CON
_xinfreq=5_000_000
_clkmode=xtal1+pll16x '80MHz system clock is recommended for stable data transfer
LCD_pin=0 'Propeller pin connected to LCD's "RX" pin
RFID=1 'Propeller pin connected to RFID's "SOUT" pin (through a 1k resistor)
RFID_EN=2 'Propeller pin connected to RFID's "/ENABLE" pin
OBJ
ser : "FullDuplexSerial"
VAR
byte i,RFIDdata[12] 'The RFIDdata array stores ID byte codes read from the RFID
PUB Main
ser.start(31,30,0,19200) 'wait for any input from terminal ser.rx
"Debug.init(LCD_pin,19200,4) 'Initialize the Debug_Lcd object "
" Debug.cursor(0) 'Make the cursor invisible"
" Debug.backlight(true) 'Turn on the backlight "
repeat
ReadRFID 'This method gets the RFID tag's data from the scanner
ser.str(string(DisplayRFID)) 'This method displays the RFID tag's data on the LCD screen
"Debug.gotoxy(0,3) 'Set the LCD screen's cursor to start of the bottom line"
if CheckRFID 'If the return value from the CheckRFID method is one, then the
ser.str(string("Access Granted!")) ' tag's ID matched one of the preprogrammed codes
else 'If the return value from the CheckRFID method is zero, then the
ser.str(string("Access Denied!")) ' tag's ID did not match any of the preprogrammed codes
PUB ReadRFID | bit,time,deltaT
dira[RFID]~ 'Set direction of RFID to be an input
dira[RFID_EN]~~ 'Set direction of RFID_EN to be an output
deltaT:=clkfreq/2400 'Set deltaT to 1/2400th of a second for 2400bps "Baud" rate
outa[RFID_EN]~ 'Enable the RFID reader
repeat i from 0 to 11 'Fill in the 12 byte arrays with data sent from RFID reader
waitpeq(1 << RFID,|< RFID,0) 'Wait for a high-to-low signal on RFID's SOUT pin, which
waitpeq(0 << RFID,|< RFID,0) ' signals the start of the transfer of each packet of 10 data bits
time:=cnt 'Record the counter value at start of each transmission packet
waitcnt(time+=deltaT+deltaT/2) 'Skip the start bit (always zero) and center on the 2nd bit
repeat 8 'Gather 8 bits for each byte of RFID's data
RFIDdata[i]:=RFIDdata[i]<<1 + ina[RFID] 'Shift RFIDdata bits left and add current bit (state of RFID pin)
waitcnt(time+=deltaT) 'Pause for 1/2400th of a second (2400 bits per second)
RFIDdata[i]><=8 'Reverse the order of the bits (RFID scanner sends LSB first)
outa[RFID_EN]~~ 'Disable the RFID reader
PUB DisplayRFID
ser.cls 'Clear the Serial screen
if RFIDdata[0]<>10 or RFIDdata[11]<>13 'All cards should have the same start byte and end byte
ser.str(string("Error! Try Again."))
ReadRFID 'Try running the "ReadRFID" method again
else
repeat i from 1 to 10 'Display each of the 10 unique identification bytes
ser.dec(RFIDdata[i])
ser.str(string(" "))
PUB CheckRFID
repeat i from 0 to 9 'Compare tag's 10 unique ID #s against ID #s stored in data table
if RFIDdata[i+1]<>Tag1[i] and RFIDdata[i+1]<>Tag2[i] and RFIDdata[i+1]<>Tag3[i]
if RFIDdata[i+1]<>Tag4[i] and RFIDdata[i+1]<>Tag5[i] and RFIDdata[i+1]<>Tag6[i] 'etc.
return 0 'If one of the IDs does not match, return a zero
return 1 'If one of the ID sequences matched, return a one
DAT
'i= 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
Tag1 byte 48,70,48,51,48,50,56,53,55,53 '<-- Enter your own RFID tag ID numbers here
Tag2 byte 48,70,48,50,65,54,55,48,69,48
Tag3 byte 48,52,49,54,50,66,66,53,55,54
Tag4 byte 48,70,48,50,65,54,55,50,51,66
Tag5 byte 48,70,48,50,65,54,55,50,51,66
Tag6 byte 48,52,49,54,50,66,66,53,53,54
'etc.
-Tommy
