Maffs is hard - propeller style
pacman
Why ?
11 x 3.5
(to most normal people this would be 38.5. Heck, I would accept an answer of 38 or 39.
but in the prop it seems to give an answer of -1004534808
snippet of code below.
Is it some sort of wierd overflow thing (but the result is WAY less than a 32 bit number)? Something to do with trying to mush a floating point into the prop?
I'm confused - please explain.
I do notice that
gives a much closer answer.
What am I miss-thinking?
11 x 3.5
PST.newline PST.dec(11 * 3.5)
I do notice that
PST.newline PST.dec(11 * 35 / 10)
So 10 / 3 can only be 3 because there is no way to represent 0.333333.....
Although you can use // to get the remainder of a division which will be 1 in this case.
However Spin does allow you to write real numbers like 2.3 in which case it encodes them in floating point format as kuroneko points out. This is in case you want to use one of the objects that does floating pint arithmetic, F32 for example. Or in case Spin gets floating point types at some point in the future I guess.
You cannot mic up floating point numbers with normal integers in your expressions.
You can always scale your numbers up and then work with them. So for example scaling all your numbers by 10 will give your first example as (110 * 35) which will get you a result of 3850. Scale that back down by 10 and you have 385 which is the 38.5 answer you wanted scaled by 10.
Choose your scaling to get you the precision you want and be careful of overflowing with big numbers.
Google is your friend: http://en.wikipedia.org/wiki/Single-precision_floating-point_format
Basically the format has a sign bit in the top bit. Followed by 8 bits of exponent. Followed by 23 bits of fraction.
Things get a bit complicated because the sign bit is not used as it is in twos comp. If it's set your number is negative so you can have both plus zero and minus zero. The exponent is a biased 8 bit value representing a range -128 to +127. It is a biased value such that 127 is actually zero.
Then we have problems with normalized numbers. Normalized means that the number is always shifted up to be of the form 1.xxxx But as the first digit is always one we don't need to include it in the representation. So 0.1 binary will comeout with the 1 bit up un the 22nd bit position of a 32 bit word.
Of course not all numbers are normalized....
Then we have to represent infinity and Not A Number (NaN) which have special encodings.
It all gets very complicated.
It's only four bytes or 32 bits and the Propeller is a 32-bit device! It's the standard for single-precision arithmetic.
I used to having to do 'scaling' in my normal day-to-day job working with PLC's so it all makes sense
Why I didn't twig to the propellor is a bit of a mystery - perhaps it's that I could enter a decimal value - most PLCs (when woring in 'integer space' dont let you put in the '.' so it's a bit more obvious).
You might be interested to hear about things called "search engines" - they are very handy for this kind of enquiry
Essentially it is a binary search tree. In your example you want to multiply 11 by 3.5 ... .
Since a binary search tree requires a reference value for LOW and HIGH, we can set the LOW to 0, but for the HIGH we must calculate the value.
RefHIGH = ( 1024 / 3.5 ) = 292
... Ok, I cheated a bit, the RefHIGH rolls the scaling of 3.5 that we want to use into the equation with a 10 -bit (That's the 1024) resolution for the output.
CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 OBJ PST : "Parallax Serial Terminal" VAR long Data PUB start PST.Start(19200{<- Baud}) RefHIGH := 292 RefLOW := 0 Data := 11 BitRes := 10 cognew(@SAN, @Data) 'Note: input Data gets re-written with the result repeat PST.bin(Data,10) PST.Char(9{<- TAB character}) PST.dec(Data) PST.Char(13{<- Return character}) DAT org 0 SAN'routine '(SAN) Successive Approximation BASE-2 Normalization rdlong _Data, par 'Read Data value mov t1, #0 'Clear t1 mov Counter, BitRes BitLoop '---------------------------------------------------------------------------------------------------------- mov RefMID, RefHIGH 'RefMID = (RefHIGH + RefLOW ) / 2 add RefMID, RefLOW shr RefMID, #1 cmp RefMID, _Data wc 'Compare Data and RefMID if_c mov RefLOW, RefMID 'if Data > RefMID ; RefLOW = RefMID if_nc mov RefHIGH, RefMID 'if Data <= RefMID ; RefHIGH = RefMID rcl t1, #1 'Rotate "C" into t1's LSB djnz Counter, #BitLoop 'Get next Bit '---------------------------------------------------------------------------------------------------------- wrlong t1, par 'Place result in Data Cogid t1 'Stop COG cogstop t1 Counter long 0 t1 long 0 _Data long 0 BitRes long 0 RefHIGH long 0 RefLOW long 0 RefMID long 0The above will produce an output of 39 if the input value is 11
So why 10-bits? ... If you multiply your input by 16 , so 11 becomes 176 then the code above produces a value of 619 on the output. The lowest range that 619 can 'fit' is in a 10-bit value. Looking at it this way if you shift the result right by 4 you effectively divide by 16 and you will see 38 as a result, but if you also look at the lower nibble (4-bits) first, then the value is 11 ... or 11/16ths ....or 0.6875 .... combine that with the 38 and you have 38.6875 .... a crude floating point if you will. The reason that it's not exactly 38.5 is because of truncating and bit level repeating mentioned earlier.
Search engines don't operate well without the proper search terms. When a people asks for help as above, its typically because they do not know the proper search terms. Responding with a link or the proper search terms (as heater did) is useful; your response was not.
Sorry, but this just bugs me and I see it often. We prefer folks to ask trivial questions rather than make extreme mistakes. Discouraging questions is no longer considered "best practice".
