PropScope just stopped connecting?
rwgast_logicdesign
This morning I woke up and plugged my prop scope in.. my computer dinged as it does anytime I plug a USB device in. I opened the prop scope application and i then got an error saying the propscope could not be found. Next I rebooted my PC, unpluged the scope from USB, and Unpluged the probes. When the computer rebooted I plugged the scope back in, still the same error. Next I uninstalled and reinstalled the application, then rebooted. Still no dice.
The scope worked fine last time I used it and has just been sitting on the shelf for a few weeks. Im about to reformat my computer to see if that does the trick. Im running XP sp3. Does anyone know what may be causing this?
EDIT: I forgot to mention the scope does show up in my device manager as COM9 PropScope.
http://forums.parallax.com/showthread.php/123627-Latest-PropScope-software
I am having the same problem with my own PropScope device when I tried to run the PropScope program on my computer which results in a message being displayed that the device is not found.
