Usb?, usb??
                    Beings that a couple of people have managed bit banged USB on the Propeller, I was thinking that it should be possible to do bit banged USB with the propeller 2 a lot easier.  If an external parallel to serial/serial to parallel shifter is used maybe even 480Mb/s USB 2.
I am wondering if anyone has thought about this, and if so if any one is working on this as of yet? It seems that if there is full support for at least USB 1.1 that this may be of aid getting the Propeller 2 to be more widely adopted. I do not have a DE0 Nano so I can not do much on this (I am emulating a 4 core Prop2 in software on RISC OS very very slowly), and unfortunately I can not afford a DE0 Nano.
12Mbps "full speed" also should work fine but would probably require a full cog.
480Mbps is clearly impossible
#1 did mention with a serialiser, and I think those were made, but are likely more expensive these days than a FT232H or FT313H
Personally, I'd be quite happy with 1.5mbps for HID, and 12Mbps for serial and maybe bluetooth
I had intended to get LS working porperly on the P1, but just not enough time. Maybe later this year.
