VGA 1024x768@60Hz signaling, 256x192 pixel @ 15bpp driver (32K colors)
Bill Henning
Here is the VGA equivalent of the HDTV bitmapped driver I posted.
- 1024x768@60Hz VESA timing
- 256x192 bitmap
- 15 bits per pixel R5G5B5
- DE2-115 only, uses 96KB frame buffer starting at $08000
- trivial to change to 16 bit RGB, just change the mode
- starts another cog with the monitor
- you could use the monitor to load 15bpp images
Top left pixel is $08000, set Chip's monitor into word mode, and you can plot pixels by writing to the hub
This VGA version is 256x192 pixels (the HDTV version is 256x144 pixels)
DE0-Nano Notes:
- It actually runs on the DE0-Nano, showing three copies of $00000-$07FFF
- It cannot launch the monitor in a second cog as there is not one on the Nano
Enjoy :-)
- 256x192 bitmap
DE0-Nano Notes:
Enjoy :-)
I hope you have time soon, the video features of P2 are immensely superior to the P1 - very easy to use, extremely flexible.
Yes, I can see that - it's simply mind-blowing!!!. I am leaving the video for you and others to experiment with.
I have way too much other bits on my plate - debug and the spin interpreter
Thanks Bill! . I ran it on my Acer 22" monitor.
