Posting Code Well
Hi. Could the forum moderators place a piece in the General Announcements or the FAQ about posting code so it shows up properly indented?
My original post here: http://forums.parallax.com/showthread.php/146305-SW-Exp-14-Scanning-and-Deboucing-Multiple-Inputs?p=1166829#post1166829 was written with code posted directly from the Basic Stamp Editor but when posted it had no indentation. I asked for help on how to do this to properly which somebody kindly replied.
A simple example of the
example would work.
Let's see if that shows up as an actual program but, you get the idea.
Place your code here
example would work.
Another general tip, is if you 'see' any formatting that you like in a Forum Post, hitting Reply with Quote, reveals the source of that, you can simply copy/paste/edit
