SW Exp #14: Scanning and Deboucing Multiple Inputs — Parallax Forums
playinmyblues_nsccplayinmyblues_nscc Posts: 38
edited 2013-03-01 10:57 in BASIC Stamp
Hi. I am hoping somebody can explain a section of program in StampWorks Experiment #14, page 94 of the book. I have an edited program in addition to the original program. In both programs I do not understand why the buttons have to be held down for the whole period of the FOR NEXT loop. I understand that that is what happens. In my program, I wrote a preceding loop to let me know when the time was approaching where I have to hold down the button. I also extended the time that the button must be held down so I can experiment with the time it is held down. For example, the first loop lets me know when the hold-down time is approaching so I hold down the button. The FOR NEXT loop counts for the debounce. I hold the button down prior to the loop and when the count is part way through I release the button and press it again before the time is up and I hold the button down until the loop is over.
The effect is I know for sure that the original program functions as it should and my program functions as it should. However, I do not understand why. The reason I do not understand why is that at the end of the count for which the button must be pressed, the boolean expression: btns = btns & ~BtnBus would equal a 1 or 1's at the appropriate place for the last count, or so I would think. Why is this not true?
Original program:
' {$STAMP BS2}
' {$PBASIC 2.5}
' -- Program: SW21-EX14-Debounce.bs2
' -- Purpose: This program demonstrates the simultaneous debouncing of multiple inputs. The input subroutine is easily adjusted to handle
' any number of of inputs.
' -- I/O Definitions --
BtnBus    VAR    INA ' four inputs, P0 - P3
' -- Variables --
btns      VAR    Nib ' deboucned inputs
idx       VAR    Nib ' loop counter
' -- Program Code --
Main:
  DO
    GOSUB Get_Buttons                    ' get deboucned inputs
    DEBUG HOME, "Inputs = ", IBIN4 btns  ' display in binary mode
    PAUSE 50
  LOOP
' -- Subroutines --
Get_Buttons:
  btns = %1111            ' enable all four inputs
  FOR idx = 1 TO 5
    btns = btns & ~BtnBus ' test inputs
    PAUSE 5
  NEXT
  RETURN
My program:
' {$STAMP BS2}
' {$PBASIC 2.5}
' -- Program: SW21-EX14-Debounce-Edit8Btns.bs2
BtnBus    VAR    INL ' four inputs, P0 - P7
' -- Variables --
btns      VAR    Byte ' deboucned inputs
idx       VAR    Byte ' loop counter
flip      VAR    Bit ' a bit sized counter to flip from 1 to 0 to 1 to alternate a DEBUG statement
idy       VAR    Word  ' variable used to count the PAUSE
' -- Initialize Variable --
flip = 0
Main:
  DO
    DEBUG HOME, "Inputs = ", IBIN8 btns, CR  ' display in binary mode
    flip = flip + 1
    IF (flip = 1) THEN
      DEBUG "Paws1", CR
    ELSEIF (flip = 0) THEN
      DEBUG "Paws2", CR
    ENDIF
'    PAUSE 5000
    FOR idy = 1 TO 500       ' This FOR NEXT loop is used to let the user know when the next opportunity to press the button is
      DEBUG CRSRXY, 0, 3     ' coming up. Otherwise, the user cannot know when to time the button press as the time is too short
      DEBUG DEC4 idy         ' unless the FOR NEXT loop below is extended to something like 100.
    NEXT
    idy = 0
  LOOP
' -- Subroutines --
Get_Buttons:
  btns = %11111111        ' enable all eight inputs
  FOR idx = 1 TO 50        ' the FOR loop is the debounce mechanism. It allows for the mechanical bouncing of the contacts to stop
                          ' and then it exits the loop and returns to the DEBUG statement in the Main part of the program.
                          ' Using a higher value for the upper limit of the FOR NEXT loop allows the person to experiment with
                          ' timing of the button press. If the button is released before the end of the loop occurs, the button
                          ' will show as not being pressed.
'    DEBUG CRSRXY, 0, 1, "idx: ", DEC1 idx
    DEBUG CRSRXY, 4, 4, DEC2 idx       ' this line gives a number that changes in one position on the DEBUG terminal
    PAUSE 5
  NEXT
  RETURN
Sorry for the poor code posting - recently fixed.
  • playinmyblues_nsccplayinmyblues_nscc Posts: 38
    edited 2013-02-28 17:56
    While you're at it can you tell me how to post code properly so it shows up in its own window, properly indented?
    edited 2013-02-28 18:05
    PhiPi's help link:
    edited 2013-02-28 18:14
    Dissecting,
    [SIZE=1][FONT=courier new]btns VAR Nib
    idx VAR Nib
    Get_Buttons:
         btns = % 1111     ' assume all four pressed
         FOR idx = 1 TO 5
             btns = btns & ~inA  ' test 4 inputs on inA
             PAUSE 5
         NEXT
         RETURN[/FONT][/SIZE]
    When a button is pressed, its bit in inA goes to 0. The ~inA operator inverts that, a pressed button comes out as 1. The % 1111 starts by assuming all buttons are 1=pressed. If a button stays pressed for all 5 scans, then its bit stays at 1&1&1&1&1 = 1. But if a button is let up even once during the scan, then the result is, e.g. 1&1&0&0&1 = 0. Debounced result is, "not pressed". Does that help?
    edited 2013-02-28 18:18
    Yes, it does. Thank you. It was a simpler explanation than I thought it would be.
    edited 2013-02-28 18:19
    Also, thanks for the link to posting code!
    My intention was to write another reply saying that while your explanation was simple, it did not really explain what was going on. However, I read through the program and explanation in the book again and see what you had written, Tracy, was essentially the same as what is written in the book. I think I was too tired last night to see it. Once there is a 0 introduced into the btns = btns & ~BtnBus boolean expression, that 0 will carry all the way through to the end of the loop.
    Thanks again!
