LOOKUP command?
72sonett
I bought a Hitachi compatible LCD and got it to work, using the LOOKUP directive to send a character string to the LCD, like so;
This gives;
where I expected
as the help manual says;
but apparently 'char' keeps the last value it had after running out of the lookup list, not the value it had before entering LOOKUP.
Maybe I'm misunderstanding the help manual?
[FONT=courier new]' {$STAMP BS2sx}
' {$PBASIC 2.5}
' -----[ variables ]-------------------------------------------------------
char VAR Byte ' stuff to send to LCD
i VAR Byte ' index, temp variable
' -----[ Main Program ]----------------------------------------------------
Main:
[/FONT][FONT=courier new] char= " "
[/FONT][FONT=courier new] FOR i = 0 TO 15
LOOKUP i, ["PARALLAX!"], char ' use list to store text
GOSUB Sendtext ' send character to 1x16 pos. LCD
NEXT
DEBUG CR
char= "!"
FOR i = 0 TO 15
LOOKUP i, ["PARALLAX "], char ' use list to store text
GOSUB Sendtext ' send character TO LCD
NEXT
DEBUG CR
END ' done
' =====[ Subroutines ]==================================================
Sendtext:
DEBUG char ' send to PC screen (instead of LCD)
RETURN
[/FONT]
This gives;
PARALLAX!!!!!!!! PARALLAX
where I expected
PARALLAX! PARALLAX !!!!!!!!
If Index is beyond the end of the list, the result variable is unchanged. In the example above, if index were greater than {8}, the message would have reported the result to be {_} (or ! ) , because that's what result {char} contained before LOOKUP executed.
You have LOOKUP in a loop. If you were to put your char = " " or char = "!" inside the loop, then it would act as you are expecting when i>9. Yes, it does then retain its most recent value.
After some trial & error I found that the trailing space in the "PARALLAX_" string effectively blanks the remaining positions of the LCD;
So this loop does exactly what I want;
