Newbie tries to build Elev-8
Haha! It is finally here! It was backordered at Christmas but it is finally here!
I've always wanted to build a flying machine. The wife and kids are out for the day, so I get to play with my boy toys...
They told me not to try this one first. (They being Servo mag, This one being Elev-8, FWIW.) But I'm ambitious. I read the articles, and looked over the diagrams. Because I have a middle class mindset, I already have a wide variety of tools. I have a few bucks so I can pick up a few things as needed (as long as I use the credit card the wife doesn't know about). And an above average IQ of 101 (too bad it is utilized in software, not hardware). What, I ask, could possibly go wrong?
Of course as a "freshman" I have yet to learn the list of things I don't yet know. While it is possible someone will learn something from this, it is far more likely that belly laughs will commence from those who have experience. I don't care, have a laugh at my expense! I'm having fun, too!
First tip from a n00b: Buy a lot of stuff. If an expert will spend $1200, you'll spend more (50%? 100%?). Bought the Elev-8. Bought the crash pack. Bought the hex upgrade. The optimist says "my flying minion will be 50% more powerful". The pessimist says "well, at least you have spare parts". (Take a guess which thing I'll do with stuff in the hex upgrade box... the answer will not be long in coming!)
First steps: put bullet connectors and shrink tube on everything. I think I got it, but it took me 4 hours instead of the 20 minutes it would take a pro. And, with the Metcal I picked up used on eBay, which makes anyone capable of making good solder joints. Was very easy to do, and the connections are quite good, but somehow the time just drained away!
Put loctite on the motor set screws. Cross-threaded/stripped one of the twelve. Not looking good for the hex-rotor..., more likely to be parts. But of course you already guessed that. At least for now! I can always order another upgrade kit...
Didn't try to build a power distribution doodad. Bought one instead. (Actually two.. one with six, and one with just 4. You know, in case I lose parts and end up with a quadrotor. In case.) Bought, because time without kiddos in the house is precious, not to waste on mere wiring. Likewise used the Turnigy ESC programmer. Maybe even met the 10 minute time budget the experts expected on that part.
Now on to the mechanicals. (And the laughing.) I started to put a rotor boom together. Sandwiched it all and started adding screws. Guess what - the 4 motor holes don't form a square! Turned the motor a quarter turn so the holes would line up, though it caused some stress on the leads. Then the bullet connectors hit one of the screws that goes through the boom. Then it dawned on me... the bottom motor mount was simply upside down. Flip it and the holes align, the wires go straight in the tube, no conflict with the bullet connectors. Easy peasy.
Well, except for the one boom where the aluminum tube extends too far past the screws and hits the motor. (I have a picture that proves they were NOT all the same.) That one, I figure, I will either hacksaw or hit with the grinder in the garage. (Probably first the saw, then the grinder...) More realistically, it will sit this round out, along with the motor with the repaired set screw, as I fly a quadrotor instead of hex. Still got 5 good booms... the hexrotor can wait!
One other tip for other n00bs - if you are screwing 2 things together, drill out holes in a top layer that are small enough to cause cross-threading (or any other conflicts in threading) for the bottom layer.
That's where I sit now, still finishing motor booms, and putting the hub together. Further updates as events warrant. Don't take it for whining - I'm really having a grand time here!
If I ever do complete this, trust me I will make it a true minion in my army. You know, because that's all about software :-) Haha!
(Dear moderator, if this should be in a more specific forum, please advise / move it.)
~Chuck
PS. I'll get through this, if it's the last thing I do. Or, more likely, build it and never really fly it. Stay tuned.,,
~Chuck
I was told to get a few crashes out of your system on cheap Smile, before you crash the elev-8.
Sounds good to me.
Crash 60 bucks worth of s107g (which buys 2 or 3 plus crash parts) instead of the killer flying robot. Sounds good. Bonus: my nephew and daughter love them. But these el-cheapo things fly by IR, so they are indoor only, and won't even take commands if they are near a 100W (equivalent) CFL. My advice: Buy an RF one if there are CFLs in your best (biggest) flying space.
Welcome to the forums, and welcome to the Flight Club!
Sounds like you're getting a fine start. Let's take care of the boom problems that we must have created - sounds like one was a different length. Well, now that you've broken into your HEX Upgrade kit we must immediately make that kit complete again. Occasionally, we can and do make mistakes. We've now put a QA/QC process in place for the machined parts to prevent this from happening again.
Please drop me a message via e-mail with your shipping and we'll replace that boom. We shall also get you in the air and keep you there for the long term. You're starting a really exciting hobby and it will be truly rewarding.
Sincerely,
Booms assembled, and look plausible. Time to put the center together, tie the ESCs on, and so on. by far the most fun I've had all day. Could take me the rest of the month at my pace, but still a good time.
Was also thinking ahead, in a dreamy sort of way, about how to tell (in software, autonomously) if this thing is moving or not. Outdoors, I can probably use GPS. If 10s of feet is good enough, anyway There are accelerometers for changes in movement, but I don't think they'll accurately tell if the thing is slowly drifting at a constant speed. Indoors I can probably ping))), or use IR, and this might even help me from crashing into the ground outside. No go if 100 ft in the air, in the sunshine, though. Pressure-based altimiters, at least the ones in digital watches, show remarkable sensitivity to changes of a few feet in still conditions, but are off by hundreds of feet if you are hiking up a mountain in the wind (resulting in a bunch of air that wants to be in the same place as the mountain, causing higher pressure / lower elevation reading). I assume houses have a similar effect.
So, partly by accident, I was talking to someone today who knows a bit about computer vision. And I asked his opinion, with high hopes that I could get some tidbits. After all, the optical computer mouse costs ten bucks, senses motion (and direction) quite well, runs for days on a small battery, and has been around for >10 years. Captures 1000s of frames a second with a small, low-res camera. Maybe there's a lesson here... Well:
1. That mouse has the advantage that it lights the surface in a particular way
2. The mouse sees things that are very close / fixed distance, so the velocity is easier to establish than from distant targets.
And, unrelated:
3. If you want to auto-land, consider a pink target. Very rare color out in the wild.
Like I said, mostly a daydream. This thing isn't going anywhere until the props are on, and that's not happening until after I change a poopy diaper right about now :-P But it does cause me to ask: I've seen a lot of camera suggestions for sending video back to the operator... but what is the best kind of camera for onboard processing (like looking for a pink area below the robot, which has GPS'd to within 20 ft of where it is supposed to be)?
ELEV 8 is a nice multi copter but not easy to fly for a beginner , it moves very quickly and the propellers are dangerous while running.
I quite agree with dmagnus : buy a small quadcopter (the Mqx is best because it uses the DX8 like the ELEV 8.
You can also fly a Ladybird or a Hobbyking Q bot). These small quacopters crash without damage and cost around 100 $.
And meet people flying copters, they are always ready to help and give good advices.
Have fun !
I have enough of a challenge flying my Mqx in the house (I have a small house). But I'm learning and even was able to fly from one end of the house to the other and land on a tv table top. :cool:
What about the shop?
Incidentally, my very first flight of an RC helicopter was in a hangar at Andersen Air Force Base in Guam. It was (still is I suppose) an eleven pound gasoline powered heli (17 years, zero crashes). I had training sticks with wiffle balls on the ends. I chose to fly inside a hangar due to the ever present trade winds. Quite nerve racking. The best thing I did for learning to fly was to ditch those stupid training sticks and get to flying it outside. Okay, well the best thing was spending time in a simulator but other than that - I think training sticks are stupid.
Things learned:
Shouldn't have pulled out the BEC pins until after I set the rotation directions with the servo tester. Oh well, I put one back, finished setting the directions, and pulled it again. Each and every one of the ESCs was originally spinning the wrong direction, at odds of 16:1 against. Yet surprising nobody.
ESC music is amusing for 15 seconds or so.
Thanks to CowboyCoder for the tip about black screws that look an awful lot alike. Prevented an almost certain mistake.
Now that it is all put together, it does look quite intimidating. I admit once admonished not to fly it in the house, my mind wandered to thoughts of demolishing all this Christmas Smile we've got stored in here but haven't used in years, robot style. Well, more likely to hurt the robot than anything else at this stage, so first test flight will be in the baseball field across the street. To the dismay of those hoping for a funny "told you so" video.
@SRLM - optical flow is exactly what I was looking for. And someone has already done it. Using a sensor adapted from a computer mouse. Looks very fun to try.
I have looked at all the R/C sites and cannot seem to find any of these for sale. Any ideas where I can get these?
I'm new to R/C and just bought an ELEV-8 with the HEX add-on. I'm an computer engineer with a lot of electronics background.
Thanks in advance and I'm really excited to get this ELEV-8 up and flying.
http://www.google.com/shopping/product/13843179578661839274?q=terminal%20block&hl=en&pws=0&bav=on.2,or.r_qf.&bvm=bv.43287494,d.aWc&biw=1198&bih=821&sa=X&ei=gW1CUY7LJ8abyQGj_YCABA&ved=0CIoBEPMCMAM
Besides the terminal blocks, I've seen a bunch of wires joined together on one side with connectors on the the other.
I used two hexagonal pieces of PCB to join six connectors together.
Here's a picture of my setup.
All the negative connectors were soldered to one PCB and all the positive connectors soldered to the other. I used bare copper wire and solder wick to reinforce the connections both mechanically and electrically. I insulated it with Polymorph.
Since I already had a bunch of batteries with Dean's connectors I used these same connectors on the ELEV-8. I considered switching connectors but I found I liked Dean's better than the connectors that came with the ELEV-8. I think this may be just because I'm used to the Dean's connectors. (BTW, HobbyKing's "T" connectors work with the Dean's and IMO are easier to use. And the HK version are a lot less expensive.)
The above was originally posted in this thread about setting up the radio on the ELEV-8
Make sure and take a look at the list of ELEV-8 links mentioned on post #11 above.
This will work.
I am too lazy to take the 4-port out of the middle of the quadrotor at this time, but I also got an 8-port version of the board. Here's a pic of that one. You can easily see the mounting holes, the bullet connector ports, and if you look closely, the pins for the battery alarm.
Bottom of the picture is a different approach - just wires soldered together. Would consider using on the hex rotor. Maybe. Looking at the hex plate, it doesn't have the same holes as the quad, but I bet I could make them in a few minutes and put the 8-port in there... so still not 100% sure what I'll do when I'm ready to upgrade...
Next set of "tips" that many other people could have told me, if I'd have listened more carefully:
1. Set the fail safes to cut off. I set mine to low throttle, thinking it would soften the crash on landings, but what it really does is make it a menace if the transmitter fails. Like say if, in a panic at seeing jelly beans skittering to and fro, you hit the transmitter power switch. (Man, it takes a while for that thing to boot up again to tell the elev-8 to cut it out...)
2. Don't use a random "servo tester" to calibrate the ESCs. If that's all it took, they could do it at the factory and be done. No, this is an opportunity for the ESC to learn about the radio you actually have, so use that one. (Somewhat miraculously though, the Hoverfly is what the ESC actually hears from, but calibrating with the radio works.) My copter was not doing anything after it armed; the ESCs would just sit there and beep the motors. Recalibrating fixed it in no time.
3. You have to use the "prior version" of the Hoverfly setup program. If you even want to; I think I didn't change anything after the firmware upgrade program.
It seems to me, as an inexperienced person, that the instructions available for the physical build of the bot are quite extensive and easy to follow. Much more knowledge is assumed on the part of the reader with regard to the RC aspect, getting power to the radio receiver (I soldered up a cable to power it from one of the ESCs). But got through it, and would still suggest this kit / project / endeavor to anyone willing to put in the time, money, and effort. You would be doing a lot of reading, at least I did. I didn't mind (half daydreaming most of the time), though I did end up with pieces of incompatible advice I think as I sort of took a mix and match from a few sets of build instructions/reports. But I think I learned more doing it that way.
Next to try it outside, though it is supposed to snow again. Then, to puzzle out how to get a camera on here and make a vid. Got just the subject in mind.
