Saving the Program? — Parallax Forums
Saving the Program?
AndroidAndroid Posts: 82
edited 2013-04-03 19:01 in Propeller 1
Hi everyone i am new to the propeller and was confused about something. I usually use the stamp and after you turn it off it saves the program. I turned off the propeller and had to reload the program. Is it suppose to save it?
    edited 2013-04-03 18:59
    Using F10 to load RAM on the propeller only loads the Propeller's RAM, so once power is removed, the program is lost. Using F11 to load the program to EEPROM will load the program into the EEPROM. Upon powering up the Propeller, it will load the program from EEPROM which does not lose the program when powered off.
  • AndroidAndroid Posts: 82
    Thank you so much! That was extremely helpful!
    -Android
