How to reset P2 — Parallax Forums
How to reset P2
David BetzDavid Betz Posts: 14,526
edited 2013-03-17 20:28 in Propeller 2
How do I cause the P2 to reboot programmatically? I'm working on code to boot a large program from flash and I'd like to force a reboot after writing the flash. What's the best way to cause the P2 to reboot?
  • David BetzDavid Betz Posts: 14,526
    edited 2013-03-17 05:40
    And another related question: Can someone remind me of the magic incantation to relaunch the monitor? Obviously, it's a coginit instruction but what is the base address of the monitor in ROM?
    edited 2013-03-17 11:22
    David Betz wrote: »
    Attempting to answer my own question, is this the code I need to relaunch the current COG with Chip's monitor program? I stole this from the ROM loader.
    CON
      SERIAL_TX = 90        ' serial pins
      SERIAL_RX = 91
    DAT
                            coginit monitor_pgm, monitor_ptr    'relaunch cog0 with monitor
    monitor_pgm             long    $55C+$1B4                   'monitor program address
    monitor_ptr             long    SERIAL_TX<<9 + SERIAL_RX    'monitor parameter (conveys pins)
  • SapiehaSapieha Posts: 2,964
    edited 2013-03-17 11:30
    Hi David.
    When a COG is started, $1F8 contiguous longs are read from HUB memory and written to COG registers
    $000..$1F7. The COG will then begin execution at $000. This process takes 1,016 clocks.
    Example:
            COGID   COGNUM           'what COG am I?
            SETCOG  COGNUM           'set my COG number
            COGINIT COGPGM,COGPTR    'restart me with the ROM Monitor
    COGPGM  LONG    $0070C           'address of the ROM Monitor
    COGPTR  LONG    90<<9 + 91       'tx = P90, rx = P91
    COGNUM  RES     1
    'If you want to inspect hub memory after your program has run,
    ' just put the following code at the end of your program:
    Code:
            coginit monitor_pgm,monitor_ptr 'relaunch cog0 with monitor
    monitor_pgm long    $70C            'monitor program address
    monitor_ptr long    90<<9 + 91      'monitor parameter (conveys tx/rx pins)
    'This will launch the ROM Monitor and let you view what your program did to hub memory.
    ' The monitor only affects the hub memory when you give it a command to do so. So, when
    ' the monitor starts up, hub memory is just as your program left it, ready to be inspected.
    edited 2013-03-17 11:41
    Sapieha wrote: »
    Hi David.
    Example:
    COGNUM  RES     1
    Code:
    Thanks! It's odd that your address for the monitor is $70C but the one in Chip's boot ROM listing is $55C+$1B4=$710. Any idea why there is a difference? Yours works though and the one I got from Chip's listing doesn't although I'm sure it is due to my own misunderstanding what Chip's code does. Anyway, thanks for your help!!
    edited 2013-03-17 11:55
    Hi
    That example come from Chip.
    In dump that address starts with Long - 0
    But I have not looked yet why Chip starts at this point.
    David Betz wrote: »
    edited 2013-03-17 11:57
    Sapieha wrote: »
    Hi
    Since we're on a roll here, can you tell me how to reset the P2 from my PASM code? I'd like to reboot after writing to the SPI flash.
    edited 2013-03-17 12:02
    Hi David.
    _________
    CLKSET  D
    CLKSET writes the lower 9 bits of D to the HUB clock register:
    %R_MMMM_XX_SS
    R = 1 for hardware reset, 0 for continued operation
    MMMM = PLL multiplying factor for XI pin input:
            % 0000 for PLL disabled
            % 0001..% 1111 for 2..16 multiply (XX must be set for XI input or XI/XO crystal oscillator)
    MMMM = PLL mode:
            % 0000 for disabled, else XX must be set for XI input or XI/XO crystal oscillator
            % 0001 for multiply XI by 2
            % 0010 for multiply XI by 3
            % 0011 for multiply XI by 4
            % 0100 for multiply XI by 5
            % 0101 for multiply XI by 6
            % 0110 for multiply XI by 7
            % 0111 for multiply XI by 8
            % 1000 for multiply XI by 9
            % 1001 for multiply XI by 10
            % 1010 for multiply XI by 11
            % 1011 for multiply XI by 12
            % 1100 for multiply XI by 13
            % 1101 for multiply XI by 14
            % 1110 for multiply XI by 15
            % 1111 for multiply XI by 16
    XX = XI/XO pin mode:
            00 for XI       reads low, XO floats
            01 for XI       input, XO floats
            10 for XI/XO    crystal oscillator with 15pF internal loading and 1M-ohm feedback
            11 for XI/XO    crystal oscillator with 30pF internal loading and 1M-ohm feedback
    SS = Clock selector:
            00 for RCFAST (~20MHz)
            01 for RCSLOW (~20KHz)
            10 for XTAL   (10MHz-20MHz)
            11 for PLL
    David Betz wrote: »
    edited 2013-03-17 12:21
    Sapieha wrote: »
    Hi David.
    _________
    CLKSET  D
    %R_MMMM_XX_SS
    MMMM = PLL mode:
            11 for PLL
    Thanks again! I guess I wouldn't have thought of using CLKSET to do a reset. From what you list it sounds like this will reset the P2:
        clkset #$100
    Does that sound right?
    edited 2013-03-17 12:25
    David Betz wrote: »
        clkset #$100
    Sorry, I guess it has to be this:
        mov     t1, #0x100 'hardware reset
        clkset  t1
    Anyway, CLKSET works fine and so does my flash loader test! Thanks!!
    edited 2013-03-17 12:26
    Hi Dvid
    In Yours example You will reset it to
    Because the the clock register is cleared to % 0_0000_00_00 on reset, the chip starts up in RCFAST mode
    with both the crystal oscillator and the PLL disabled.
    You need in same time set other value3s to what You want.
    David Betz wrote: »
        clkset #$[COLOR=#ff0000][B]1[/B][/COLOR]00
    edited 2013-03-17 19:27
    Thanks to the help I got in this thread, I got the flash loader working. I'm now able to write a C program to flash so it will boot on reset. I've got a few problems to iron out and I'll push the changes. Anyway, thanks Sapieha for your help!
    edited 2013-03-17 20:26
    Nice work guys - very useful.
    David Betz wrote: »
    I've pushed the propeller-load changes. You can now use the propeller-load -e option to write a program to the flash and have it boot on reset. We still don't have support for XMM mode yet though so you're limited to COG, LMM, or CMM programs at the moment. However, your LMM or CMM program can use all of the 126k of hub memory.
