NEWBIE Needs Direction ...........
So after hitting the proverbial brick wall with the stamps limitations, and the subsequent conversation with Parallax tech support it seams I need to learn the Propeller.
The problem is I was just getting acclimated to the stamp, And I honestly don't know where to start.
I need advice, consider me as below entry level but highly enthusiastic and cant wait to start.
All advice will be appreciated. ....................
Thank you in advance.
I've collected some links to tutorials about programming the Propeller in post #3 of my index. There are several other good tutorials to go with the PEK including JonnyMac's SpinZone articles.
Edit: I was just looking at the Parallax store and I think if you were to get a QuickStart and one of these parts kits, you'd be pretty well set. You'll probably want to make sure you have a decent breadboard. One nice think about the PEK is the breadboad. It has more holes than most.
OldBitCollector (Jeff) has also been working with FemtoBasic and adding features to make a nice Color Basic (see here). Try it too.
So, these may still be my recommendations... But, I was mostly interested in VGA output.
So, I guess it all depends on what you primarily want to do...
I would go with the standard 40 pin kit. Two immediate reasons that I can think of. First, I think it is better for learning the more you do yourself and second, if you mis-wire something and burn up the chip it will be much more economical to replace it. You might even want to order a spare Propeller chip, if you don't need it as a replacement you could easily use it in a project.
