Help Clueless - Basic Stamp 1 for bi-stepper motor, mechical lizards
Hi -
I don't know the first thing about this - so please be very specific with replys! I am building a little mechanical model of a lizard that extends its throat flap (a dewlap) at a specific speed and in a specific pattern (it's for research...).
To control the dewlap I will use a bipolar stepper motor. I have a Basic Stamp 1 starter kit - which includes a Basic Stamp 1 Module and a Super Carrier Board (plus serial cable, serial adapter cord, wires, syntax book).
SO - do I program the module first, and then connect it somehow to the motor? Or will my mechanical lizards have the super carrier attached all the time?
IF its just the module that I connect to the motor (after programming) then
1. how do I connect it to the motor?
2. how do I connect it to the power supply?
3. do I need a driver to interface between the module and the motor?
Also - my super carrier just has a lot of holes where the breadboard should be... Is that right or will I need a breadboard there to make things work?
Ultimately I want to tie these models to trees and leaving them running for a long time, so I want them to be efficient and as small as possible.
Any suggestions would be most appreciated, but if someone could hold me hand and walk me through this step by step - that would be amazing!
Danielle
Danielle
I'm wondering what driver to use for my bipolar stepper motor - how do I connect it all up, with the power sources etc, whether I need a bread board for my super carrier board and whether, after I've programmed the driver, I still require the super carrier board to be attached.
Anything at all would be appreciated.
Thanks in advance.
The BS1 might be able to run from a power source up to maybe 12V depending on the amount of current drawn from the I/O pins. It's a heat issue. Everything above 5V is dissipated as heat. The regulator can provide up to 50mA and at 12V would have to dissipate (12V - 5V = 7V) x 0.05A = about 1/3 W. That's tolerable, but the BS1 will get hot over time.
The very 1st project I did about a year 2 years ago was a 10 minute timer.
I used Perfboard from radio shack and Wire Wrapping techniques to get it working.
For power supply, I used my wife's car cigarette lighter socket.
The only thing that would apply to your application is perhaps the size of this circuit board.
The PerfBoard circuit board, when completed measured 1 1/2" x 2"
This was installed in a plywood housing with the cigarette lighter socket.
I'll attempt to attach a photo here.
If you follow Mike Green's advice, as I did with this project, I believe you will have success.
I hope this helps your endevour
I just was wondering why you would not want to use a servo motor to control your Dewlap flap.
Servo motors are very inexpensive and move back and forth without the technical difficulty of
pulsing the steps of stepper motors.
Just a thought!
http://www.parallax.com/dl/docs/prod/stamps/basicstampman.pdf
