RN-42 Bluetooth example Propeller spin code?
Just received RN-42 Bluetooth Module (#30086)
I found example code for the BASIC Stamp, but could not find example Propeller spin code or wiring diagrams.
Instructions similar to those at http://learn.parallax.com/KickStart would be very nice.
Does anyone have link to Spin example code for RN-42?
Connected RTS and CTS pins.
Set voltage jumper to 3.3v.
Set Baud Rate to 115k by removing jumper 4.
Computer could detect, but not connect to RN-42 module using default passcode (1234).
Real problem was: USB connection to Propeller board could not supply enough current to RN-42 Bluetooth module.
Connected 6v SLA to Propeller board power inputs, then computer could connect to RN-42 module.
Now working using FullDuplexSerial.spin.
