power a BS2 or QS for at least 10+hrs
I was at the sports store, and I saw one of those criter cams that you can place on a tree or were you like, thought can't it be done with a BS2 or a Propeller QS. I want to try this but in a more simple way... With just a PIR sensor,and an eeprom to keep count. I think adding a cam or wireless can strain the battery life for 10hr+ use; since it will be placed out doors I was thinking of using the BS2 OEM since it's off the shelf parts make it more rugged for the elements. Any ideas if this can be done, without going into the $150.00 mark?
Edit: You would still need to protect a Stamp or Prop from the elements. Electronics and water do not mix well!!!
- What is the maximum size/weight?
- What features do you need?
- What battery type do you prefer?
If you just want to count how many times a PIR has been triggered, you could probably use a simple counter chip and display the results on an LED array.
Why not use a pair of 74HC590 chips then? With those, you can count up to 2^16-1 events. They each have 8 outputs, which you can connect to LEDs for reading the result. Of course, you would want to hook the LEDs up to a common switch, so you could turn them off.
All told, the total current consumption would be ~80uA + PIR. The PIR consumes up to 12mA, for a total of ~13mA. A D battery has about 17000mAh in it (source), the device should run for ~54 days (in theory). Simple, and meets the specifications for the cost of a PIR+ a dollar or so.
