Download latest version of PropBasic for Viewport here... - Page 3 — Parallax Forums
13»
  • andre.nieuwoudtandre.nieuwoudt Posts: 65
    edited 2013-03-03 12:43
    I have just started using ViewPort with PropBasic and there are 2 things which I cannot figure out:
    1) Is it possible to turn the background colours of the Code Window off, i.e. just have a plain white background?
    2) Is it possible to make the Code Window larger and the Info Windows on the left smaller? There does not seem to be a "Drag Handle" to re-size the Code Window horizontally?
  • HannoHanno Posts: 1,130
    edited 2013-03-03 14:01
    Hi Andre,
    1- Currently you can not customize the color syntax highlighting.
    However, ViewPort makes it very easy to use your own editor. Just open the file in both your own editor and in ViewPort. ViewPort will ask you if you want to "reload file" if you make any changes in your editor. Everything will be preserved, even your position in the file.
    2- Yes, you can adjust the size, just mouse to the boundary and drag it.
    Hanno
    edited 2013-03-05 15:14
    Hi Hanno,
    Thanks for the feedback :-)
    Regards
    Andre
  • BeanBean Posts: 8,129
    edited 2013-03-06 05:20
    ToeToast wrote: »
    Since I'm a newbie, please forgive me if this has been covered before. I was curious on how to establish local variables for subroutines contained withing the COGs. I recall that in SX/B you could append a "l_" to the var.
    Here is a typical example of 2 independent subroutines that need to have variables defined. Since having 6 variables defined (a,b,c,d,e,f,) is wasteful of COG ram, what would be the best practice here to have variable names that save on space but also have meaning within the routine ?
    SubRoutine1 SUB
    a VAR LONG
    b VAR LONG
    c VAR LONG
    ' Some code using these variables
    ENDSUB
    SubRoutine2 SUB
    d VAR LONG
    e VAR LONG
    f VAR LONG
    ENDSUB
    I know we could use something like declaring Temp1, Temp2, Temp3 etc outside the 2 routines and then using them within each routine. However, the generic names are meaningless within the context of each routine (I like to give the variable names accurate descriptions based on their role within each routine).
    Many thanks
    Tony
    Tony,
    All VARs in PropBasic are global, but you can alias them like this:
    a VAR LONG
    b VAR a
    In the above example both a and b will use the same memory location. So you can create some temp vars, then alias them at the beginning of your subroutines so you can call them something descriptive.
    Bean
    edited 2013-04-19 08:22
    Hi Hanno,
    Just a question regarding the Compile (Shift + F8) statistics: The Variables information always shows 2 longs, regardless of how many variables the program has. Is it supposed to show how many variables are used by the program or does it actually show something else?
    Program: 3090 longs
    Variables: 2 longs << This is always 2
    Stack/Free: 5095 longs
    Regards
    Andre
    edited 2013-04-19 08:29
    Apologies, forgot to say I am using ViewPort Ver. 4.8.0, PropBasic.exe Ver. 1.30 and the Program runs in LMM mode.
    edited 2013-04-21 10:50
    Hi Bean,
    I remember downloading PropBasic Ver. 1.30 for Viewport from one of the many threads at some stage having found the post by pure coincidence, but I can't find it again. I had a disk crash and had to restore some backups this afternoon but I lost PropBasic Ver. 1.30 :frown:
    Could you perhaps update the first post in this Forum with the latest version of PropBasic?
    Regards
    Andre
  • VonSzarvasVonSzarvas Posts: 3,630
    edited 2013-04-21 12:27
    Hi Bean,
    I remember downloading PropBasic Ver. 1.30 for Viewport ...
    Regards
    Andre
    Try here at post 787
    http://forums.parallax.com/showthread.php/118611-Download-PropBASIC-here...-00.01.14-July-27-2011?p=1160689&viewfull=1#post1160689
    edited 2013-04-22 08:19
    Cool, thanks :smile:
