Need 20Mhz crystal for Basic Stamp 2
Can I replace the 20Mhz resonator with a crystal and get better clock accuracy ?
What crystal part number ? Don't see it on the Parallex site. Any other mods to the board needed ?
thanks
Randy
thanks
Randy
The better clock accuracy won't do you much good. There's no way to reference it directly. PAUSEs are already pretty good and the resonator is good enough for serial I/O. For timing most events, the statement execution time provides enough delay so that timing events is problematic. Other than "because it's there", is there a particular reason why you'd want to do this? If you want to time things accurately, how about using an SX or Propeller instead?
Very cute little chip however working like a champ...
