Propeller Demo Board heat issues?
I am working on a project that runs two US Digital optical shaft encoders (http://www.usdigital.com/products/encoders/incremental/rotary/shaft/h6?specification=single-ended-electrical) and one Parallax 4x20 LCD Screen and I notice the two chips between the power supply adapter port and the serial port get extremely hot when the encoders are running. Is this common or should I be concerned?
Hot generally is 'stressfull' ... what hardware are you using? PPDB, Proto?
...Tim
PS - never mind, just saw the subject line. Sorry about that.
Thank you for your feedback. It is indeed the regulator chips that are running hot. I am also powering the encoders from the board. Do you believe this is a damaging amount of current draw?
Thats a good idea ... and if it turns out to be too much, consider the E4P (I have several). Much smaller and you can run 2 of them on less current than your present encoder.
http://www.usdigital.com/products/encoders/incremental/rotary/kit/E4P
... Tim
