Buffering MCU output for remote servo control?
Hello.
I'm building custom wildlife observation camera, which will be controlled using basic stamp and servos (up/down, left/right, zoom in/out, focus in/out). The control panel will be away from camera itself with servos about 30 feet. I want to deliver steady signal to servos, and also protect MCU from short circuit, hot plug, static and so on. This is why I want to buffer control outputs (servos will receive power from separate, stabilized power supply). Currently, I have the following IC in stock, and I want to re-use them, without need for buying something else. These IC's are:
CD4050
74HC04
ULQ2803
Which one will be the best choice?
CD4050
74HC04
ULQ2803
You might want to use 4 twisted pairs for the 4 servos with a ground for each. That will help keep the control pulses from coupling through to each other over the long cable. You could use CAT5 cable for that and a separate cable for the servo power.
