Servo8Fast code runs in another cog. Is it possible that Write_to_ESC routine is calling the object while the Servo8Fast object is trying to update its PMW value. Is a person supposed to use locks when 2 Cogs are using the same variable. Below is how I am setting the PMW values from my main flight loop, very simple.
    PUB Write_to_ESC
    '>>>>>>>>>>> This Section Takes uS
      ESC.Set(FL_MOTOR,Output[0])
      ESC.Set(FR_MOTOR,Output[1])
      ESC.Set(BR_MOTOR,Output[2])
      ESC.Set(BL_MOTOR,Output[3])
      Debug[6]  := Output[0]
      Debug[7]  := Output[1]
      Debug[8]  := Output[2]
      Debug[9]  := Output[3]
    Shawn
    edited 2013-04-14 06:58
    Another thought I just had, maybe my ESC's do not like the 3.3V they are receiving and every once in awhile they are freaking out. When I set the timing up for my ESC's with the remote I think I set it for medium. I am not sure really where that should be set I think it depends on how many poles the motor has. I wouldn't think that would make it glitch either. I would think it might make it stall out.
    Wow there are just so many things that are involved with a project like this, and when there is something wrong it is very hard to pinpoint a problem.
    I read somewhere that a cap needs to be placed across the signal wire to the ESC's if the length of the wire exceeded a certain length, I do not remember the length of the wire or the value of the cap. Could this be my problem, I think my leads are about 6 to 9 inches long if you include the jumper wire I used on my proto-board?
    The quad is very fun to fly and I don't even notice it while I am flying. I only notice it when I am hovering and trying to have it maintain attitde. It even maintains attitude pretty well by itself, but it scares me when it glitches out by itself.
    Shawn
    edited 2013-04-14 07:05
    Shawna wrote: »
    Not knowing enough about ESC servos, can you quantify the conditions which would cause such a glitch (e.g. pulse too wide)? In which case it should be easy enough to run another cog monitoring the relevant PWM values and tell you about abnormal conditions (short of logging all PWM values). Servo8Fast is only reading them so we should be able to figure out whether they get generated or are an artefact of the object itself.
    edited 2013-04-14 09:51
    No. If you look again you'll see it right before the repeat. It's standard practice to initialize the timer variable immediately before dropping into the synchronized loop. This structure ensures that the loop always consumes the same amount of time. If you reset the timer variable in the loop, you're adding to that time. So... initialize the timer variable right before the loop and update it in the waitcnt() call.
    Doing what you're doing is NOT a problem UNLESS the code in your loop consumes too much time and cnt goes past the waitcnt() target. It's tedious, but testing each call individually may be necessary to analyze where a possible bottleneck is located.
    edited 2013-04-14 11:50
    I may have misspoke, it is not an ESC Servo. I am using ESC's, 4 of them. The servo8fast object can be used to control either of them. The ESC or Servo can be controlled by a PWM signal that is high between 1 and 2 mS and it does this at a rate of 50Hz. The ESC's can handle a faster rate, mine can handle up to 400hz I believe, I should look that up and confirm that, that could be a problem. I used these ESC's on another quad and did not have a problem.
    I cannot really quantify the conditions that would cause this, because I am not sure what is going on. The ESC's are motor controllers, and there are PID loops that are constanly updating the PWM width being sent to the Servo8Fast object so that the quad stays at a desired attitude, with no stick input the quad should just hover parallel to the ground, which it does. So if one only applies throttle the quad should lift straight up into the sky and if one would decrease throttle the quad would fall from the sky.
    My thought was originally that it was my servo code because I wrote it by modifying the servo32 code. I thought that maybe my counter was off and that every once in awhile it was not switching the high time of my PWM signal off fast enough which would cause an increase in RPM's of my motors.
    I don't know, anyways because of your guy's posts and my ramblings I have come up with a few more things to check, thank you all.
    Jonny, what is the -544? Is that the amount of clock cycles it takes to execute those 2 linesof code? Are you thinking maybe I am missing my cnt and my loop cycles are getting messed up? If I missed a handful of loops in any given second that could cause erratic behavor. I thought I had plenty of overhead but I will investigate further.
      tix := -cnt
    ' code to test
      tix += cnt - 544
    Shawn
    edited 2013-04-14 12:44
    So are you using or have you tried the new Sevo32 code? Which has some recently found glitch bugs fixed.
    [URL]http://forums.parallax.com/showthread.php/147219-CODE-UPDATE-Servo32v9[/URL]
    edited 2013-04-14 13:11
    No I have not tryed the new Servo32v9 code, that is a good question Heater. The reason I did not try it is because of the refresh rate, 50hz is to slow in my opinion. I am not sure that the refresh rate is changeable without a lot of work and I already failed at making a servo driver. Why reinvent the wheel? The only real reason I wrote my Servo driver before is because I wanted to run my ESC's at 400hz. I found that 400hz is ridiculous and 250hz should be fine. My thought is, other people are using the Servo8Fast code and not having any problems, so it must be a problem in my code. I will try it if I cannot find any problems in my code. I am not great at programming, and I appreciate the help people are willing to give. Because of this I try not to jump the gun and lay blame on other peoples code. This thread started with me placing blame on my interpretation of the Servo8Fast code. Now that I am still having problems, I will tear through my code more.
    The other flight control board I have I was told has a 400hz refresh rate for the ESC's. This other Flight Controller is the one I used these ESC's with before. I am going to get the scope out and verify that my other FC is actually refreshing that fast. It is possible that it is not, and my ESC's won't handle 400hz or even 250hz.
    Thanks for the input Heater
    Shawn
    edited 2013-04-14 13:22
    Wow, my other flight controller is running at 500Hz.
    I just scoped the output pin.
    edited 2013-04-14 13:32
    To be honest I have not looked at any Propeller servo code seriously or played with ESCs ever.
    However I now have to ask what is the motivation for wanting a faster than 50Hz rate on a PWM signal driving motor speed? I'm rather surprised at the idea of being able to control the speed of a motor, with it's inertia plus that of the propeller, at such a rate.
    It would be a nice experiment to measure the acceleration and decceleration achievable with various PWM frequencies. My gut, which is often wrong, tells me there might not be much to be gained with increasing frequency past 50Hz.
    edited 2013-04-14 14:11
    Well I just tried the new servo code and had the same issues.
    That would be an interesting experiment Heater. I think the theory behind the faster refresh rate is........... the faster the motors can be updated the smoother and more responsive the machine will fly. Interestingly enough when I just switched to the new servo code to try, my motors were refreshing at 50hz. I did not notice much of a difference in its flight characteristics. To be honest though, I did not really fly it around. I got the quad of the ground for about ten seconds and it glitched twice so I set it back down.
    Time to dig into my code.
    Shawn
    edited 2013-04-14 14:21
    Could a faulty 3cell lipo battery be causing this. I am trying to think back to my first couple of flights and I don't remember having this problem. I was playing with the PID loops and I decided I wanted more flight time so I switched batteries.
    I am still brain storming because I can't find a problem with my code. I am going to reprogram my ESC's and switch batteries.
    edited 2013-04-14 14:40
    Batteries...good idea to elliminate unknowns. I'd be tempted to exercise everything using a bench power supply.
    How is the supply to the Prop itself?
    As for PWM rate, yes I guess faster is better but at some point no improvement will be noticeable. As I say you have all the enertial of all those big heavy mechanical parts, motor and propeller slowing things down. When it comes to responsiveness of the entire machine you have the inertial of the whole copter to overcome as well.
    edited 2013-04-14 15:15
    The supply is coming off of one of the BEC's from one of my ESC's I do not think that is the problem but it could be. This is the board I am using.
    http://www.parallax.com/Store/Microcontrollers/PropellerDevelopmentBoards/tabid/514/CategoryID/73/List/0/SortField/0/catpageindex/2/Level/a/ProductID/878/Default.aspx
    The BEC supplies 5V to the Vin on this board. The Vin says it will handle 5-16V. I suppose if I am pulling a lot of current from the battery the output of my BEC may drop below 5v but if it does it can't be much. I think the battery pack fully charged is only 12 or 13 volts. I suppose I could hook it directly to the input of my proto board. I figured if I let the BEC from my ESC drop the voltage down to 5v then the regulator on my proto board would not have to dissipate so much heat.
    There is more than likely a problem with my code, but I have yet to find it.
    I just reprogrammed my ESC's and was really excited, I hovered the quad for about 3 minutes with no glitches, then it twitched and glitched. I continued to hover it for another couple minutes and it glitched one more time. When I say glitch or twitch, its like I goosed the throttle for just a fraction of a second. Everything is flying smooth then goose, and then everything is fine again. Its really weird. I was really bummed the first time it happened and I actually fried a Prop trying to trouble shoot the outputs.
    Being able to bounce ideas off you guys is awesome.
    Shawn
    edited 2013-04-14 17:42
    I just took it for another test "hover". I reprogrammed the ESC's again and change the timing to high. The quad doesn't handle breezes very well but I tried hovering it anyway, there was no noticeable glitches or twitches I am not sure if it was because the timing fixed the issue or if I was bouncing around too much to notice. Or if the timing degraded the motors performance to much and it kind of just muffled the glitches. Its hard to tell because there was too much of a breeze. I drained a whole battery which is about ten minutes. I may not have ever had it stable enough to notice any glitches. I don't think it is supposed to be windy tomorrow. Time to hang out with the family.
    Later
    I think I found the problem. Normally throttle range on a transmitter is 1000 to 2000uS. I adjusted my throtle range via my transmitter for a range of 1000 to 1650uS to allow my PID's to be able to add more throttle, to stabilize the quad, even when my transmitter throttle is at max. When I did this I programmed my ESC's with this same range and I don't think they liked that. I should have programmed my ESC's with the 1000 to 2000uS range and then adjusted my max throttle. I am pretty sure this is the problem. I have hovered through 3 batteries now with no noticeable glitches or twitches. It still has been breezy and hard to control but I think I got it.
    Thanks for listening to me ramble, and offering me suggestions of what to look for guys.
    Shawn
