Weird. I went to my iPhone and saw the link. I went back to my laptop and did not see the link. I had to hit F5 and it refreshed and the link was there. I have never had to do that. It's a caching issue I suppose.
I ran the demo PAINT program and IT IS AWESOME!!!!! Great use of the mouse and I can't want to play with the code a little. Nice Job!!
I've been busy creating a new mouse cursor tonight with some graph paper. I think it turned out fairly good of a hand holding a stick pointer (cursor is in 3 colors).
CON 'Define cursor colors
mfore=lcd#rgb_LightYellow
mback=lcd#rgb_black
[B]mstick=$ff_a5_00 'Orange[/B]
PUB Main |i
'start VGA driver
lcd.start
'lcd.StartMouse(@MouseCursor1,@lineBuffer) 'Mouse support requires mouse draw data and a buffer big enough to hold background
[B] lcd.StartMouse(@MouseCursor2,@lineBuffer) 'Mouse support requires mouse draw data and a buffer big enough to hold background[/B]
[B]
DAT 'Define mouse pointer 2
MouseCursor2 long 'with long, no hot spot needed as points can be relative
long 17,22 'width, height of cursor
long 82 '#quartets to draw
long 0,1,mstick,1 'x,y,#width
long 0,2,mstick,2
long 0,3,mstick,2
long 0,4,mstick,3
long 1,5,mstick,2
long 1,6,mstick,3
long 2,7,mstick,2
long 2,8,mstick,2
long 3,9,mstick,1
long 8,5,mback,3
long 5,6,mback,2
long 7,6,mback,1
long 10,6,mback,3
long 4,7,mback,1
long 7,7,mback,1
long 10,7,mback,1
long 13,7,mback,2
long 4,8,mback,1
long 7,8,mback,1
long 10,8,mback,1
long 13,8,mback,1
long 15,8,mback,1
long 0,9,mback,3
long 4,9,mback,1
long 7,9,mback,1
long 10,9,mback,1
long 13,9,mback,1
long 16,9,mback,1
long 0,10,mback,1
long 3,10,mback,2
long 13,10,mback,1
long 16,10,mback,1
long 0,11,mback,1
long 4,11,mback,1
long 16,11,mback,1
long 1,12,mback,1
long 4,12,mback,1
long 16,12,mback,1
long 2,13,mback,1
long 16,13,mback,1
long 2,14,mback,1
long 16,14,mback,1
long 3,15,mback,1
long 15,15,mback,1
long 3,16,mback,1
long 15,16,mback,1
long 4,17,mback,1
long 15,17,mback,1
long 4,18,mback,1
long 15,18,mback,1
long 5,19,mback,1
long 14,19,mback,1
long 5,20,mback,1
long 14,20,mback,1
long 5,21,mback,10
long 8,6,mfore,2
long 5,7,mfore,2
long 8,7,mfore,2
long 11,7,mfore,2
long 5,8,mfore,2
long 8,8,mfore,2
long 11,8,mfore,2
long 14,8,mfore,1
long 5,9,mfore,2
long 8,9,mfore,2
long 11,9,mfore,2
long 14,9,mfore,2
long 1,10,mfore,2
long 5,10,mfore,8
long 14,10,mfore,2
long 1,11,mfore,3
long 5,11,mfore,11
long 2,12,mfore,2
long 5,12,mfore,11
long 3,13,mfore,13
long 3,14,mfore,13
long 4,15,mfore,11
long 4,16,mfore,11
long 5,17,mfore,10
long 5,18,mfore,10
long 6,19,mfore,8
long 6,20,mfore,8
[/B]
BTW: One trick I did for the arrow cursor is to just draw black all the way across (instead of at both sides) to reduce the number of lines of code... I was worried about flicker if it took to long to draw.
But, I don't notice any flicker with your cursor so maybe that's not an actual issue...
Absolutely. Use anything. I just appreciate learning from your code and others SPIN/PASM code to come up with some neat ideas.
BTW: Originally I came up with the standard hand with the index finger pointing up but changed it because at point 0,0 is where the drawing starts and it was off (not drawing from the finger pointing up). It would be nice for the user to be able to set the coordinates of the pointer starting location. Just ideas coming up in my head to act or not. Great stuff you have!
Tim, in Windows, the coordinate of the cursor application is called the "hot spot".
I was going to do something like that here, but realized that I don't have to.
That's because I just use 0,0 as the hot spot and allow negative numbers for the line start points...
It did not work with negative numbers. I got a lot of trailing lines that moved when the cursor moved. I tried a few times with simple small cursors with negative x values and was not successful.
Hmm... Well, I see one thing I maybe did wrong, but I don't think it should matter...
Anyway, can you please change two assembly "add" to "adds" and see if it helps?
Actually, I see now what the problem is...
It's not the painting, it's the restoring part that's not working...
lcd.StartMouse(@MouseCursor3,@lineBuffer) 'Mouse support requires mouse draw data and a buffer big enough to hold background
DAT 'Define mouse pointer 3
MouseCursor3 long 'with long, no hot spot needed as points can be relative
long 4,10 'width, height of cursor
long 9 '#quartets to draw
long 0,2,mstick,2
long 0,3,mstick,2
long 0,4,mstick,3
long 1,5,mstick,2
long 1,6,mstick,3
long 2,7,mstick,2
long 2,8,mstick,2
long 3,9,mstick,1
Here is the code I was using (the stick part of the other cursor). This works but if you make any x or y part negative... you get the trailing paint lines.
Maybe I have an idea on how to fix this for negative numbers, but it's going to take me a bit of time...
Actually, after sleeping on it maybe we should forget negative numbers and use the hot-spot approach.
Also, I think I'm going to change things so that each line only takes 2 longs instead of 4 to reduce the data size...
Ok, I've added hot spot support (easier than negative numbers)...
Also, I've made a lot of the cursor data bytes instead of longs to make it smaller in memory
(even though it takes more lines of code).
I've also added one extra feature that isn't exploited in this cursor defininion because I had a spare byte...
Using the spare byte as an x increment when drawing the horizontal lines.
Before the x increment was fixed at 1.
But now, to draw black on either side of the arrow, I could set width to 2 and x increment to the width of the cursor.
Make any sense?
I think this should speed up drawing.
Haven't tested this feature yet, just set all the x increments to 1 in this example...
Update: Just tried the x-increment and it works. It saves a bit of time drawing the cursor edge... Here's the new data for drawing the black edge of the cursor:
MouseCursor1 long 'must be long aligned
long 1,1 'hot spot offset in x,y
long 12,19 'width, height of cursor
long 41 '#quartets to draw
byte 0,0,1,1 'x,y,#width,increment
long mback 'color
byte 0,1,2,1
long mback
byte 0,2,2,2
long mback
byte 0,3,2,3
long mback
byte 0,4,2,4
long mback
byte 0,5,2,5
long mback
byte 0,6,2,6
long mback
byte 0,7,2,7
long mback
byte 0,8,2,8
long mback
byte 0,9,2,9
long mback
byte 0,10,2,10
long mback
byte 0,11,2,11
long mback
byte 0,12,12,1
long mback
byte 0,13,8,1
long mback
byte 0,14,2,3
long mback
byte 0,15,2,2
long mback
byte 0,16,2,1
long mback
I converted my cursor over fairly easily to your new format. It's twice as big as your arrow default MouseCursor1. Notice I moved the hotspot from 0,0 to 0,1.
Very nice!
Tim
mback=lcd#rgb_black
PUB Main |i
'start VGA driver
lcd.start
[B]DAT 'Define mouse pointer 2
long 0,1 'hot spot offset in x,y
byte 0,1,1,1 'x,y,#width
long mstick
byte 0,2,2,1
long mstick
byte 0,3,2,1
long mstick
byte 0,4,3,1
long mstick
byte 1,5,2,1
long mstick
byte 1,6,3,1
long mstick
byte 2,7,2,1
long mstick
byte 2,8,2,1
long mstick
byte 3,9,1,1
long mstick
byte 8,5,3,1
long mback
byte 5,6,2,1
long mback
byte 7,6,1,1
long mback
byte 10,6,3,1
long mback
byte 4,7,1,1
long mback
byte 7,7,1,1
long mback
byte 10,7,1,1
long mback
byte 13,7,2,1
long mback
byte 4,8,1,1
long mback
byte 7,8,1,1
long mback
byte 10,8,1,1
long mback
byte 13,8,1,1
long mback
byte 15,8,1,1
long mback
byte 0,9,3,1
long mback
byte 4,9,1,1
long mback
byte 7,9,1,1
long mback
byte 10,9,1,1
long mback
byte 13,9,1,1
long mback
byte 16,9,1,1
long mback
byte 0,10,1,1
long mback
byte 3,10,2,1
long mback
byte 13,10,1,1
long mback
byte 16,10,1,1
long mback
byte 0,11,1,1
long mback
byte 4,11,1,1
long mback
byte 16,11,1,1
long mback
byte 1,12,1,1
long mback
byte 4,12,1,1
long mback
byte 16,12,1,1
long mback
byte 2,13,1,1
long mback
byte 16,13,1,1
long mback
byte 2,14,1,1
long mback
byte 16,14,1,1
long mback
byte 3,15,1,1
long mback
byte 15,15,1,1
long mback
byte 3,16,1,1
long mback
byte 15,16,1,1
long mback
byte 4,17,1,1
long mback
byte 15,17,1,1
long mback
byte 4,18,1,1
long mback
byte 15,18,1,1
long mback
byte 5,19,1,1
long mback
byte 14,19,1,1
long mback
byte 5,20,1,1
long mback
byte 14,20,1,1
long mback
byte 5,21,10,1
long mback
byte 8,6,2,1
long mfore
byte 5,7,2,1
long mfore
byte 8,7,2,1
long mfore
byte 11,7,2,1
long mfore
byte 5,8,2,1
long mfore
byte 8,8,2,1
long mfore
byte 11,8,2,1
long mfore
byte 14,8,1,1
long mfore
byte 5,9,2,1
long mfore
byte 8,9,2,1
long mfore
byte 11,9,2,1
long mfore
byte 14,9,2,1
long mfore
byte 1,10,2,1
long mfore
byte 5,10,8,1
long mfore
byte 14,10,2,1
long mfore
byte 1,11,3,1
long mfore
byte 5,11,11,1
long mfore
byte 2,12,2,1
long mfore
byte 5,12,11,1
long mfore
byte 3,13,13,1
long mfore
byte 3,14,13,1
long mfore
byte 4,15,11,1
long mfore
byte 4,16,11,1
long mfore
byte 5,17,10,1
long mfore
byte 5,18,10,1
long mfore
byte 6,19,8,1
long mfore
byte 6,20,8,1
long mfore[/B]
Ti
CON 'Define cursor colors mfore=lcd#rgb_LightYellow mback=lcd#rgb_black [B]mstick=$ff_a5_00 'Orange[/B] : : PUB Main |i 'start VGA driver lcd.start 'lcd.StartMouse(@MouseCursor1,@lineBuffer) 'Mouse support requires mouse draw data and a buffer big enough to hold background [B] lcd.StartMouse(@MouseCursor2,@lineBuffer) 'Mouse support requires mouse draw data and a buffer big enough to hold background[/B] : : [B] DAT 'Define mouse pointer 2 MouseCursor2 long 'with long, no hot spot needed as points can be relative long 17,22 'width, height of cursor long 82 '#quartets to draw long 0,1,mstick,1 'x,y,#width long 0,2,mstick,2 long 0,3,mstick,2 long 0,4,mstick,3 long 1,5,mstick,2 long 1,6,mstick,3 long 2,7,mstick,2 long 2,8,mstick,2 long 3,9,mstick,1 long 8,5,mback,3 long 5,6,mback,2 long 7,6,mback,1 long 10,6,mback,3 long 4,7,mback,1 long 7,7,mback,1 long 10,7,mback,1 long 13,7,mback,2 long 4,8,mback,1 long 7,8,mback,1 long 10,8,mback,1 long 13,8,mback,1 long 15,8,mback,1 long 0,9,mback,3 long 4,9,mback,1 long 7,9,mback,1 long 10,9,mback,1 long 13,9,mback,1 long 16,9,mback,1 long 0,10,mback,1 long 3,10,mback,2 long 13,10,mback,1 long 16,10,mback,1 long 0,11,mback,1 long 4,11,mback,1 long 16,11,mback,1 long 1,12,mback,1 long 4,12,mback,1 long 16,12,mback,1 long 2,13,mback,1 long 16,13,mback,1 long 2,14,mback,1 long 16,14,mback,1 long 3,15,mback,1 long 15,15,mback,1 long 3,16,mback,1 long 15,16,mback,1 long 4,17,mback,1 long 15,17,mback,1 long 4,18,mback,1 long 15,18,mback,1 long 5,19,mback,1 long 14,19,mback,1 long 5,20,mback,1 long 14,20,mback,1 long 5,21,mback,10 long 8,6,mfore,2 long 5,7,mfore,2 long 8,7,mfore,2 long 11,7,mfore,2 long 5,8,mfore,2 long 8,8,mfore,2 long 11,8,mfore,2 long 14,8,mfore,1 long 5,9,mfore,2 long 8,9,mfore,2 long 11,9,mfore,2 long 14,9,mfore,2 long 1,10,mfore,2 long 5,10,mfore,8 long 14,10,mfore,2 long 1,11,mfore,3 long 5,11,mfore,11 long 2,12,mfore,2 long 5,12,mfore,11 long 3,13,mfore,13 long 3,14,mfore,13 long 4,15,mfore,11 long 4,16,mfore,11 long 5,17,mfore,10 long 5,18,mfore,10 long 6,19,mfore,8 long 6,20,mfore,8 [/B]Next step is to allow saving screen to sd...
Tim
I would not have considered negative numbers. Great idea. I'll have to take another look at this.
Tim
BTW: I'm thinking replacing the color picker with this image that is borrowed from Microsoft:
Tim
Might need to specify a "hot spot" after all...
I'll have to think about this a minute...
: lcd.StartMouse(@MouseCursor3,@lineBuffer) 'Mouse support requires mouse draw data and a buffer big enough to hold background : : DAT 'Define mouse pointer 3 MouseCursor3 long 'with long, no hot spot needed as points can be relative long 4,10 'width, height of cursor long 9 '#quartets to draw long 0,1,mstick,1 'x,y,#width long 0,2,mstick,2 long 0,3,mstick,2 long 0,4,mstick,3 long 1,5,mstick,2 long 1,6,mstick,3 long 2,7,mstick,2 long 2,8,mstick,2 long 3,9,mstick,1Here is the code I was using (the stick part of the other cursor). This works but if you make any x or y part negative... you get the trailing paint lines.
SSD1963_Paint - Archive [Date 2013.02.27 Time 19.50].zip
Make any sense?
DAT 'Define mouse pointer MouseCursor1 long 'must be long aligned long 1,1 'hot spot offset in x,y long 12,19 'width, height of cursor long 41 '#quartets to draw byte 0,0,1,1 'x,y,#width,increment long mback 'color byte 0,1,2,1 long mback byte 0,2,2,2 long mback byte 0,3,2,3 long mback byte 0,4,2,4 long mback byte 0,5,2,5 long mback byte 0,6,2,6 long mback byte 0,7,2,7 long mback byte 0,8,2,8 long mback byte 0,9,2,9 long mback byte 0,10,2,10 long mback byte 0,11,2,11 long mback byte 0,12,12,1 long mback byte 0,13,8,1 long mback byte 0,14,2,3 long mback byte 0,15,2,2 long mback byte 0,16,2,1 long mbackI converted my cursor over fairly easily to your new format. It's twice as big as your arrow default MouseCursor1. Notice I moved the hotspot from 0,0 to 0,1.
Very nice!
Tim
: CON 'Define cursor colors mfore=lcd#rgb_LightYellow mback=lcd#rgb_black [B]mstick=$ff_a5_00 'Orange[/B] : : PUB Main |i 'start VGA driver lcd.start 'lcd.StartMouse(@MouseCursor1,@lineBuffer) 'Mouse support requires mouse draw data and a buffer big enough to hold background [B] lcd.StartMouse(@MouseCursor2,@lineBuffer) 'Mouse support requires mouse draw data and a buffer big enough to hold background[/B] : : [B]DAT 'Define mouse pointer 2 MouseCursor2 long 'with long, no hot spot needed as points can be relative long 0,1 'hot spot offset in x,y long 17,22 'width, height of cursor long 82 '#quartets to draw byte 0,1,1,1 'x,y,#width long mstick byte 0,2,2,1 long mstick byte 0,3,2,1 long mstick byte 0,4,3,1 long mstick byte 1,5,2,1 long mstick byte 1,6,3,1 long mstick byte 2,7,2,1 long mstick byte 2,8,2,1 long mstick byte 3,9,1,1 long mstick byte 8,5,3,1 long mback byte 5,6,2,1 long mback byte 7,6,1,1 long mback byte 10,6,3,1 long mback byte 4,7,1,1 long mback byte 7,7,1,1 long mback byte 10,7,1,1 long mback byte 13,7,2,1 long mback byte 4,8,1,1 long mback byte 7,8,1,1 long mback byte 10,8,1,1 long mback byte 13,8,1,1 long mback byte 15,8,1,1 long mback byte 0,9,3,1 long mback byte 4,9,1,1 long mback byte 7,9,1,1 long mback byte 10,9,1,1 long mback byte 13,9,1,1 long mback byte 16,9,1,1 long mback byte 0,10,1,1 long mback byte 3,10,2,1 long mback byte 13,10,1,1 long mback byte 16,10,1,1 long mback byte 0,11,1,1 long mback byte 4,11,1,1 long mback byte 16,11,1,1 long mback byte 1,12,1,1 long mback byte 4,12,1,1 long mback byte 16,12,1,1 long mback byte 2,13,1,1 long mback byte 16,13,1,1 long mback byte 2,14,1,1 long mback byte 16,14,1,1 long mback byte 3,15,1,1 long mback byte 15,15,1,1 long mback byte 3,16,1,1 long mback byte 15,16,1,1 long mback byte 4,17,1,1 long mback byte 15,17,1,1 long mback byte 4,18,1,1 long mback byte 15,18,1,1 long mback byte 5,19,1,1 long mback byte 14,19,1,1 long mback byte 5,20,1,1 long mback byte 14,20,1,1 long mback byte 5,21,10,1 long mback byte 8,6,2,1 long mfore byte 5,7,2,1 long mfore byte 8,7,2,1 long mfore byte 11,7,2,1 long mfore byte 5,8,2,1 long mfore byte 8,8,2,1 long mfore byte 11,8,2,1 long mfore byte 14,8,1,1 long mfore byte 5,9,2,1 long mfore byte 8,9,2,1 long mfore byte 11,9,2,1 long mfore byte 14,9,2,1 long mfore byte 1,10,2,1 long mfore byte 5,10,8,1 long mfore byte 14,10,2,1 long mfore byte 1,11,3,1 long mfore byte 5,11,11,1 long mfore byte 2,12,2,1 long mfore byte 5,12,11,1 long mfore byte 3,13,13,1 long mfore byte 3,14,13,1 long mfore byte 4,15,11,1 long mfore byte 4,16,11,1 long mfore byte 5,17,10,1 long mfore byte 5,18,10,1 long mfore byte 6,19,8,1 long mfore byte 6,20,8,1 long mfore[/B]
