Trimming SIP resistors
I sometimes trim SIP resistor arrays to fewer pins using a pair of diagonal cutters. They cut cleanly, and testing shows the resistance from common to each remaining pin is not immediately affected. Is this a common accepted practice, or could it somehow damage the resistor and the damage not be evident until later? I haven't been able to find any info on this from any authoritative source on the web.
Although I have seen other people do it as well I would try to avoid it. I would never do this for a finished design or project. If I saw that on a production product it would make me question the rest of the device. If you are building a prototype then I suppose you could get away with it but instead just leave the other pins unconnected.
Just my opinion.
to the elements.
