Help locating a pump
NWCCTV
I am looking for an inexpensive, low dc voltage air pump that has enough psi to inflate a 2 liter balloon fairly quickly. I checked on EBay and about all I could find are 3 volt ones that do not have the psi needed. So, if anyone knows where I might find one please let me know.
Duane J
@ElectricAye, Yes, it has to be air.
Also, to clarify, do you need pressure or volume? Balloon inflation usually requires low pressure-high volume.
Edit: I will also be doing a heart but I do not need much air for that feature.
How about using an electric motor powering a crank that pulls on a diaphragm that then actually pulls on the "lungs" much the way the human body does it? It might be less noisy than a pump that actually buzzes air into and out of balloons. Just thinking out loud here.
Yeah, it makes sense. But if what you're aiming for is realistic lung sounds, would it make more sense to implement some kind of sound recording? Doctors are trained to tell the difference between different kinds of lung sounds - pneumonia can create a squeaky sound, for example. Gun shot wounds, if they penetrate the lung, have another sound, etc. You would have lots more flexibility with your dummy if you could integrate recordings, I think, rather than just plain ole huffing and puffing. Besides, I doubt you could mimic human sounds with balloons and pumps very well, but that's just a guess.
Bend an ear to some of these:
http://faculty.etsu.edu/arnall/www/public_html/heartlung/breathsounds/contents.html
Which brings me to another question. Can the Prop play MP3 sounds from an SD card or does it only do .wav?
Edit: First and foremost is to get the mannequin!!!! I am going to hit up the major department stores in my area to see if someone will either donate or sell me one real cheap. I then need to get the skin made and I have a machine shop client that I am going to have cut out the torso once the skin is made. After that it will just be a matter of getting it all working together.
For the pump you may want to consider making your own using a large diameter PVC pipe. With the piston moving back and forth at the breathing rate there would be minimal pump noise.
An expanding balloon is not a good analogy for the lung.
The lung, essentially, isn't elastic. Its more like a bag of constant surface area with a variable volume.
A balloon requires a fair amount of pressure to expand.
The lung needs very little pressure to inflate, what little pressure there is is mostly due to air flow resistance not static pressure.
Anyway, you might want to use a very large balloon that is suitably large at rest.
Or, a plastic bag cut into a lung shape.
We wouldn't want to mislead the little urchins in how the lungs actually work.
Since this technique requires very low pressure a small DC fan can inflate it.
Duane J
