Scaling Accelerometer Output
I have an LSM303DLHC accelerometer (product page), and it has a built in three axis accelerometer. I can successfully read it, and I get the following values (taken from a selection on the bus, as told by reading the I2C bus with a logic analyzer):
z: 0000010101100000 = 1376 decimal
z: 0000010100110000 = 1328
x: 1111111111010000 = -48
z: 0000010101110000 = 1392
x: 0000000000010000 = 16
y: 0000000000000000 = 0
The accelerometer is resting flat on the table, so the X and Y axes should be 0, while the Z axis should be 1 g. The accelerometer is in high resolution +-16g mode.
The datasheet says that there is a sensitivity of 12 mg/LSB (in +- 16 g mode). So, if I multiply the reading that I expect to be ~1.0g, then I get
1376 * 0.012g = 16.512g
Which is obviously too much. What is the algorithm to get the reading more reasonable?
John Abshier
It suggests taking two readings with the accelerometer rotated 180 to establish 1g and also to measure its sensitivity.
So maybe your supposed to use the technique to come up with your own conversion factor?
BTW, Wouldn't the +-2g mode be higher resolution than the the +-16g mode? You'd of course loose range of detection by using the 2g mode but I'd think 16-bits over a 4g range (-2 to +2) would offer more precision that the same 16-bits over a 32g range.
I'm basing this on the sample Arduino code from Pololu: https://github.com/pololu/LSM303/blob/master/LSM303/LSM303.cpp
I couldn't find any documentation on this feature, but it seems to work.
re High Resolution Mode: the CTRL_REG4_A (23h) register has a bit that enables high resolution mode. What does that mean? I have no idea: it's not documented anywhere in the datasheet. But, I think I'd prefer high resolution, so I enabled it.
And, my guess is that the +-16g mode does not use the full 12 bit range of values. This is from the linear acceleration sensitivity table:
For each of the first three levels, the +-g count doubles and the resolution halves. For the +-16 level, the +-g range doubles but the resolution is less than 1/2 the previous. In any case, just an interesting note.
Did you ever get spin code working for this device? If so, do you mind posting it? I've got the same device and I've not been able to get it working. I'm pretty sure it's my implementation of the I2C stuff, but I'm using Mike Green's object and it still doesn't work. It's be nice to test it with some code that is known to work before concluding there's a hardware problem.
Peter
I never tried for Spin code. Instead, I went for libpropeller C++ code. That's open source, and can be found here: https://github.com/libpropeller/libpropeller/blob/master/libpropeller/lsm303dlhc/lsm303dlhc.h
The only oddity I notice in this chip is that bit-7 of the register address needs to be set in order to auto-increment.
See if this gets any readings:
LSM303DLHC demo - Archive.zip
Chris
