Combining codes of Ping))) Sensor and Servo connected to Propeller Board inside S2
Hi, I am currently working an S2 robot with a Propeller Board inside(I remember it being a Propeller BOE). The external hardware added to the robot are the PING))) Ultrasonic Sensor and the Servo(Parallax Standard Servo). I am currently stuck on programming both the sensor and the servo to work at the same time. Here are the codes for the Ping))), The servo, and for the final code, respectively: PING_TEST:
S2_SERVO_TEST:
And the PING_SERVO:
CON
_xinfreq = 5_000_000
_clkmode = xtal1 + pll16x
PING_PIN = 5
PCBAUD = 115_200
obj
d : "Parallax Serial Terminal"
ping : "Ping"
PUB Go
d.start(PCBAUD)
repeat
d.home
d.str(string("Ping distance: "))
d.dec(ping.Millimeters(PING_PIN))
d.str(string(" mm "))
PauseMs(20)
pub PauseMs(duration)
waitcnt(cnt + (clkfreq/1000)*duration)
S2_SERVO_TEST:
con
SERVO_PIN = 4
pub RunServo
'set pin to be an output
dira[SERVO_PIN]~~
repeat
PulseOut(1000, SERVO_PIN)
PulseOut(1500, SERVO_PIN)
PulseOut(2000, SERVO_PIN)
pub PulseOut(time, pin)
repeat 100
outa[pin]~~
waitcnt(cnt + (clkfreq/1_000_000)*time)
outa[pin]~
PauseMs(20)
And the PING_SERVO:
CON
PING_PIN = 5
PCBAUD = 115_200
SERVO_PIN = 4
obj
ping : "Ping"
PUB Go
d.start(PCBAUD)
repeat
d.home
PauseMs(20)
pub RunServo
dira[SERVO_PIN]~~
repeat
repeat 100
outa[pin]~~
outa[pin]~
PauseMs(20)
My classmate told that the main function to work on is the PulseOut function in order to get both the Ping)) sensor and the Servo to work, but I am still unsure.
In essence what you will need to do is have a main routine that continuously executes the ping code, the pulse out code, and whatever other code you need in a repeat loop.
Also, when you post code, use the # icon.
I was thinking of coding methods in the program. Here is what it would be:
PUB callMethod(method,var1,var2....) switch method METHOD1: Go(var1,var2...) METHOD2: PulseOut(var1,var2...) PUB Go(variables) its code under here. PUB PulseOut(variables) its code is under here.I haven't implement the code yet. But, I know that if I were to methods, then I will need to put callMethod in a loop so it does things more than once. Any suggestions to this?Post again and let me know how you did.
I forgot to mention to look at the README file first to see the top object.
