Memory Storage Management - bug???
I am getting wierd results when I use "ES" as the Key to store a string.
When I use "Es" or any other character such as "E1" it works properly.
These are the values I write, followed by those read back.
______________________________________________________________________
MemWriteAll
Key : Data
SE!!!!!! : SE,0,0,0,0,2!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Code: -1
VI!!!!!! : VI,0,50,50!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Code: -1
F0!!!!!! : F0,80,80,0,0,100!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Code: -1
F1!!!!!! : F1,80,80,0,0,100!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Code: -1
F2!!!!!! : F2,80,80,0,0,100!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Code: -1
F3!!!!!! : F3,80,80,0,0,100!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Code: -1
F4!!!!!! : F4,80,80,0,0,100!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Code: -1
F5!!!!!! : F5,80,80,0,0,100!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Code: -1
PT!!!!!! : PT,NNNNNNNNNNNNNNNNNNNNNNNNNNNNNN,1000!!!!!!!!! Code: -1
ES!!!!!! : ES,50,50,150,100,50,100,0,1,150,150!!!!!!!!!!!! Code: -1
Free Table Entries: 1014
Free Name Space: 16224
Free Data Space: 7647
MemReadAll
Full list of names: 10
ES!!!!!! : F2,80,80,0,0,100!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
When I change the key "ES" to "Es" it works properly.
MemWriteAll
Key : Data
Es!!!!!! : Es,50,50,150,100,50,100,0,1,150,150!!!!!!!!!!!! Code: -1
MemReadAll
This is the code creating the string for "ES"
Pri MemSaveEStim1
MemClearVars 'I clear the variable strings using ByteFill and set them to "!" so they display easily
Tx[0]:="E"
TxPtr.byte:=1
Tx[TxPtr++]:="S" 'This is where I can change the "S" to "s" or "1" or "2" or anything else that I have tested!
Tx[TxPtr++]:=","
ByteMove(@StrKey,@Tx,2)
RF.str(@StrKey)
RF.str(String(" : "))
DecToString(EStimStart)
Tx[TxPtr++]:=","
DecToString(EStimEnd)
Tx[TxPtr++]:=","
DecToString(EStimFreq1)
Tx[TxPtr++]:=","
DecToString(EStimFreq2)
Tx[TxPtr++]:=","
DecToString(EStimPower1)
Tx[TxPtr++]:=","
DecToString(EStimPower2)
Tx[TxPtr++]:=","
DecToString(EStimOn)
Tx[TxPtr++]:=","
DecToString(EStimPolarity)
Tx[TxPtr++]:=","
DecToString(EStimPW1)
Tx[TxPtr++]:=","
DecToString(EStimPW2)
'Tx[TxPtr]:=0
ByteMove(@StrData,@Tx,TxPtr)
RF.str(@Tx)
RF.str(String(" Code: "))
RF.dec(MEM.Create_Str(@StrKey,@StrData))
RF.Str(string(RF#NL,RF#LF))
Return
It does the same thing if I use
MEM.Edit_Create_Str(@StrKey,@StrData)
I have tried changing locations in EProm, as well as the welterweight module.
For now, I will just change to a "s" so I can finish my project.
If anyone wants more code, email me. Gaylan@WardOffice.com
Gaylan
MemWriteAll
Key : Data
MemReadAll
MemWriteAll
Key : Data
MemReadAll
Pri MemSaveEStim1
Tx[0]:="E"
TxPtr.byte:=1
Tx[TxPtr++]:=","
RF.str(@StrKey)
Tx[TxPtr++]:=","
Tx[TxPtr++]:=","
Tx[TxPtr++]:=","
Tx[TxPtr++]:=","
Tx[TxPtr++]:=","
Tx[TxPtr++]:=","
Tx[TxPtr++]:=","
Tx[TxPtr++]:=","
Tx[TxPtr++]:=","
'Tx[TxPtr]:=0
RF.str(@Tx)
Return
Gaylan
EDIT: I just did a quick test with a value name of "ES" and nothing special seemed to happen, but I would like to understand how you encountered the bug some more to try to replicate it.
EDIT2: I think I see what is happening, "ES" and "F2" both produce the same hash/checksum (but it should know that and still not mess up), so it does appear to be a bug, let me try some more things.
EDIT3: I just did another simple test of storing to both "ES" and "F2" and it calls the values back correctly. I'm going to need a copy of your program to continue...
What version of MSM are you using?
Thanks for responding. You wrote a great EProm storage program! Thanks! -Gaylan
MemTest.spin
PRI getaddr (nameAddr, tblAddr) | v[2], ptr, ptr2, n[name_size / 4] '' return address for an existing entry name_truncate(nameAddr) ptr2 := ptr := gethash(nameAddr) bytemove(@n, nameAddr, name_size) ' for an unknown reason, nameAddr gets overwritten when the read() is called below, so it must be backed up REPEAT UNTIL (ptr + 2 == ptr2) longmove(@v, @table[ptr], 2) IF (v[0] == 0) QUIT IF (strcomp(read(v[0] >> 16, v.byte[1]), @n)) bytemove(tblAddr, @v, 8) RETURN ptr IF ((ptr += 2) => table_size) ptr := 0 bytefill(tblAddr, 0, 8) RETURN -1Let me know how that works out for you.
It makes me happy knowing there isn't really a bug, because I rely on this object a lot in day-to-day use, and I just assumed it was working correctly from my previous testing and lack of anomalies. Good to have peace of mind.
This all brings to light, though, the poorly executed hash/checksum method I have. I didn't spend a whole lot of time on it, and now I think I should spend more time. Collisions like that shouldn't be so common.
