pasm question
I'm trying to ramp down a led as a pasm lesson, but can't seem to get it right. I've been copying examples from the manual and slightly changing them. I have a couple questions...
is... "delay long 0" near the bottom considered an unchangeable constant or is it just the starting point and will change if added to? If the "0" is left off is it assumed as a starting point and delay is more like a variable. The main problem here is i'm trying to increment delay with a limit of 80_000_000, so the rate of toggle slows to one second on one second off. Seems pretty straightforward, but it's not working.Any advice would be appreciated
{{ AssemblyToggle.spin }}
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
PUB Main
{Launch cog to toggle P16 endlessly}
cognew(@Toggle, 0) 'Launch new cog
DAT
{Toggle P16}
org 0 'Begin at Cog RAM addr 0
Toggle
mov dira, Pin 'Set Pin to output
mov Time, cnt 'Calculate delay time
:loop
waitcnt time, Delay 'Wait
xor outa, Pin 'Toggle Pin
max Delay, #apex 'limit delay value to 80_000_000
add Delay, #1 'increment delay value
jmp #:loop 'Loop endlessly
Pin long |< 16 'Pin number
Delay long 0 'Clock cycles to delay
apex long 80_000_000
Time res 1 'System Counter Workspace
would add delay to time and in the next Loop wait for that counter-value. But adding 0 means that you already missed the counter-value and that you have to wait for ~50 seconds until the counter passes the value again.
So, in your code you also have a minimum delay which makes the code run as expected (not missing the counter value). This minimum value also depends on the runtime of instructions after the waitcnt,
Delay is a variable which is initialized to be 0, but you can change it anywhere in your code!
mov time, cnt add time, delay waitcnt time, delay2 ' wait for delay waitcnt time, delay3 ' wait for delay2In other words the delay in the instruction sets up the next waitcnt, not this one, so you need to have special case for the first use.The waitcnt instruction behaves like a wait, then an add.
DAT org 0 Toggle mov dira, Pin mov Time, cnt add Time, #9 ' minimum delay to not block :loop waitcnt time, Delay xor outa, Pin add Delay, #1 max Delay, apex jmp #:loop Pin long |< 16 Delay long 22 apex long 80_000_000 Time res 1 fit
